Question about Platypus Big Zip Sl 2.0L Reservoir 70 Fl. Oz
I don't Know how to unzip platypus big zip sl 2l
Live update don't work with control center together
Hello you can download the drivers here:
http://www.msi.com/product/mb/760GM-P23--FX-.html#/?div=Driver&os=XP%2032
Click on the zip file for download
Please unzip before you install
I am sorry to tell you that liveupdate has not worked for a long time.
You have to download the files manualy.
Good luck
Oct 28, 2012 | Computers & Internet
How to download this kind of webcam
To install a webcam, it's best to have its updated drivers, if it doesn't come with them already. You can go here to download the latest driver for the A4tech PK-635 Webcam
http://www.a4tech.com/download%20driver.asp?cmodnum=pk-635m
Keep in mind, all PC downloads are in .ZIP format. If you don't have a program that can unzip .ZIP files, go here and download Winzip for free.
http://download.winzip.com/winzip81.exe
May 22, 2012 | A4tech PK-635 Webcam
The driver don't find the VIA chipset on motherboard, what can i do?
Hi, you can download the drivers and a manual here:
http://www.asus.com/Motherboards/AMD_Socket_A/A7V600X/#download
Please select your operating system.
Select the driver and click on global for download.
The driver needs to be unziped before installation.
Here is a free unzip program:
http://www.7-zip.org/download.html
Click on the exe file for download.
Hope this will help you.
Aug 23, 2011 | ASUS X Series A7V600-X Socket A KT600...
I need to sound card driver
Hi, you can download the driver here at asus:
http://www.asus.com/Motherboards/Intel_Socket_775/P5VD2MX/#download
Select first your operating system 32 or 64 bit.
Then select audio and click on global for download.
The file needs to be unziped before installation.
When unziped choose the installation program or exe file.
You may need to restart after this.
Just click on the exe file for download.
Aug 18, 2011 | ASUS P5VD2-MX Motherboard
I don't have the driver for the multimedia audio controller.
http://www.asus.com/Motherboards/Intel_Socket_775/P5P800VM/#download
This is the driver for windows xp if you are running another
operating system just select it in os.
Select audio and select global and download the driver.
Right click and choose unzip here.
Just click on the exe file and download.
Hope this was helpfull.
Aug 14, 2011 | ASUS P5P800-VM Motherboard
Hi, Thanks for the prompt service in sending me the download for the driver I requested. I have downloaded the zip file but it has alot of files contained in it and I don't know what to do now to...
UNZIP all the files into one folder.
Look into the folder, for 'install.exe' or 'setup.exe' or 'readme.txt'.
If there is a 'readme.txt' file, then open it and read its contents.
If there is an 'install.exe' (or 'setup.exe') file, double-click on it, to run the "Installer" program.
Jul 25, 2011 | Samsung N150 Netbook
I don't have installation cd of lexmark x2450. how can i do it to install?
Any drivers you need can be found on the lexmark website. Note that some printers need the software installed before hooking up the printer. I'd try to install the printer first. The software will tell you if the printer needs to be connected.
Jun 13, 2011 | Lexmark Computers & Internet
Philips Semiconductors SAA7134HL Multimedia Capture Device driver
I have found solution to your problem.
Just download the above file , Unzip and locate your device to the zip files.
That's it. done.
Philips Capture Device Driver SAA7134
Don't forger to rate the solution.
Jan 09, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
Download Drivers
You can download the free program 7-zip from:
to unzip the file.  Once the file is unzipped, just run the setup.exe and it should install the drivers.
Nov 07, 2008 | Canon imageCLASS MF3240 All-In-One Laser...
Platypus Big Zip Sl 2.0L Reservoir 70 Fl. Oz Logo
94 people viewed this question
Top Platypus Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Platypus Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
