Question about Dymo LetraTag QX50 Thermal Label Printer
I can't figure out how to remove border remove border
Border
go into tools, border, select none
Apr 24, 2013 | Acer Computers & Internet
How do I disassemble a sony ecm-nv1 microphone?
remove the sony sticker and you reveal 2 screws.
unscrew them with a small cross screwdriver then take apart the 4 parts shell (2 sides, top cap and rubber bottom) running your nail trought the border.
now you can access the electronics :D
Feb 07, 2013 | Sony ECMNV1 Microphone
Widen border on Toshiba lap top
Widen border on what? A document, if so go into page setup. If you're talking about the whole screen, go into the Desktop under the Control Panel and change the screen resolution.
Mar 30, 2012 | Computers & Internet
Remove cover from HP w2408h monitor
pop the roundish 'HP' cover of the back of the stand. Remove the 4 black screws and the stand comes away. The case is just a clamshell affair, the main piece is the rear cover, the LCD front plastic border locks into it. The screen with components mounted is sitting loose in the back cover once the front border is removed. The trick is to pry off the front border without damage. Hook the fingers under the border where it lays against the LCD screen, wiggle, pull, curse and do it again. The top and bottom borders come loose easier than the end borders. Once these are popped free, stand the unit on end between your knees and pry away the end borders. A wide putty knife slipped between the border and metal frame will save your fingers but don't damage the screen. When the front border is off, lay the unit face-up on a table, undo the screws for the control panel and power switch modules, flip it over and lift off the back panel. Everything is under a metal casing.. I had no voltage from the power supply, trying to find a Fairchild chip SG6902SZ on the small control module, P/N ILTR-003, else the Pwr Bd, P/N ILP-004..
Jan 05, 2010 | HP w19 19" LCD Monitor
I have the canon power shot d10. i left my
There is no removeable border around the LCD so your instruction book would not be able to help. This is a waterproof camera. Trying to remove any of the water seals will compromise your water tight integrity.
Aug 28, 2009 | Canon Cameras
Removing borders
can't, you have to re take them. sorry.
Nov 06, 2008 | Samsung Digimax 4010 Digital Camera
Dymo LetraTag QX50 Thermal Label Printer Logo
16 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
GuruGrundy
GuruGrundy
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
