Question about Kenwood Excelon XR-1S Mono subwoofer amp - 700 watts RMS x 1 at 2 ohms
How do i bridge a kenwood excelon XR-1S amp - Kenwood Excelon XR-1S Mono subwoofer amp - 700 watts RMS x 1 at 2 ohms
5 Suggested Answers
zzedly
  • 300 Answers
SOURCE: Kenwood Excelon KAC-X521
According to page 7 of the radio's manual, E-02 means the amp has failed and DC is being applied to the speakers. It also says "Turn the POWER switch "OFF" and release the protection."
Posted on Mar 05, 2008
etirbynnor
  • 655 Answers
SOURCE: To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Posted on Apr 28, 2009
  • 10 Answers
SOURCE: kenwood kac9152d bridge mono wiring diagram
I have owned this amp for 2 years and i have it up to my kicker L5 sub, in a 3.1 cubic foot ported and chambered box that is tuned to 33hz. the amp can be wiried for eitherrunning one sub or several subs, rms power is 500 watt @ 4ohm, 900 watt @ 2ohm, and 1600 @ 1ohm. it is a strong amp, and it puts out large and powerfull amounts of energy, the bass remote is an added touch, i had it set to 100hz on the amp at +1 on the input sensativity, i ran my sub hard producing 138.40 db on a term lab. and i only had the remote at +9/+11 for level and set to 43hz on frequency boost, if you have only one sub with single 4ohm voice coil run it on the outer sides of the speaker outputs on the amp, if you have a dual or quad voice coil, you can either lower the ohms wiring the sub in a paralelle circuit, or up the ohms by wiring the sub in a series circuit. if you have 2 or more subs, wire them left and right channel, the amp has 2 out puts because it is a dual monular amplifier, meaning you can link 2 or more amps together to wire one or multiple subs, witch makes this amp perfect if you have a 180db, @ 18hz **** , than this amp is for you!!!!!! if you need more advise on the amp or how much power it needs to run it or when the amp loads into protection mode feel free to email me @ zekk68@hotmail.com
Posted on May 22, 2009
  • 85 Answers
SOURCE: My kenwood excelon x1200m amp
You may have blown a fuse. There should be one on the amp itself and the other is generally installed on the main 12V power cable. Most installers put it in the engine compartment for easy access. Pull each fuse and make sure it's still intact. If not you'll need to replace it. Most auto parts stores will carry the fuse, just take the old one in to make sure you get the correct amperage.
Posted on May 02, 2011
I BROUGHT A CAR WITH A KENWOOD DDX7015 THAT ASK FOR A PASSWORD
Password protection on kenwood is very good, you might need to pick up another head unit. Also after inputing the pass code you need to hold the fast forward or skip button to activate the code. I am verry familiar with that head unit and I dont know of any end arounds to bypass the security code. Get ahold of the origional owner and get their passcode or replace the headunit.
Dec 31, 2014 | Kenwood Excelon DDX-7015 Car DVD Player
I have two 12 inch 1200 watt kenwood excelons and i want to bridge them to the amp but i can barely turn it up with out blowing fuses
Please check the impedance of those subs. Are they 4 or 8 ohm speakers? Do they have dual voice coils? this app may not be capable of handling dual voice coil four ohms and you're trying to bring it down to a 2 ohm mono.
Dec 19, 2013 | Kenwood KAC-7201 Car Audio Amplifier
I have a kenwood excelon xr-4s amplifier and in channel 1 and 2 i have front speakers, in 3 and 4 i have a infinity kappa doble coil 4ohm each coil. When i turn it on loud it shut down the amp and start on...
Since you have two dual 4 ohm voice coil subs, hopefully you had one sub wired in parallel to each channel separately (one sub on 3, one sub on 4). That way, each channel gets 2 ohms. If you have both subs bridged across channels 3 and 4 (left + and right -) then you have applied a 1 ohm load to your amp, which would cause the problem you're having. It's possible the amp has been damaged, but the fuses on the amp should have blown to protect the amp. Check your sub wiring to make sure you don't have a 1 ohm load bridged across channels 3 and 4. Also check the fuses on the amp itself to make sure neither of them have blown. If everything is fine there, check your fuse under the hood that's connected to your battery. That fuse could have also blown.
Nov 14, 2017 | Car Audio & Video
Kenwood x1200m
this amp is 1 ohm stable and a monoblock which means there is only one channel in the amp so if you run both subs parallel at 2 ohms and parallel them together you will be at 1 ohm which this amp will handle excellently. i know this because i have it and have been running it at 1 ohm for the past 2 years with no problems.
Mar 01, 2012 | Kenwood eXcelon X1200M Car Amp
Kenwoodxw1000f shut off after 10 sec
the problem sounds like your new sub is drawing to much power and your amp can not handle it. bridging the amp is a good way to get the full power out of your amp. But it isnt always suggested, my solution is to get a bigger amp. I install stereo systems for a living, and i tell my customers that it is smart to get an amp about 100 more watts then the rms rating of your subwoofer.
Feb 13, 2010 | Kenwood eXcelon KFC-XW1000F Car Subwoofer
VIDEO DISPLAY PROBLEM FROM SHARP XR-1S LCD PROJECTOR
make sure the resolutions match. change it on the projector.
Mar 30, 2009 | Sharp Notevision XR-1S Slide Projector
The amp is only putting out on 1 channel
I do believe this is caused by one of your amp fuses. Depending on which + on the amp is being used. That channel has a blown fuse. have you tried running + and -, + and - to both channels to see if both subs worked? If one sub doesn't then it's a blown fuse or scarred fuse and needs to be changed.
Feb 10, 2009 | Kenwood Excelon KAC-X521 Car Audio...
Sharp XR-1S Projector
you'd be better off hooking the dvd up to an amp and run speakers off of that.
Jul 17, 2008 | Sharp XR-1S Multimedia Projector
Kenwood Excelon XR-1S Mono subwoofer amp - 700 watts RMS x 1 at 2 ohms Logo
77 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
