Door mechanism broken
Can someone point me the direction of someone who can repair this?
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
F22 flashing on hot point washing machine
Google it this is not the hotpoint website .
Jan 06, 2017 | Washing Machines
My passenger door on my 1992 dodge van 250 wont open from inside or outside
Since neither the inside nor outside handles will open the door, it sounds like one of two thing may have happened. Either the push-rod to the lock mechanism or the push-rod to the door-latch mechanism has been damaged or disconnected. The only way to really tell is to perform some exploratory surgery. You will most likely have to remove the interior door panel and inspect all of the push-rods and linkages to find the broken link. Hope this gets you pointed in the right direction.
Nov 02, 2013 | 1992-1994 Dodge Van B250 Distributor Rotor...
The climate control on passanger side is broken and blows hot air and I cannot cool the vehicle. I'm sure it's something I can easily fix for now if someone can point me in the right direction
likely either a linkage heater air actuated door may also be vaccumed controled seek manual for air ducting for your model.likely vaccum actuated switch.
Jun 05, 2011 | 2004 Hummer H2
My driver side door wont open from the outside but will open from the inside. How do i fix this
Well first remove the door panel then look for a link that joins the lock to the door handle, you will probably find that the clip that holds it on has broken.
May 02, 2011 | 2003 Isuzu Rodeo Sport
Technik tkl9260 and the drum is solid.
I depends on your degree of electro-mechanical experience, Yes it is a repair some owners can do themselves, Locate an assembly and/or parts diagram.
The most frustrating and difficult part of the repair is resetting the tensioner pulley on the drum belt. If you are lucky you have a gear or direct drive. Look for broken support rollers or a roller whose axle bolt has become dislodged.
Sep 17, 2017 | Washing Machines
Door locking mechanism keeps breaking
just and idea,,,put a little flat rubber or cushion pad between the door and the panel so door dont close so hard,,and tight,,,onthejob
Jan 16, 2009 | Kenmore Elite 45986 Front Load Washer
1-866-925-PART (7278)
Apr 29, 2008 | Panasonic PV-DF2735 27 in. TV/VCR/DVD...
Plate stops turning
I would initially suspect a bad door switch or broken door switch mount, but if you can't turn the turntable motor by firmly grasping the couler, then it may be a broken coupler or motor. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: You can find helpful exploded view diagrams and order parts by entering your model number here: If you still need help, feel free to contact me directly or reply here.
May 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
