Question about Tricity Bendix AW850W Front Load Washer
Aw850 washing machine
Keeps filling up with water when switched off
    Scholar:
  • 86 Answers
Hi, Is the water clean or dirty? If it is clean then your water valve in side the machine is letting by and will need replacing. If it is dirty water then it is coming in from the sink trap if it is connected by this method, Or it is to far down the stand pipe and is coming back in via it.
Let me know....
Posted on Jan 26, 2009
  • soredaffy Feb 28, 2011
    Hi Yamahakrisfi,
    the water appears to be clean. Every time I do a wash there is slightly more water left in the drawer than the time before.
Water keeps filling even when not in use
hi Jeremy.
Why does my washing machine keep filling up with water when not in use? Ensure that the waste pipe of the washing machine is higher at one point than the drum of the machine, this will prevent water running back into the machine. Normally this would fill the machine with dirty water. Or it could be a faulty water inlet valve, which will fill the machine with clean water.22 Sep 2007
why is my washing machine filling up with water when off ...
forums.moneysavingexpert.com/showthread.php?t=558300 Search for: Why does my washing machine keep filling up with water when not in use?
if you want to read up more then go to this link.
Washing Machines keeps filling even when not in use Google Search
Nov 18, 2017 | Washing Machines
Washing machine starts filling then wont go any
there are a lot of questions of a simular nature check the diaphram switch this controls how much water is taken in and wont progress until the switch says so what you dont say is if the machine keeps filling or stops filling and wont progress
Jan 16, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Help! My fisher paykel washing machine won't stop filling up!
If the water continues to fill even if unplugged the water valve is sticking and needs replaced. if removing power turns the water off the water level pressure switch is bad or there is something plugging the sensor tube somewhere.
Eric
Nov 22, 2009 | Washing Machines
2 problems 1st is the washer continues to fill with water when i put in a new load second is it wont spin
If the water keeps filling without cutting off, you either have a faulty inlet solenoide or your pressure hose and or pressure switch needs checking.
To isolate the acutal problem, start the machine on a new cycle. Change the water level to minimum or low before you start. Let the machine fill up. Keep checking the water intake as it fill up. Once the water level goes over the half way mark in your tank, if the machine starts its wash action then your pressure hose and switch are o.k. as they have signalled to the timer that the water level selected, has been reached.
However if the machine keeps filling up even though the wash action has started, then you have a faulty inlet solenoide/valve. Turn off water at the tap and get the valve replaced.
Ash
Oct 26, 2009 | General Electric WCSR2090G Top Load Washer
Washing machine continues to fill when starts
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Oct 01, 2009 | Washing Machines
Washing machine won't quit filling with water and starts washing while still filling. Have to shut water supply off in between cycles so it can do its wash, rinse, spin. Otherwise as I stated, it will keep...
Check the water level switch. It's a diaphragm like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level it activates the switch to shut off the water. Check the plastic tube for any obstructions or damage. The switch can be tested using an ohmmeter or multimeter. Check for continuity. A lack of continuity indicates a faulty switch. Sorry for your trouble and I hope this helped. Best wishes.
Sep 07, 2009 | Washing Machines
Keeps filling with water when turned on
A lot of wahing machines use a bunch of micro-switches to turn the various solenoids on and off. If your washer has that type of switch, it could be sticking, subsequently sending an "on" signal to the fill solenoid.
Apr 19, 2009 | Washing Machines
Washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Feb 20, 2009 | Admiral AW22 Top Load Washer
Washing machine won't stop filling with water
if it keeps filling when unplugged replace fill valve if shuts off ckd pressure switch and hose to switch from tub
Nov 18, 2008 | KitchenAid KAWS750L Top Load Washer
My washing machine is stuck on filling up with water it wont wash
If it keeps filling and overflows you need to check the water level switch and hose. If it keeps filling but doesn't leak out the you drain hose is too low or too far down the drain.
Apr 24, 2008 | Washing Machines
Tricity Bendix AW850W Front Load Washer Logo
83 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
