Question about JVC CP6U Adapter
Why does my VCR keep ejecting my JVC CP6U adaptor? I put a cassette in the adaptor then put it in a VCR. " play " is activated for a second then shuts off and ejects the adaptor. VCR is working with other regular VHS tapes.
shadow5599
  • 51 Answers
SOURCE: DVD Drawer / VHS Eject button
My 1st suggestion is to pull the AC power plug from the wall, wait 5 minutes (have a smoke or a coffee) and plug it back in.
Then retry the functions that are giving you grief.
Report back with the results and we'll go from there.
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating Other than Solved
Posted on Oct 18, 2007
  • 10 Answers
SOURCE: JVC HR A62U VCR
I was wondering if you tryed unplugging vcr for an hour then
plugging it back up. sometimes this resits it and it will work fine.
the tape might eject itself out or eject button might work.
Posted on Nov 13, 2007
MNfisherman
  • 11896 Answers
SOURCE: Will not release the cassette when ejected and breaks the tape.
there is a spring attached to the tape release gear that will eventuall wear out through time, also, sometimes the rubber belts wear out and throws the timing off.
That would be the first two things to check. Make sure spring is not stretched. Try testing with cover off and watch to see if the part holding the back of the tape releases.
Posted on Mar 11, 2009
SOURCE: problem ejecting tapes getting stuck
The take up is not rewinding the tape all the way back into the shell. Check the idler, it's either worn or if it's plastic it is warped from the heat.
Posted on Apr 30, 2009
  • 16 Answers
SOURCE: JVC HR-S9500 S-VHS VCR. all functions work except
the eject button is a plastic piece that turns and pushes down on the board and is more then likely broken open the vcr take off the front face plate and check the button, it will propaply fall out. you can use super glue and glue the button back in place
Posted on Jan 05, 2010
How to open jvc c-p6u cassette adapter?
Change the AA battery. I did and the switch worked and it ejected.
I had no idea there was a battery involved.
Panel on left end
Aug 15, 2011 | JVC CP6U Adapter
Jvc video recorder. cassette will not eject
make a hard reset and try to eject
Jul 08, 2008 | Cameras
I have a JVC C-P6U Cassette Adapter,I have not used it for some time as there was a cassette inside I put it in my TV and played the tape which was great when it was finished I wanted to remove it and play...
the adapter is probably jammed you may need to use a little force for the switch also a little force to try and pry it may work without damaging it. please let me know if this helps if now i will glady do more research on it for you but this is what i found when i was looking up the adapter issue.
Mar 14, 2011 | JVC CP6U Adapter
Red lever stopping adapter from going in vcr
That lever is there for a reason. The adapter needs a battery in it to run the motor to lace up the small tape before it goes into the VCR. If it goes in without the tape being laced it won't play and might cause damage.
Jan 18, 2011 | JVC CP6U Adapter
Unit accepted cassette, won't eject
check the tips in my profile
May 10, 2010 | Sony EVC100 Hi8 VCR
It is likely that either the drive belt has broken or is slipping. Because the unit is still in "play" mode, the mechanism won't let the door open up. If you have not opened up these units before, do not attempt it now. This unit should be taken to an experienced tech for repair. Where are you located?
Dan
Apr 08, 2010 | Sony EVC100 Hi8 VCR
Vcr will not play tapes,it ejects the tape after a few seconds
This may be caused by the mode switch.
By the way it uses a K-Deck Mechanism.
Sep 11, 2009 | Televison & Video
VCR ejecting my cassettes
Try removing the top cover & have a look to see what happens when you put the tape in & press play/rewind etc. Is the take up spool (right hand spool) turning properly or is there slack tape not being taken into the cassette? Are the heads spinning ? I think your problem is more likely to do with the tape not travelling smoothly around the tape path. Possibly the clutch gears need cleaned or the soft brakes may not be dis-engaging properly.
Jul 19, 2009 | Televison & Video
VCR ejects blank tape only
It sounds like the cassette is not releasing the tape so the machine can put it around the heads. This could damage the machine. Don't use it. A two dollar tape is not worth damaging your vcr. Throw it away.
Oct 09, 2008 | GE Televison & Video
JVC HR-S9700 TAPE STUCKS, HAVE TO BE PULLED OUT, CASSETTE DOOR REMAIND OPEN,VCR SWITCHES OFF-CAN NOT BE PLAYED AGAIN
Check out the drive that works the unloading and loading operation of your machine. Also check the switch that is activated by the presence of your cassette. If something is wrong with the latter, the tape will not load and unload properly. And under those circumstances your machine will not work.
Try Google search for your questions. You may get lucky and get the answers right there!
Mar 13, 2017 | JVC HR-S9600 S-VHS VCR
JVC CP6U Adapter Logo
74 people viewed this question
Top JVC Cameras Experts
Michael Galve
Michael Galve
Are you a JVC Camera Expert? Answer questions, earn points and help others
