Question about HP Compaq nc6000 Notebook
Computer bios how to I check the computer bios to see if wireless has been disabled
  • Femi Williams
    Femi Williams May 11, 2010
    I have the same problem too, I see the Wireless network off on the BIOS, but I don't know how to disable it, Anyone that has a solution to this should please reach/contact me on wilfem2002@yahoo.com Thanks.
  • 3,940 Answers
Most systems today you can enter the BIOS with pressing F2 at boot. Some use F1, F10 or Del to enter setup (It should be on the screen at boot which key to enter setup) Once in BIOS navigate to the wireless device and see if it is Enabled
You can also look at the Function Keys, as most portables have a Fn + functin key combination to enable wireless (look for a radio tower Icon on a Fn Key, With Dell it is Fn+F2 not sure on HPs)
Posted on Jan 26, 2009
How do I know which realtek product to reinstall on my windows7 pc as it has dissapeared
via the bios number that comes up on the screen at boot up. If integrated on motherboard. search the bios number with the words wireless driver .check if there is an air plane mode on the wireless first ! go to control panel under settings and look for device manager and see if wireless device is disabled or set to aeroplane mode.
Oct 28, 2014 | Realtek Semiconductor Computers & Internet
My wireless wont turn on with the Fn and F2 key.It was recently formated so i dnt knw if thats the problem
If your computer was formatted then may be a posiibility it doesnt have the drivers for the wireless card. Or may be its disabled from BIOS.
Fisrt make sure drivers are installed else you need to install drivers from dell CD or get it from dell website http://support.dell.com
To check BIOS settings.... Turn off computer Turn on and hit F2 to enter BIOS setup Find if Wireless switch is disabled Enable it incase its disabled or set it to default. Save and exit restart computer....it should be working now.
Jun 22, 2011 | Dell Inspiron E1505 Notebook
LENOVO C200 (3000 SERIES) Radio is disabled. The switch at the front & the Fn5 keys dont work. pl help!
1. Turn on the computer; then, while the initial screen is displayed, press the Lenovo CareSM button. The Rescue and Recovery screen opens. 2. Enter into BIOS SETUP with F9 on start up or Click Access BIOS. The System Restart Required window is displayed. 3. Click Yes. The computer restarts, and the BIOS Utility screen opens. 4. Check whether the wireless radio is enabled. if it is disabled make it enable.
Hope this helps to you
Jun 18, 2011 | Computers & Internet
I have a T40 IBM that just got the 1802 error. downloaded a bootable fix that I made to a CD. Set both startup and network to look for the CD drive first. Cannot get past the double beep on the POST test...
To correct this issue, you will need to remove the PCI wireless card from your laptop or disable the mini PCI settings in the BIOS menu.
On IBM's, the Mini PCI card slot is usually at the back of computer.
After removing card or disabling the
mini PCI settings in the BIOS menu, boot your computer. Make sure to update your BIOS. The new BIOS version can be downloaded from the manufacturer's website.
(http://www-307.ibm.com/pc/support/site.wss/MIGR-51708.html).
This issue has been corrected in the latests BIOS updates released.
After updating the BIOS, you can reseat the PCI Wireless card or enable the mini PCI settings in the BIOS menu.
Note that once you have removed the wireless card, you will not have wireless connection until you update the bios and replace it.
Hope this helps.
May 19, 2011 | IBM ThinkPad R40 2722 Notebook
My Pc bluetooth is not detecting my Nokia 2730 mobile but when i use an externel bluetooth device it connects easily
Chances are your Bluetooth is disabled in BIOS.
  • Make sure the computer is turned off.
  • Press the ON button.
  • Immediately press the F2 key.
  • This should get you into BIOS config page.
  • Highlight the "Wireless" option & press space.
  • Highlight the "Wireless Devices" option.
  • In the top right side of your screen you should have a check-box labeled "Enable Internal Bluetooth".
  • Make sure this is checked (not empty).
  • Chose the EXIT button (bottom right).
  • The computer will reboot.
  • Try connecting your Bluetooth device again.
Hope this helps.
Jan 25, 2011 | Dell Vostro 1015 Laptop
My wireless lan device remains disabled although i have enabled it from BIOS? sometimes it powers on when i turn the wireless button on but goes disabled after a while
you dont have to enable it from bios. if its disabled, do a bios default and check if it works.. if not then u can mail me at L2support.hp@gmail.com
May 06, 2010 | HP Compaq nc6220 Notebook
Wireless button showing amber, but wont change when pressed
WIRELESS NETWORK BUTTON FIX FROM RED TO BLUE. 1. Press wireless button. 2. left click the dialog box in the bottom right corner it will prob say wireless disabled etc. 3. HP wireless assist box should open if so its working and you should click on properties. 4. check all unchecked boxes and press apply or ok etc.5 you should now see in the top right corner of the HP wireless assist box an option to turn on wifi press it. 6. Try the wifi button it should work! If not sorry it did for me.
Apr 15, 2010 | Compaq Presario CQ60-220US PC Laptop
Disable internal wireless network card
Well I would access the BIOS on his laptop and do 2 things. 1) Enable a BIOS password and set it. 2) If the laptop has a BIOS controllable wireless setting , disable it. But this will disable the wireless TOTALLY.
Otherwise you need talk to your neighbor and have them set a security on their wireless router.
Dec 09, 2008 | Computers & Internet
Wireless Button Disabled
After one month of trying everything, I finally figured this one out.  First turn off and restart your computer.  Then press F10 to enter the System BIOS Settings.  Select F9 (Setup Defaults) and when it asks Load Default Configuration Now? , Enter YES.  Then, press F10 (Save and Exit) and when it asks Save Configuration Changes And Exit Now, Enter YES.  This should restore the wireless LAN button to its original factory settings.  Once you restart the computer the button will be listed as disabled, but press on the button and it should work again.  I hope this helps someone else out!
Sep 29, 2008 | HP Pavilion dv4000 Notebook
I cannot enable the wireless connection on the compaq Evo n1000c
For the built-in wireless on this model (EVO N1000C) the key combination to enable/disable wireless is Fn + F2. If pressing the Fn and F2 keys together does not enable the wireless, it may be disabled in the BIOS.
If you need to check this, here are the instructions to enter the BIOS:
Turn off the computer. Power it on and immediately start tapping the F10 key about once per second until you see the BIOS screen.
Aug 28, 2008 | HP Compaq Evo Notebook N1000c
HP Compaq nc6000 Notebook Logo
288 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
