Question about Hitachi 43F300 43" Rear Projection Television
Ghosting or distortion on edges of screen
The image on my Hitachi 43f300 out of the blue just got distorted. over the edges specially on the top left and bottom. If I look at the center, it looks fine but it just looks like it "droops". Like if my tv suffured a stroke.
I bought the tv on dec 2003. Could it be the end of the TV?
  • Hitachi Master
  • 3,459 Answers
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneerghosting or distortion on edges of screen - 2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
THE PICTURE IS GHOSTING AT THE TOP & BOTTOM OF THE SCREEN. THERE
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Problem #2
Dec 28, 2009 | Hitachi 46F500 46" Rear Projection...
The right edge of screen is distorted and red and green colors are seperated. Is this fixable ?
The Convergence Amps have failed, Possibly also has 1 or more burnt resistors. Hitachi has kits to repair this problem. But only if you are good at Disassembly and Reassembly and can solder well. Otherwise get actual Technican to do the repair. Average price from a shop should be $175 to $225. Thats my price range for this repair.
Oct 22, 2009 | Hitachi 43F300 43" Rear Projection...
Red and Blue color bowing...
Hi, you`ve lost your convergence IC`s, At our shop here in western florida this runs right around $246.00, price will depend on your geographical location and who you call. gl, video-tek
May 29, 2009 | Hitachi 50FX30B 50" Rear Projection...
Color ghosting or shadows
*Screen Looks 3-D
*Colors wont align
Problem #2
Jan 19, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Hitachi Projection tv
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 17, 2008 | Hitachi 43F300 43" Rear Projection...
Double Image
Convergence repair needed.....order kit part # X480293....
has two IC's and some resistors...................T.
Mar 28, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Color Issues with red ghosts on screen
The suggestions listed would be relevant for 'Ghosting' by itself, however you mentioned you tried to use the crosshairs to line up the images4.gif, which implies convergence - red/green/blue image separation and/or distortion. NONE of the solutions mentioned were anywhere close to the fix for this problem - this us usually cut and dry; convergence circuit failure. Generally, STK ICs are used. (Common parts are STK392-010/020/040, STK392-110/120/150/180, etc.) Most times replacing BOTH of these chips will be enough, sometimes there will be a blown fusible resistor and/or burnt resistors near the chips themselves. If you don't implicitly know exactly what I'm talking about, don't attempt it - take it in to a repair shop. For in-shop repair, this would NOT exceed $250 (EVER) at our location, unless there was more damage done, which is a one in a hundred situation. Good luck!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2008 | Hitachi 43F300 43" Rear Projection...
Distorted view at upper 20% of screen horizontally
Wow for the convergence to shift you must have really moved it. First try the manual convergence on the set. if that dosent help then your gonna need a pro to come in and adjust it for you as it takes special equipment and the know how to do this kind of alighnment as its not a consumer alighnment sorry couldnt assist more. Good Luck
Jun 11, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43F300 43" Rear Projection Television Logo
113 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
