Question about InFocus ScreenPlay 4805 Multimedia Projector
My Infocus 4805 suddenly blackout
I was watching a movie on my Infocus 4805 and suddenly it became dim and only a white strip appear on the top part of the screen. so I turn it off and try to restart the projector, and all I could see on the screen was a short light up around 3 to 5 sec and it gone, and my lamp life is only 70 hour of usage. I personally don't think it is the lamp problem, but i suspect it is a relay that start the lamp is causing the problem. Please help me with this problem. Thank You.
First check what is the lamp you using please use lamps recomended by SONY only. That lamps might run up to 2000 hours so.......try checking your lamps and let me know.
Posted on Feb 26, 2009
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    Infocus 4805 has yellow line on the right side of the screen
    It will be the light tunnel. Apparently it is very common in the 4805. See here for how to fix it, by the way you cant get parts so its a DIY job.
    http://www.avsforum.com/avs-vb/showthread.php?p=6744737#post6744737
    Feb 21, 2010 | InFocus ScreenPlay 4805 Multimedia...
    InFocus 4805 - right 1/3 is fine, middle 1/3 dim, left very dim.
    the light tunnel is collapsing and needs replacement. the part itself is relatively inexpensive, but you have to be careful if you want to replace it yourself. it's under the colorwheel, which is delicate. when you remove the top, front, and rear panels, remove the colorwheel (which is between the lens and the lamp) and carefully set it aside. there are 2 screws holding the light tunnel bracket in place. remove them and the bracket. pull out the pieces of the tunnel (little rectangles of mirror) and replace with a new one. reverse the steps to put it back together. by the way, you can get the part from any infocus authorized service center (check the infocus website for the one closest to you). part # 306-0095-01
    Oct 14, 2009 | InFocus ScreenPlay 4805 Multimedia...
    InFocus IN24 projector picture shaking
    reset the settings to factory default and make sure the resolution matches. if it persists, replace the colorwheel.
    Feb 24, 2009 | InFocus ScreenPlay 4805 Multimedia...
    InFocus ScreenPlay 4805 Multimedia Projector Logo
    108 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
