Question about Fellowes P50CM Shredder
How to oil shredder - Fellowes P50CM Shredder
How do I oil the shredder
Found this that should help:
Oiling Instructions for Fellowes Shredders
Why and How Often: Regular oiling of cross-cut and micro-cut shredders is a necessary maintenance step to help keep your shredder functioning properly and prolong its life. Several factors determine how often you should oil your shredder-such as the type of paper being shred, the amount of paper being shred, and whether you shred only occasionally or continuously for long periods of time without stopping.
  • As a general rule, it is a good practice to oil your shredder each time you empty the wastebasket, or once a month.
  • Micro-cut shredders need to be oiled more frequently-ideally after every 15 minutes of use.
How To: Press and hold down the reverse button on your shredder. Put the tip of the oil bottle in the paper entry and make one or two sweeps across the cutters while gently squeezing the oil bottle. Continue to run the shredder in
reverse for another 10-15 seconds.
What to use: It is recommended that you use Fellowes Oil to oil your shredder. You may also use other oil designated for shredder use.
Do not use any oil or lubricant that is dispensed from an aerosol container.
Do not use any petroleum-based oils or lubricants. Use of such oils or lubricants will void the warranty on your shredder and could cause serious injury, as they are fire hazards when used with electronic devices.
http://shop.fellowes.com/oiling-instructions.aspx
Jul 04, 2014 | Fellowes Office Equipment & Supplies
Tip
Oiling a Shredder
Oiling your shredder maintains optimal performance. You should oil your shredder every time you empty the waste bin.
on Feb 04, 2015 | Fellowes Powershred Shredder Oil &...
What kind of oil should I use on my fellowes dm8c cross cut shredder
Staples Shredder Oil or GBC Shredder Oil usually about $12.00
Jan 15, 2013 | Fellowes DM8C Cross-Cut Shredder
My shredder squeaks when in use, does it need regular lubrication? If so, what do I use?
Visit the link below for various types of shredder oils.
http://www.factory-express.com/Shredder_Oil__Bags-2025.htm
Regular use of paper shredders creates paper dust that can dry out components, dull the blades, clog the machine and burn out the motor. However, with proper oiling and maintenance, a paper shredder can last for years.
Oiling a shredder can be accomplished using one of two quick methods. The paper method limits excess oil to the paper, reducing the chance of it splattering when you turn the machine back on. This method is more common than the second and can be used with all kinds of shredders. The paperless method may be less common, but it is just as effective at removing dust buildup from the blades of the shredder.
The Paper Method:1. Place a sheet of paper on or above a surface that will not be marred or damaged should you spill oil on it.2. Apply the oil to one side of the paper in a wide zigzag pattern across the whole face of the page to ensure sufficient coverage. Do not saturate the paper with oil.
3. Turn the shredder on and run the oiled piece of paper through the shredder. As the paper shreds, the oil that has been absorbed by the paper will lubricate the blades. The motion of the blades will distribute oil so the shredder continues to operate smoothly.
3. Feed a few more papers into the shredder to absorb residual oil from the cutting assembly. The Paperless Method:1. Set the shredder to manual mode so you can control the direction of the blades and the amount of time the blades are in motion.2. With the paper shredder turned off, squirt a solid line of oil into the paper entry lengthwise across the paper-shredder blades.
3. Start
the paper shredder in reverse, allowing it to run for 10 to 20 seconds before stopping the blades. This will evenly distribute the oil to all parts of the cutting assembly.
4. Return
the shredder to automatic mode. Then feed two or three sheets of paper into it to absorb the excess oil from the machine. Tip:
How often you should oil your paper shredder depends mostly on how much you use it. Office shredders that see heavy use every day will need to be oiled several times a week, while home machines used occasionally need be oiled only a few times a year. Cross-cut shredders will require more frequent oiling than other paper shredder varieties because they have more blades and create much more paper dust.
You can purchase a shredder lubricating oil from any major electronic or office supplies store or you can contact Royal customer service at 908-429-4357.
Feb 20, 2012 | Royal Sc120 Shredder
How to lubricate a Black & Decker Model BD-s600 paper shredder
    • 1 Turn the paper shredder off and unplug it.
    • 2 Clean out the paper shredder. Make sure the blades are free of paper bits and debris. Remove pieces of paper that are jammed around the blades.
    • 3 Spray the shredder oil through the blade opening or throat of the shredder. Spray it in a stream.
    • 4 Plug the shredder back in and switch the reverse button on. Then run it for 10 to 30 seconds in reverse to allow the blades to be saturated with shredder oil.
    • 5 Put the shredder in forward motion and let it run again to disperse the oil thoroughly to all areas of the cutting blades.
    • 6 Feed a couple pieces of paper through the blades to be shredded and absorb any extra shredding oil.
Read more: How to Lubricate Paper Shredders ' eHow.com http://www.ehow.com/how_5761042_lubricate-paper-shredders.html#ixzz1kDQGrxZ8
Jan 22, 2012 | Office Equipment & Supplies
I have the CX6 shredder, the paper get jammed in the feed,can i oil the feed?
How to Oil a Paper Shredder shredder_oil.jpg Paper Shredder OilProper shredder maintenance is required by all paper shredder manufacturers to maintain warranty coverage. Perhaps the most effective way to care for your shredder is to oil the cutting heads regularly. Why should I Oil my Paper Shredder?
The frequency of shredder oil applications is determined by a number of factors. First of all cross cut shredders must be oiled more often than strip cut shredders do. A cross cut paper shredder will require regular applications of shredder oil while a strip cut can go for a longer period of time without decreased performance. Secondly, paper shredders that are used more will need more lubrication. A paper shredder under heavy usage will need oil about once every four hours, while one under normal use will only require oil once or twice a month. Most manufacturers recommend oiling the cutters once every 30 minutes of accumulative shredding, but an easy way to remember is just to oil your paper shredder every time you change the bag. The type of material as well as amounts fed at once can also effect performance and lead to the need for oil.
Directions
You should only use specifically designed shredder oil to oil your paper shredder. This oil is designed to lubricate precision heat treated shredder cylinders, and any other lubricant or oil will void the manufacturers warranty. So don't use WD-40 or the like to oil your paper shredder.
Shredder oil can come in both liquid and aerosol varieties. However, the most common is liquid shredder oil.
The first way to oil your shredder is to spray or squirt lubricant into the opening and onto the cutting heads. The oil is packaged in a squeeze bottle and is applied directly onto the cutting head in a fine stream. This is done through the paper entry throat. Take 1-2 seconds to oil from one side of the opening to the other. Turn the machine in reverse for about 10-15 seconds to allow the oil to transfer to all parts of the cutting head. The final step is to shred a few sheets of paper to remove any excess oil.
The other, and perhaps most common, way to oil your paper shredder is illustrated in the image above. Simply spread a small amount of shredder oil onto a piece of paper in a zig-zag type motion. Make sure that you spread the oil over the entire sheet. (NOTE: you don't need to soak the paper in oil, just ensure total and even coverage.) Feed this sheet through the shredder and then operate the machine in the reverse mode for a few seconds. This will make sure the oil is dispersed throughout the shredders cutting cylinders. The final step is to shred a few sheets of paper to remove any excess oil. You may want to repeat this procedure depending on the results, and is recommended for up to three applications to be assured of thorough oiling.
You should oil your cross cut shredder on a regular basis. If you are shredding a small quantity such as only 50 sheets a week or if you are using a small shredder, then you should oil your shredder every other day. If you are shredding a large quantity such as hundreds of sheets, then oil after 30 minutes of usage or after you empty the bag.
Start oiling your paper shredder now. The shredder will run smoother, faster, and put less strain on the overall motor, gears, and bearings.
Oct 03, 2011 | Office Equipment & Supplies
Should the shredder ever be oiled? if so...where
Directions
Dec 16, 2010 | Office Equipment & Supplies
The shredder overheats. The most we can shred are
Have you put any shredder oil or a shredder oil sheet through the machine.
Shredders need oiling to keep the cutters free
Free cutters mean clean cuts and less friction
Jan 14, 2010 | Intimus 502 Shredder
How do I remove excess EXCESS oil from my shredder? It won't shred.
Asking why you should keep your shredder lubricated is no different than asking why you should change the oil in your car every 3,000 miles. Not only is proper maintenance a requirement to maintain an active warranty, but all mechanical parts need a little oil to help them turn smoothly and to keep them clean. Applying shredder oil to the cutting heads inside a shredder lubricates them so that they efficiently destroy documents sheet after sheet. Fortunately, you will find that taking good care of your shredder is less expensive, faster and easier than caring for your car.
Every time you shred a sheet of paper a fine dust made of tiny paper particles is produced. This dust collects in the cutting assembly of a paper shredder. If allowed to build up, this dust will compact until it completely blocks the smooth turning of the cutting head. Shredder oil will actually break up the compacted dust lodged in the cutting assembly, allowing the parts to move and push out the softened dust.
Shredder oil is specially formulated to eliminate oil residue on the cutting head. Other oils, like WD-40, will attract dust, further clogging the cutters. When lubricating your paper shredder, only use oil specifically designated for shredder use or risk voiding your warranty and further clogging your shredder.
The frequency with which you should oil your shredder depends on several factors: frequency of use, shredder capacity, cut size and type of paper. Your shredder will need more oil the more you use it, the more paper you shred at once and the thicker the paper is that you shred. Also, shredders with smaller shred sizes require extra oil. A 1/4" strip cut shredder used only one to two hours per week will only require a weekly oiling. A cross cut shredder, on the other hand, requires oil after every half hour of use. If you remember to oil your shredder every time you change the bag you'll be in good shape.
There are two fast, easy ways to oil a paper shredder:
The first method involves applying the oil directly to the cutting head. Shredder oil is packaged either in plastic squeeze bottles or aerosol cans, designed for easy application. No tools are required, just aim the bottle directly at the cutting head, through the paper entry point, and apply a fine stream of oil from one end of the cutter to the other. Run the machine in reverse for 10-15 seconds until the entire cutting mechanism is coated. Finally, shred a few pieces of paper to remove any excess oil from the cutters.
The alternative method requires streaming oil onto a piece of paper. Do not soak the sheet in oil, but cover it evenly from edge to edge. Shred the oiled sheet of paper and then run the shredder in reverse for 10-15 seconds to allow the oil to coat the entire cutting mechanism. Finally, shred a few sheets of paper to remove any excess oil from the cutters. In any case, run a couple of sheets of paper through the shredder after oiling to remove excess oil. procedure may be repeated up to three times to ensure proper lubrication.
If you take a few seconds once a week or every time you change your shredder bag to oil the cutting mechanism in your paper shredder, you'll maintain your warranties and keep your shredder running smoothly and efficiently document after document.
click this link directly for more detailed help
---- http://www.howtocleanstuff.net/house/appliances-and-fixtures/how-to-clean-a-shredder/ --------
thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 22, 2009 | Royal 1280MX Shredder
How to fix a stuck shredder
Go to your local hardware store, and pick up a quart of 3 in 1 oil, shredder oil or some other light weight oil. (With the shredder in the off position or unplugged). Use a couple of ounces and Pour the oil over the paper that is jammed in the shredder. Use enough oil so it saturated the jammed paper. Wait about 10 - 15 minutes so the oil really soaks into the paper. Don't go crazy with the oil, and keep in mind what goes in, must come out. If you pour too much oil in the shredder, the exess oil will drip out. Don't worry about having oil in the shredder blade, this will help lubricated the teeth, and it will actually make your shredder blades last longer.
Now try to turn your shredder on after the oil has soaked into the paper for 10-15 minutes. Hopefully, the paper that is stuck has gotten softer, and then it should pass the paper. If it still doesnt work, then, try some more oil on the paper, and then wait and then turn the shredder to the forward, and then reverse mode, and then back and forth.
Hopefully your shredder will be unclogged by this time.
Hope this helps.
Good luck.
Feb 04, 2008 | Office Equipment & Supplies
Fellowes P50CM Shredder Logo
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
