Question about Whirlpool GH4155XP Microwave Oven
Handle screw broken
Handle came off, one of the two screws that keep the handle attached to the door is broken. I don't know if I need to repalce the entire handle or just the screws, where can I get the required parts, and how can I fix them back in there. On visual inspection, I am not seeing any apparrent way to take out the two screws from the door and put the new ones back in there.
Please advise.
    Problem Solver:
  • 11 Answers
You have to take the trim off the in side of the door around the glass. Be careful, because the glass could fall out. You should be able to open it with a regular flathead screw driver. There is probably 4 screws holding the handle on. I am pretty sure the only way to get the part is through whirlpool.
Posted on Jan 28, 2009
My samsung SMH7187STG microwave handle broke off.
You can order new "cap handles" (the plastic parts that join the aluminum handle to the door for 3.99 each plus 8.99 shipping and handling at the Sears Parts Direct Website. The part number is DE67-00222C. When you have the parts in hand, open the microwave oven door. On the inside surface of the door their is a black plastic frame around the door that pops off easily (gently use a screw driver to pry up the door frame) so that you can have access to the screws that attach the end caps to the door. You will need to hold the remant of the cap handle (the part that is probably broken off even with the glass surface on the outside side of the door) still while you unscrew the screws. Once the screws and broken remnant of the handle caps are out, you are ready to put new handle caps on the handle, then put the handle with the new handle caps on the door. By the way, Samsung was absolutely NO help with this. The agent I chatted with denied that their were any reports of the handles breaking off, so I had to cut and past the postings about the door handle breaking off ON THEIR OWN WEBSITE under "Community Q and A" into the chat box -- still the agent did not acknowldege the existance of these reports...or the possibility of a poor design. I asked for them to send me a couple of the $4 parts as a good will gesture....got nothing but lofty words about Samsung commitment etc. and only a authorized technition blah blah, no action. All you need is a strong thumbnail, a phillips head screw driver, new handle caps.
May 02, 2010 | Samsung 1.8 Cu. Ft. Over-the-Range...
GE profile mirowave JVM1350WW002. Handle broken
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Oct 10, 2009 | GE Profile Spacemaker Over-the-Range...
Door Handle snapped off
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 09, 2009 | Maytag MMV5165 Microwave Oven
How to replace the door handle on a GE, JVM1490SD 003 microwave?
around the door you will see a plastic cover strip. gently pry it off and under there you will find the screws to open up the door and get to the door handle screws. you dont have to worry about breaching the seal.
Aug 13, 2009 | GE JVM1490 Convection/Microwave Oven
The bottom of the door handle broke off. GE spacemaker xl
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Repalce Door handle on GE Profile model number SCA1000DBB03
There're some half a dozen or so small screws securing that frame to the door face. These screws must be removed. Then, the frame can be pried out by releasing the plastic snappers (with a flat screwdriver) while in the same time gently helping the frame to detach from these snappers' hold and the door face. It's a tidious, somewhat annoying task. The snappers may and will even likely break in the process, but aren't needed for the frame to be resecured to the door face after the handle is replaced. Note that the broken ends of the handle must be held with a pair of pliers or a flat screwdriver needs to be inserted bewteen each of them and the hole, or the ends will turn with the screws. This is because the metal screws' grip of the plastic handle broken ends is very strong and will otherwise won't get separated.Once the above is accomplished, reassembling the door is a brease.
P.S.: The dual end latch may interfere somewhat with the job and can be removed for the prtocess to be undertaken without it disturbing. It's easy to remove and replace that latch, including its spring.
Nov 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Handle broke and can't screw in the bottom screw of the new handle
bottom plate of the handle has a keyhole shape in the door-face of it
to go over a mushroom headed screw already secured in the door
tap the old broken handle down the door and it will pop off the screwhead
then
set the new handle sideways on the door, top end out into empty space, and pull it into place on the screw head,
rotate the handle top over the door and screw it into place, dont flex the handle much to twist it in place, they are brittle, and break
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replacement of Door handle
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Sep 05, 2008 | Whirlpool MH1150XM Convection/Microwave...
The handle broke on a stainless steel whirlpool microwave
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 05, 2008 | Microwave Ovens
Another broken handle
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
May 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool GH4155XP Microwave Oven Logo
167 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
