Question about JVC AV-27230 27" TV
Screen went full bright one day.
The picture is still barely visible but very gray, with retrace lines. I can adjust the brightness but it will only go brighter. If I adjust the contrast the retrace lines will fade but the picture is no longer visible.
    Sergeant:
    Champion:
  • 326 Answers
Hello, please check the 10uf/200V capacitor around flyback transformer. Best regards, Arpi
Posted on Jul 17, 2007
Samsung HiTron, CD50F2, high bright, flyback line white visible, menu text blurred
Check the screen voltage. Adjust it to a little lower and check. Check the supply voltage to its video output stage [CRT base card]. If this voltage is less than normal, this kind of fault can occur. Check the smoothing capacitor [the electrolytic capacitor of low capacitance value] is bad. If it is bad, the voltage stated above will go low,and the retrace lines will be visible. Check these.
The fault you now see is technically called vertical retrace lines with picture. The above said are the main causes for this.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts.
Mar 31, 2014 | Televison & Video
I have a tube tv. the picture as lines and is blur that goes in and out.
If the lines are colored DIAGONAL lines, they are referred to as "retrace lines," which indicates either that the picture tube bias is set too high, or the brightness level is set too high.. If the blur occurs when the image is particularly bright or a particular color is bright, it is referred to as "blooming." This is caused by either a weak high voltage circuit or because the picture tube bias is set too high.
Is the picture set very bright? Try reducing the brightness control to a level where the retrace lines disappear, and reducing the contrast control below the level where the blooming occurs.
If the television is more than ten years old or has many hours of use, the picture tube may simply be deteriorating normally. By nature, they have a limited life span. Before you decide to throw the set out, if you are technically-inclined, try adjusting the bias and screen drive controls for the television as recommended by the set manufacturer (you didn't specify what make or model the set is), and you may get a few months or years of additional life out of the set.
Jul 05, 2011 | Televison & Video
At first it was lots of horizontal lines over the screen, and later TV screen went completely black. The sound still is perfect. Perhaps I just need to replace the fuse? I love this TV! Thanks...
Hello
You have stated that your TV has a lot of horizontal lines before it went off picture. We say that lines as retrace lines. So many of them will there on the entire screen, at about one inch or so apart, horizontaly scattered along with picuture. At that time, you may be unable to down the brightness control also. Even though you have reduced the brightness control to zero position, there will be some brightness level on the screen. You should have to repair that fault at the begining. There is a voltage going to the picture tube base, known as screen voltage. That voltage determine the emission of the picture tube, and we call it a bias voltage. When it goes higher than normal, this trouble ie retrace lines will occur. In long run it may spoil the picture tube itself. I don't know what the case of yours.
Anyway it is best for you to consult an experience technician in this case. Ok.
Nov 05, 2010 | Sony KV-35V35 TV
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
I have blue arched lines on my sony kp 57wv600 is there a fix for this
Those are retrace lines, the screen controls which are a technical control located under the front gray panel of your tv needs adjusted. This also could be an indication of a bigger problem, most common would be the focus block failing. it could also be of the picture tubes failing but this is not as common or possibly the crt driver ic's. There are specific diagnositc steps to preform to isolate the potental failure. this could lead to the tv going very bright then shutting down.
The first thing a tech is going to do is to adjust the screens and leave, somtimes this is enough, but sometimes it is not. if you want to try and adjust the screen i have an instruction set below, but i must warn you that there are high voltages present when attempting this adjustment and can be dangerous if you are un familure with tv repair.
Turn your color all the way down and the brightness in the middle, then find the focus block, it will be a block with 6 controls one row will say screen the other will say focus near the picture tubes, adjust the screen controls(one control for each color) until the picture has a good black and white look to it, then turn your color up and it should look fine. This is how i balance out the picture. But there is another method that allot of techs use, the other method is to adjust the brightness up until you see what is called retrace lines it is a jagged line going down the screen, once you see these lines back the adjustment down just until they disappear. Do this for all three colors. This method works but on an older set can throw the white balance off because of tube wear.
Aug 05, 2009 | Sony KP-57WV600 57" Rear Projection...
Have 46 samsung dlp that has green lines all over the screen . menu still works but doesnt go away on the menu mode. the green is so thick that you cant see any picture in the background.
Red, green, or blue retrace lines ( a quote from "Notes on the Troubleshooting and Repair of Television Sets", found at http://www.repairfaq.org/sam/tvfaq.htm#tvrgbrlin )
Where only one color is showing, suspect an incorrectly adjusted individual background/bias control or bad part on the CRT neck board for that color.
  • Individual brightness/background/bias control(s) - mark setting of pot for the problem color and then see if a slight adjustment removes the retrace lines. See the chapter: "TV Adjustments". Of course, if this happened suddenly, the problem is not due to a misadjusted control though a dirty pot is possible - turn it back and forth - this might clean it and restore normal operation.
  • Component or connection on CRT neck board - insufficient voltage to or incorrect biasing of the video driver for this color can result in the CRT never totally blanking. Compare voltages and signals, and swap components between good and bad channels to confirm.
  • Blanking circuit - this may be a part of the video/chroma chip or separate. Check and compare waveforms of good and bad colors to determine if the blanking pulses are making it to the video output.
There is a slight possibility that a bad CRT may result in visible retrace lines. To eliminate this possibility:
  • Disconnect the filament - all evidence of a picture, raster, and retrace lines should disappear once the filaments/cathodes have cooled (15 seconds or so. If there are still visible retrace lines, the CRT is suffering from cold or field emission from someplace (may not even be the cathode).
  • Turn down the screen (G2) control on the flyback (usually). If one color remains no matter how you set the control, again there is some kind of weird emission from the CRT. However, if white/gray retrace lines remain, the problem may be in the screen supply.
(quote ends)
You will be greatly helped if you have a schematic for your TV set, and you may need to change some parts, clean some connector contacts and/or tweak settings inside the set, so remember the original settings before you tweak them...
Good luck
3rq8 (Triarcuate)
Jul 23, 2009 | Televison & Video
Sony trinitron tv kv type
The screen voltage adjustment should be on the back of the high voltage multiplier. It should be marked as "Screen", or "G2". Next to it, is the "Focus" adjustment.
Some models of Sony sets have two focus adjustments. This is for H and V focus.
When increasing the screen voltage will usually increase the wear factor of the electron-gun assembly in the CRT. This is because it is increasing the screen bias current.
When increasing the screen bias, the brightness will increase a little. When the CRT is weak, this may produce visible retrace lines more so than on a good working CRT. This is because the excessive screen current will stop allowing the electron-gun assembly to work at its proper cut-off level in order to allow the blanking drive to bias it off during the retrace period.
Increasing the screen bias will usually cause a shift in the colour temperature especially in the low level gray colours. This is because the AKG reference for the electron-gun biases will be offset due to the differences in the electron gun performance characteristics change.
Jerry G.
May 03, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Screen
bright green with retrace lines in it?
if so the Green is running wide open and is hard on everything,
could be bad green CRT, video out short problem.. thats about it.
if low brightness ...... video trouble.
Jan 23, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Retrace line on monitor
To prevent serious damage and extend the life of your monitor you need to adjust the main brigthness control of it. it is of the LOPT/Flyback transformer inside of your monitor!
check also for cold SOLDER joints on the main pcb and also on the crt neck Board.
Nov 16, 2007 | Sony STYLEPRO CPD-E540 (Gray) 21 in.CRT...
JVC AV-27230 27" TV Logo
124 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
