Question about Maytag MMV5207AAS Microwave Oven
Microwave not heating food
The microwave is louder than usual and not heating up items.
    Novelist:
  • 140 Answers
The problem you are having with your microwave is a common one. Not heating is a problem that can be caused by three things. I'll list the most common solution first, the magnetron that actually does the heating is what is making that noise and has gone bad. It is possible for you to also have a bad high voltage diode that has opened up, solution two, or solution three is the high voltage capacitor is not working properly as well. From my experience with microwaves I am positive that it is your magnetron that is bad. If you are not do it yourselfer you'll need to take it to a repair shop to replace. However, if you know how to use a screwdriver and can unplug a couple of wires with spade terminals on them, then you can take it off yourself, find another one and replace it the same way you took it off. The magnetron sits behind the control panel of your microwave but on top. It has cooling fins on it and has 2 terminals maybe three depending and make and model that plug into it. It has 4 screws that are easy to get to that actually holds it in place. If you do not have a good local source like an electronic parts supply place then you can find the right magnetron at www.mwoparts.com. Be sure you always unplug the microwave before touching or trying to take the he cover off and then when you take the magnetron off also.Good luck and God bless.
Posted on Jan 26, 2009
  • HariGB Jan 09, 2011
    If the microwave appears to be working normally (ie: light comes on; timer counts correcting, turntable turns) but there is no heating of the food, it could also be your high voltage fuse - normally 5kv 700mA or 0.7A. Check and if found faulty replace with same specification component.
Everything is working except the food,and beverages are not heating up,and there is a noise. The thing that really bothers me is : when I touch the outside of the microwave its warm.Could it be whats already posted tht magnetron.Should I be afraid of the warmth of the microwave? Thank You:0 Ann
Posted on Oct 21, 2011
How do I get the heat to work?
Hi Marc, there is no 'heat' per say with microwave ovens as one would find in a convection oven. Microwave ovens operate by generating electromagnetic fields (within the microwave band) that causes water molecules in the food item to vibrate/rotate creating friction/heat - within the food item as opposed to the surrounding space (this would be convection)
Oct 26, 2014 | Oster Microwave Ovens
G.E. spacemaker microwave stopped heating,made louder than normal sound,smelled odd.
The magnetron has failed, "heats food" to repair the unit will approach the cost of a new microwave oven.
May 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-340H Microwave has power but does not heat food. Carousel working.
The magnetron is the likely problem, "heats food" the other two items to check is the high voltage capacitor and diode. It usually is cheaper to replace.
Apr 06, 2011 | Sharp Microwave Ovens
My microwave is not heating up food. Everything else still works, but it is louder than usual. Lights, timer, fan, etc all work, the food is just not getting hot. It is about 4 years old.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 11, 2010 | GE XL1800 1100 Watts Microwave Oven
Unit is about 3 years old. Making a louder noise than usual and not heating the food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101/../
Jul 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our microwave (GE) not longer heats food items.
Microwave Oven Basic Troubleshooting Tips
heatman101
r
Sep 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Won't Heat Food
My Kenmore 721.63259301 would not heat items up so I came here and saw the parts required and was just about to order them when I checked the online owners manual and found this. FULL FIVE-YEAR WARRANTY ON
THE MAGNETRON For five years from the date of purchase, if the
magnetron in this Kenmore microwave oven
fails due to a defect in material or workmanship,
Sears will repair it free of charge.
My microwave has a manufacture date of July 2009 so I will be taking it right to the closest Sears repair center for a free repair. I suggest everyone do the same.
Aug 18, 2009 | Kenmore 63792 Microwave Oven
Microwave works but is not heating up food
can you hear the magnetron operate i.e. light dims,transformer has a louder hum,if so more than likely either the H.v. diode or H.V. capacitor is bad or worst case scenario the mag tube has failed.....costly
Jul 18, 2009 | Microwave Ovens
Turns on but not heating food sounds a bit louder
Hi, this is common in most microwaves. this abnormal noise is coming from a faulty Magnetron. this device is responsible for the heating process and, it is damaged and not heating at all at this point.Simply replace the Magnetron and, this unit will start to heat once more.
May 31, 2009 | GE Profile Spacemaker Over-the-Range...
GE Spacemaker Microwave, Model J VM1650AB5 Not heating food
If you sure that lauder sound comes from turntable motor than it needs to be replace.
Nov 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag MMV5207AAS Microwave Oven Logo
15,963 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
