Question about Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer
Maytag neptune super stack mle2000ayw
Washer wont drain water, can hear it spining
  • 1294 Answers
SOURCE: i have a maytag neptune washer the water will not drain out of it
First drain as much water from the drum as possible and unplug from the outlet. Then there are 2 screws left and right under the front lower panel at floor level. Undo those two screws. Pry the front panel DOWN from the door panel. Once the lower panel is removed you will see the pump and pump filter on your right. The pump filter is to the left. It has a large turnscrew. Be ready with a pan or something to catch the water from the open filter! Screw this counterclockwise until it comes loose. You will now be able to remove the filter and all the debris. After cleaning, re-screw the turnscrew. Before you put back the front panel test that it is clear by doing a wash. If it still doesnt drain you must remove debris from the pump itself. The pump is between the pump filter and the pump motor on the right. Undo the white clips from the motor and the retaing clips attiching the filter to the metal washer body. Then turn the motor clockwise to separate it from the filter. Refit carefully after job is done. And fit outlet tube a correct height, not too deep. <courtesy tzotsi>
Posted on Mar 10, 2009
SOURCE: my maytag front loader will not drain water oe comes on the control panel
On the 9700s it's even easier - three screws on the front bottom panel below the door, then use your hand to unscrew the large round handle in the front center. When you can't unscrew any more, pull gently and the filter / catcher will come out.
It's amazing how much stuff mine held - 4 breastfeeding shields, a pencil, a pen, a fake mouse, and lots of grey gunk.
Screw it back in, put the panel back on, and you're in business.
Posted on May 04, 2009
SOURCE: will drain but wont spin
I just had exactly the same problem. It turns out that the washer thought it was "continuously out of balance" because the inertial unbalance switch was not working properly. The way I fixed it was:
1. I followed the instructions to disassemble the Neptune washer found here: http://www.neptunehelp.com/index_files/Page323.htm and then in the control panel on top I found actually a very useful document stored in the control panel itself. It is called "Schematic Mini-manual LED Washer" and it contains a set of schematics for the electrical system and an explanation on how to run various diagnostics on the washer. This was incredibly helpful.
2. I checked the diagnostic code using the following procedure:
a. Plug the washer in for power.
b. Put the washer into "Service Mode" by holding the "Delicates" and "Heavy soil" keys simultaneously for 3 or more seconds. My washer showed a "00" on the screen when it was in Service Mode.
c. Pushed "Presoak" to put it in diagnostic code mode.
d. Pushed the down arrow key to read out the last diagnostic code. In my case the most recent diagnostic code was a "05", which the mini-manual says means "Continuous unbalanced circuit". In fact the mini-manual also says to "Check for: Faulty unbalance switches, Loose wire connections, Bad control board".
e. To find out how many cycles ago this happened, you can push the "Cotton/sturdy" button and it will tell you how many cycles ago this happened. I can't remember the response of my washer, but it either showed a "00" or "01".
To double check the diagnostic code, I
a. Cleared the list of diagnostic codes by holding the "Heavy soil" and "Presoak" buttons for 3 seconds while in the "Diagnostic code" mode;
b. Put the washer door back on and screwed it in without putting the entire front back on the washer.
c. Pushed the "off" button or unplug the washer and plug it back in to get it out of "Service mode".
c. Ran just the spin cycle, where it counted down to 7 and then was perfectly silent and then displayed a "00" without really trying to spin.
Double checking the diagnostic code probably wasnt' really needed, but I thought I would try it just to make sure. I did receive the "05" diagnostic code again.
3. With the washer unplugged again, I did the following to check that the switches were the problem, I checked the resistance of the circuit that has the following three switches in it: the inertial unbalance switch, the low tub displacement switch, and the upper tub displacement switch. If the circuit has effectively "0" Ohms of resistance, the switches are good. If you effectively have "infinite" resistance, then one of the switches is bad.
The mini-manual shows you where the switches are physically on the washer. The easiest way to check this is to find a connector that connects the three switches to the control panel. I found this by lifting the top panel of the washer up all of the way so I could access the top of the washer's tub. Based on the schematic from the mini-manual, the in-line connector has four wires. One side you will find a red wire with the number "23" on it and an orange wire with the number "40" on it. The other half of the connector has two blue wires connected to it, one with the number "23" on it and one with the number "40" on it. In my washer, this connector was placed on top of the washer toward the back.
To test to see if one of the switches is not working:
a. Disconnect the inline connector described above.
b. Test the resistance between the two terminals on the side of the connector having the two blue wires. I found that when I did this I had infinite resistance, so want of the switches was stuck open, indicating the "unbalanced " condition.
To find which switch was at fault, I disconnected each switch from the circuit and tested each one individually. The one that was easiest to get to was the lower tub displacement switch, which is in the front on the bottom of the washer's tub. It worked fine (0 Ohms resistance normally and infinite resistance when you push the button). The next I tried was the inertial unbalance switch, which is placed on the top, right, front of the tub just underneath the block of concrete that is mounted on the tub. For convenience, I removed the concrete block so I could easily access and remove the switch.
This was the switch with the problem (it was effectively stuck open or infinite resistance). It seems to have some rod of metal in it that moves back and forth with the washers motion, so I just shook it vigorously and you could hear the rod of metal move back and forth. This seemed to free up the switch mechanism and the switch functioned again (showed "0" ohms when it was held in about the same position as it would be on the washer). I put the switch back in place and checked the connector with the blue wires leading to all three switches as before. This time I received effectively "0" Ohms, meaning that the problem was fixed.
4. At this point, I put everything back together again (concrete block, reconnected the in-line connector to the switches, and reversed the procedure found in http://www.neptunehelp.com/index_files/Page323.htm ).
Once everything was back together again, I tested just a "spin" cycle and everything worked. You could also test this before putting things back together (probably a good idea) by temporarily putting the door on properly and trying a "spin" cycle.
Another thing to note, you could actually check the diagnostic codes and run several of the tests without taking the entire washer apart. Basically, all you need to do is get the mini-manual out of the control panel (I there are 6 screws total I took off) and run the tests before opening the rest of the washer.
In the end, it might be good to clean or lubricate the inertial unbalance switch or replace it since it will probably stick again. Unfortunately, I am not sure how it is built, so I am not sure what the best way to clean or lubricate it is. Just shaking it for the moment did the trick.
Hope this helps.
Posted on Aug 22, 2009
hh0405
  • 77 Answers
SOURCE: why isn't the maytag neptune draining? when you
if you do not see water in the tube and the clothes have spun out enough to go into the dryer when the washer cycle finishes the washer has drained out all of the water the water you hear in the tub when the door is open and you spin the tub with your hand that liquid is in the sealed balance ring , that is a sealed channel around the front of the tub to help the machine stay balanced it does not come out
Posted on Apr 04, 2010
ginko
  • 19396 Answers
SOURCE: I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Posted on Jun 13, 2010
Maytag Stack MLE2000AYW Washer Timer Won't Advance
If manually turning the timer allows it to spin and drain, then I would say the used timer installed was also defective. Try a new timer. You will save money if you get it online or go to an appliance parts store like "Mid-America Appliance" rather than Sears or the likes. Hope this helps.
Jul 06, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
Our Maytag stacking washer/dryer, MLE2000AYW, has generally worked well. Recently there is water in the washer after the clean clothes have been removed. The water can be removed by adding a spin cy
The intake valve may have debris under the plunger allowing the water to bypass the valve. If it fills up when not in use it is a sure sign of this. However, your issue sounds more like a clogged filter allowing drain water back in the drum after the cycle has ended
May 19, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
I maytag neptune stacked washer and dryer model # mle2000ayw just recently the dryer started to act up it doesnt wanna dry the cloths all the way so we have to put it over again !! sometimes 3x ...
hi gar.... sounds like your dryer vent pipe or outdoor vent is partially clogged with debris. thoroughly clean it out and it will work great once again. Joe
Jun 17, 2011 | Maytag Neptune MLG2000A Front Load Stacked...
Holds water wont compleatly drain shuts down before spine cycle
Hello
If the washer shuts down before spin cycle it indicates that it is unable to drain properly. Please check the drain hose/drain pump filter for any clogs/blockages and try cleaning them to solve this problem. Also after cleaning check if the pump is working fine.
Kevin
Nov 10, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
Replace wax motor on neptune stacked w/d
I just recently purchased a used Maytag MLE2000AYW Stacked washer/dryer. The problem I am having is that the washer unit seems to turn on, the lights go on, fills with water, but doesn't not engage in the wash or spin cylce. There also seem to be a kind of intermittent spinning sound every five seconds or so when it is in the wash cylcle. Can anybody give me some ideas to troubleshoot for?
Mar 31, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
My Maytag Front load stack unit washer/dryer model # MLE2000AYW
I had a similar problem, My washer spun but the clothes were still soaked with water. We replaced the inertia switch. That solved it.
Dec 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Water wont drain all the way
I have the same problem and am trying to get it fixed. You can find good info here: http://www.applianceguru.com/
Search for the model name and number of you appliance. Good luck!
Aug 24, 2008 | Maytag MLE2000 Front Load Stacked Washer /...
Maytag Neptune stacked front load MLE2000AYW
I'm trying to remove the top cover in order to relace one of the fins inside the drum. The screws came loose and let go. I'm struggling to get the top off. Which screws in the from need removed to release the front? Thanks.
Jul 13, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer Logo
48 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
