Question about Canon EOS 550D Rebel T2i Digital Camera
Camera behaves as bulb even when on 1/100
My 550d behaves like it's on 'bulb' when the sutter speed is set to a faster speed, such as 1/80. note that it happens when shooting from the viewfinder` when shooting in live mode everything works properly.
    Genius:
  • 1,019 Answers
Shut the flash off with the manual setting. it sounds like light censor problems. needs to be repaired.
Posted on Jan 26, 2013
poolseman
  • 206 Answers
SOURCE: lcd screen does not display viewfinder image
That is normal. Didital SLRs are different in this respect from digital compacts .
Posted on Sep 02, 2007
SOURCE: Canon shutter is stuck on bulb
Never mind, I fixed it. Thanks.
Posted on Dec 11, 2008
  • 285 Answers
SOURCE: Viewfinder not working when in camera mode
Impossible! the viewfinder on this camea is not electronic. it is optical, impossible to see the pictures you already took. anyways, try pushing disp.
Posted on Jul 03, 2009
  • 5 Answers
SOURCE: cant get live view to work
To activate live view you have to set live view to on just as you did and then press the set button and vouala!! image appeares on your screen and if you have selected quick focus you have to press the AE lock button to focus on the subject.
I hope you found this hint usefull.
Posted on Aug 07, 2009
xscrewdriver
  • 246 Answers
SOURCE: LCD screen is black in Photo mode Canon SD1100;
Press DISP. button, and repeat untill the display shows up
Posted on Aug 10, 2009
I just bought the minolta XG-A, will I be able to adjust manually the shutter speed? I just bought it only, still has not been shipped. I bought it mainly for a film photography class but I just read that...
Minolta XG-A can work in full manual mode. The lowest shutter speed is 1 second and it had Bulb mode where the shutter is open as long as you press the button.
Sep 12, 2013 | Minolta XG-A 35mm SLR Camera
Cant set shutter speed past 200
Is the flash turned on? The camera won't let you set a shutter speed faster than 1/200 when the flash is on.
Dec 08, 2012 | Nikon D3000 Digital Camera
For my trip to Indonesia for a month I thought of buying two Sanddisk SDHC 8GB Exreme Pro UHS-1 cards. I have a Panasonic LX2 camera, what is the max memorycard speed (class) the camera can take? Is...
The camera can use any speed card. If you get a very slow card, the camera will slow down to it's speed. On the other hand, if you get a very fast card, the card will simply slow down to the camera's speed.
Faster cards tend to cost more than slower cards. For a camera like this, I wouldn't spend more money than for class 4 cards. Faster cards will not make the camera operate any faster.
Jun 08, 2011 | Cameras
Nixon S8100 fairly new camera, nice pics if the subject doesnt move but horrible pictures if object moves. Very blurry.
If everything in the picture is blurry, you are moving the camera when you press the shutter button. If only the subject is blurry and the background is clear the problem is too slow shutter speed. If this is cause by movement of the camera you must learn to SQUEESE the button while being sure you don't move the camera. It just takes a little practice. If this problem caused by a shutter speed that is too slow, it is remedied by increasing the ISO "film" speed. Even though you have no film, the camera has a "speed" setting that relates to that. The higher ISO value increases the camera's sensitivity to light and thus allows for faster shutter speed. Normally the ISO choices are 100, 200, 400, 800, 1600. Try using 400. The ISO setting is in one of your camera menus. 400 is fast enough to solve your problem in all but very fast movement of either the camera or subject. Using ISO above 400 will cause your pictures to look grainy and not as sharp. Use the highest speed only when absolutely necessary. Slower ISO numbers produce the finest grain and thus the sharpest pictures. It a trade off between ISO and shutter speed because the exposure is a combination of the ISO and shutter speed and lens opening. Each one effects the exposure by half or double.
Apr 16, 2011 | Nikon Cameras
When failed trun signal bulb, Jeep turning signal is fastly blinking. I changed rear turn signal bulb with LED bulb, but turn signal blinking speed doesn't go to normal, At first couple of seconds it is...
Try replacing with the same bulb type as was failed. Flasher unit isusually reliant on resistence from the bulbs to what speed that side will flash at when powered.Some of these led type have less resistence and that equates to a faster flash speed.That is why when one bulb blows that side will flash faster or may even stay on without flashing.You could even swap the led to the other side( to confirm.Check with the bulb retailer to whether they have those bulbs with a higher rated resistence in led.If this vehicle has leds as standard,you may need to get the correct type from dealer. Hope this helps or get back with findings if it still has fault after replacing bulb.
Mar 29, 2011 | 2009 Jeep Patriot
My camera won't charge, i plug it into the computer throught the USB & the camera lights up like it's actually charging but after a cpl hours I took it off the USB & as soon as i cut it on it cuts...
The C1033 does NOT charge batteries. By plugging it into the computer you've actually drained the batteries faster since the camera has to spend juice communicating with the computer (even if only to say it has nothing to say). Put in a fresh set of batteries, and next time don't leave it connected to your computer.
Mar 26, 2011 | GE C1033 Digital Camera
Slow sutter speed/Lag in taking a picture
Use full auto mode or take out of Aperature priority, you may be shooting with a very small aperature setting and not know it. Also shutter priority can be set to a slow shutter speed.
Sep 24, 2008 | Fuji FinePix S5000 Digital Camera
Settings for movement on Cannon Power shot SX100 IS
The right setting should be one that says for moving objects or some definitions like that in your camara.
Take care
artgirl
Jun 20, 2008 | Canon PowerShot SX100 IS Digital Camera
Canon EOS 550D Rebel T2i Digital Camera Logo
54 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
