I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the settings but I dont know what I am doing wrong!
  • 3,940 Answers
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Posted on Jan 26, 2009
    How can I get my Avery 8876 business card sheets to feed through my printer?
    Avery is a fairly good name in the business.Brother on the other hand seems to have ignored the reasons why folks don't buy brothers. It's these little annoying things that bigger company's have spent time and energy on. For one there's usually a lever you push to control how much pressure the two fusing rollers push; hot rollers, for years this perplexed the big guys because there all ready is a pretty small tolerance of melting the toner and not burning the paper; melting the toner(powered plastic) next was the ever annoying OHP overhead projector sheets. this is plastic toner on plastic"paper" nightmare! melt the toner but not the plastic its on.... Well enough of engineering issues, time and perseverance paid off. now comes a sticky label on a waxxy surface that is twice as thick as paper and yet has toner to be fixed on it and dried....Some company's like cannon tried a cold roller that seemed to work at first but when things went bad they really went bad.labels coming off all in the wrong places... Toshiba and Savin Ricoh decided to get with Avery and others and make one side harder to come off than the other; reduce the squeeze pressure and increase the opposite "static cling" voltage. Also the angle it hit the feed section// Bypass feed only/Lt-R. Following the printed directions in the individual label sheet seemed to reduce the issue to a minimum. Understanding all the changes the poor piece has to go go through in an 8second processes is half the battle. hope this helps a smidge~~~SC
    Nov 08, 2014 | Office Equipment & Supplies
    HP Photosmart C4795. Can't get business cards to align correctly at top. Alignment is perfect on plain paper, but starts too high on card stock so every one is lined up wrong. What am I doing wrong? Using...
    In printing properties and printing preferences be sure and tell the printer you're printing labels, it allows more time for the card stock to reach the starting point.
    Jan 05, 2010 | Office Equipment & Supplies
    Paper goes through tray 1 the image prints landscape on portait
    Try placing the business card sheet in the main paper bin instead of the manual feed or adjusting the print orientation from Portrait to Landscape or vice versa.
    Sep 25, 2009 | Computers & Internet
    Jammed card stock
    This machine has auto paper type sensor- may be at fault
    May 01, 2009 | Dell Photo 964 All-In-One InkJet Printer
    Mis-alignment during printing of labels sheets
    Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
    Mar 23, 2009 | HP DeskJet F380 All-In-One Printer
    Printing business cards
    Feed sheets through front manuel feed slot.
    base tray is mainly for up to 90grm paper,anything heavier
    can feed for a time but tends to fault.also try and clean the
    paper pick up rollers regularly.
    mongrelken.
    May 20, 2008 | Brother HL-2040 Laser Printer
    Problem printing business cards
    in your program adjust the pic your printing to fit in yours sumtimes u have to adjust your print in preview box your card u made down or up whole thing so it fits in nice for u sumtimes they just dont line up right i had same issue just move your project up with it ok to make it print in box cards u need ok
    Mar 13, 2008 | HP PSC 1210 All-In-One InkJet Printer
    Avery Ink Jet Magnetic Sheets - 3270
    It worked fine for us on an Epson. We printed about 40 sheets fed one at a time. Do not stack the sheets in the feed hopper, they stick together because of the magnetism.
    There is no template because the material is not die cut. It is just full 8.5x11" sheet size.
    Feb 04, 2008 | Avery DesignPro Deluxe CD-ROM...
    Print Garbage
    The reason your pictures come out dark and grey is that you have not set the paper thickness on your printer. On the back you will see a flip switch change this setting then feed your business card sheet in there and see the diffrence. Plus make sure your settings for your printer are set for a thicker paper this will fix your problem. Make sure though when done printing your cards that you set it back to the normal or you will have problems printing regular paper documents.
    Sep 15, 2007 | HP OfficeJet 7310 All-In-One InkJet...
    Computers & Internet Logo
    181 people viewed this question
    David Payne
    David Payne
