Question about Sony Playstation 3 (PS3) Console
The PS3 will not start up although the green light is on and it accepts and ejects discs. There is no signal shown on the T.V through the HDMI cable or AV cord. It does not sound like the fan is running either.
  • 23 Answers
Im sorry,i have no solution.
Posted on Jan 26, 2009
My son put in a cleaning disc and now it will not eject, the green light comes on to start then the blue light straight after which stops the machine
It sounds like the cleaning disc might have damaged the Playstation 3's disc drive eject motor, especially if it was a disc designed to clean a regular DVD or CD player. Since the PS3 is a blu-ray system, the eye for the laser is much closer to the disc, and thus might have damaged the motor by grinding up against the disc. Unfortunately, this sounds like an issue that will have to be repaired by Sony or by a third party repair center.
Mar 16, 2011 | Sony Playstation 3 (PS3) Console
Ps3 slim 129 gb will mot eject mw2 it makes the beebing noise and the another weird noise that sounds like it is stuck and the doesnt work the games does eject from the main menu but it is still in the ps3
1. First shut down the system by flipping the power switch in the back off.
2. Hold down the eject disc button.
3. While still holding down the eject button, flip the power switch to turn back on your PS3.
4. When the green light comes on, wait a few seconds then tap the eject button a couple times. The fan will run on full power and the disc will eject.
Nov 23, 2010 | Sony Playstation 3 (PS3) Console
Playstation wont take any disc it'l eject but not insert
i have seen this before... there is a little eye inside the ps3 bluray drive that senses when a disc enters and starts turning wheels with rubber feet on them to pull the disc in. when that eye goes bad for what ever reason the only way to get it to accept discs is to force it in slightly and it will spread the acceptance arms and pull it in. if it will not eject the disc correctly then the drive has been disassembled and needs to be reseated until it function right.
the acceptance eye is fairly cheap to buy online but can be a pain to replace if you dont know what you are doing.
Mar 07, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 will light up green then yellow
1. Try turning the ps3 on and off and then hitting eject.
2. Do Not try to open up the playstation. You may do more damage than good.
3. Try to halfway insert another game, cd, or dvd into the playstation 3 and press eject.
4. Here's the one that worked for me. I slid another compact disc into the console almost all the way but still holding on to it and pushed up as I pulled the disc back out. To my suprise another disc began to slide out with it. I had no idea how many discs were actually inside the ps3, but when I hit eject the original game that was in there still would not come out, so I new something still wasn't right. I repeated the process a few more times and low and behold, I had a total count of four, aside from the game. At last, eject finally pushed hubby's NBALive out of the playstation.
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
No signal to the tv
You have to take the system apart yourself and take it out or send it in to Sony
Jul 23, 2009 | Sony Playstation 3 (PS3) Console
2 LIGHTS ON CONSTANTLY WON'T LOAD GAMES
make sure there is no disc inside first as stupid as it sounds people do do it, when you go to turn the ps3 on hold down the eject button b4 you press the power one then turn the power on whilst stil holding the eject button, if this does nothing when you turn the ps3 off hold down the power button this should reset its settings which can be the cause of no display on your tv
Jun 22, 2009 | Sony Playstation 3 (PS3) Console
Wont accept disc
Try this....after a lot of frustration and research, what i found on the internet for this problem was usless. I tried holding down the eject button for 15 seconds to reset the disc drive, still it would'nt accept the disc. As i literally picked up the phone to ring sony, as the ps3 was on standby i pressed the eject button multiple times and heard 2 beeps each time, still the system stayed on standby. After that i then tried just putting the disc in as normal as its on standby and the system booted automatically and accepted my disc. I hope this helps others, as mine now works perfectly.
(PSN ID is Burnsy333)
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
Ps3 60gb
The PS3 60 gb is going to be sent to sony for repairs. Thanks
Oct 06, 2008 | Sony PlayStation 3 40GB System
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
97 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
