Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool washer problem with door
I believe that the door latch on my whirlpool washer is broken if I push it over it will start my machine but then if i open the door again the machine will not continue in the cycle. I know the door latch is a plastic piece as it has broken before, but we would like to change it ourselves this time but dont know how to lift the top of the machine to get at it.
  • 5,911 Answers
I believe you are talking about the lid switch. To replace follow these steps: 1. UNPLUG the machine first. 2. Remove the console. You will have one of two types of consoles with two separate methods of removal. a. The first type is a matter of removing the two end caps of the console by lifting up on the end cap from back behind the console and pulling towards you. The cap should just pop off. There will be a groove present on the top rear that you can gently pry with a screwdriver if you can't remove by hand. You will need to remove the philips screw under the end caps and the console will lift up. Be careful not to break the plastic hinges that hold the console in place. You can lift it up and lay it back over the rear panel in a resting position. b. The second type of console (usually found on some of the newer models) has a retaining clip under each end cap at the front corners. You will need to carefully slide a putty knife between the end cap and top of the machine from the front. Push in to release the retaining clip and lift up. This may be a little tricky trying to get both ends to release together. The console lifts up in the same manner as described before. Again, be careful not to break the plastic hinges that hold the console on. 3. You will find two brass colored clips under the console. Place a flat blade screwdriver in the clip groove on the washer top and push away from you. This will release the retaining clip that holds the case to the back of the machine. Remember how they came off, because you will need to put them back in. 4. Disconnect the lid switch plug from the connector. This is a white plug that is mounted physically to the washer top casing. 5. Lift the lid and place one hand under the front rim of the casing and pull up from the rear towards you. The entire casing should lift off the frame. 6. The lid switch is located on the right side of the machine in most washers. Some are located in the back on the left hand side. In either case they are fairly simple to remove. There should be a couple of mounting screws and a ground wire to remove first. Then the switch (with harness) should come off. You will need to carefully remove the connector from the casing by using a small screwdriver to release the tabs holding it in. 7. The new switch will install using the reverse order of the steps I just mentioned. 8. Placing the case back on the frame can be tricky. Lift the lid again and place one hand under the front rim of the casing. Looking down through the lid, place the front of the casing UNDER the frame first and slowly lower the rest to the back. There are two cleats on the frame that must line up with two holes in the casing. Once the casing lines back up on the frame, set it down all the way and pull the back up to meet the casing so you can place the brass retaining clips back in. Place the clips in the groove on the back first, then push down until they snap back into the hole on the washer casing top. You may have to use a little effort to get them back in. 9. Reinstall the console. I know this seems like a lot, but it should help you replace the switch. Getting the machine case to line back up is the hardest part of the procedure, but you can do it if you take your time. Let me know if you have any further questions.
Posted on Jul 17, 2007
I have a whirlpool front washer and the door will not latch shut . What should I do?
Examine the latch on the door. is it broken? If so, then replace it. If not, replace the catch on the machine.
Jun 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool front loader won't start. The lights are on, the door is closed, but when I push the "hold to start" button, nothing happens. Could the latch be broken?
Two things 1) do you have delay start pushed?
2) the door latch cannot energize and catch the keeper this is a limit switch telling the computer (on board controller) that the door is not yet shut. Worst case try 1 slam of the door it cannot hurt at this point of the game.
Apr 18, 2010 | Whirlpool Washing Machines
The panel is not working when I press start it beeps and that set
Take a look at the door switch actuator. Located right above the latch in the washer's front panel. If the switch actuator is broken off, the machine will just beep and not start. If broken, part # is 8182634 and is very easy to replace, you just remove the outer clamp from the door seal, remove the three screws from the door latch, pull back the seal and access the latch. There are three wire harnesses, but they are all keyed differently, so no way to do it wrong.
Nov 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer model ghw9200lw
Either your door lock or latch is broken.
Door lock part # WP8182634
Door latch (Striker) part # WP8181651
If it is latch striker you will see it broken and this part is in the door itself.
Door lock is in the frame of the washer.
Check the part pictures at www.repairclinic.com
Oct 26, 2017 | Whirlpool Washing Machines
Whirlpool Duet front load washer won't start
The error codes it is showing don't even exist. Does the little round door latch plunger go in and out if you push it?If not, then replace the door latch. If so, you most likely have a bad machine control. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door wont latch shut
Is there a dl code? If not note the door striker position as the door closes. If you have to push it shut you need a door lock and if the striker is hitting below the latch too much a hinge will fix it. Finally look for a black pin above the striker for any damage as the latch will need to be replaced if broken too. Because with this and a door hanging low will not close the circuit and the ccu will believe the door is open also.
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Broken door
You probably have to bad door latch. its easy to replace. it requires i believe a number 20 torx bit you have have to remove the spring around the door boot and then you can put you hands to inside the unit to remove the latch.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet won't start
Open the door and look at the latch on the right side of the opening. Just above the hole the door latch fits into is a small switch. It should be sticking out about a quarter of an inch. You should be able to push it in and out easily. It is very common for these to break. If it is broken, the door latch assy will have to be replaced. About $65 for the part. You may be able to break a round toothpick or something else about that size to use as an actuator until you can get it repaired. Just stick it into the broken switch with about quarter inch sticking out. Then carefully close door. Post back to let me know if this helps or not.
Oct 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
918 people viewed this question
Dan Webster
Dan Webster
Sal De
