Question about Sony STR-V444ES Receiver
What can I do to get hdmi output for Sony-V444ES?
Sony STR-V444ES "Protector message"
I hate to tell you this that has been a problem wit sony amps end recievers end evan there tv,s for years allready doing that, Try giving it a good hard rapp on the side or the top of it, Sometimes that will work to reset it, If that does not work , It will have to be taken in for repair, What happens to them ,The output transsisters swell up on them, From over heating, , It is cause buy cranlking up the vollume over it,s limit,People don,t relized that with evan a good low wattage amp or reciever ,That they are putting out there maximun power at3/4 vollume allredy. End buy cranking it up over that it cuases it to over heat, The humidifryer would not becauseing that problem, Allso sony do not like haveing miss match speakers being hook up to them, Or any little change in power in your house , Makes them act up allso, End eventully wil cause a problem with it, I no you are not going to want to hear this, But what it cost to have it repaired , You can buy a decent new one , Or a very high end used reciever for, Hope this helps you out,
Nov 27, 2012 | Sony STR-V444ES Receiver
What's your problem?sony v444es 5,1 wont turn on, only clicks the relay on power board non stop
Sounds like your power transformer is bad. You might also check the power board for cracks. This model had a history of that.
Jun 21, 2012 | Sony STR-V444ES Receiver
Hi - I have a Sony V444ES receiver that I have four speakers on A (in house) and two on B (outside). I hooked up a third speaker (rock speaker) for outside use however the sound is very low compared to the...
What's a rock speaker? All you will hear with one speaker on the Rear Right output is the Rear Right channel which is typically for effects and ambience. You DO have a manual, right?
Individual speakers commonly have different responses given the same amplifier input. Where you physically place a speaker once it's electrically connected is up to you. Speakers placed outdoors might not have the sound-re-enforcement of nearby or adjacent walls as indoor speakers do so they will sound weaker.
Jul 11, 2011 | Sony STR-V444ES Receiver
Receiver str-v444es no sound on headphones or
discharge the output circuit! If you don't you will blow a 10 ohm resistor every time. I've worked on hundreds of these receivers I know. They need the output circuit soldered at the voltage driver ic's and quite possibly some capicitors replaced on the digital board. The caps mounted near the heat sinks dry up the fastest. These are nice amps. Larry's Electronics Sacramento Ca. ledstiles@hotmail.com
Apr 24, 2010 | Sony STR-V444ES Receiver
Stops working after a few mins with cd player playing
One of three things: speaker wire short, shorted/or blown speaker, or a bad output chip. First and easiest way to check is to disconnect all speakers, turn it on, turn it up, and wait. If that's ok, begin connecting one speaker at a time with the unit off, then turn on and play. When you get to the speaker or wire with the problem, it will short and go into protection. Disconnect all speaker wires again and only hook up the speaker that shorted the receiver and test. If it shorts, swap speakers with the same wire and test again. If a different speaker on the same wire causes the unit to short, replace the wire. if it doesn't, you need to test the speaker with a multimeter or disassemble if possible, check the wiring internally on the speaker. Check the impedance, should be 8ohms or 6ohms depending on the drivers. then check for resistance. If your meter says 1... it's shorted and needs to be replaced. Hope this helps
May 25, 2009 | Sony STR-V444ES Receiver
STR-V444ES just hums
Sounds like the output stage is shot.
Here are a few things to try. If there is an option in the manual to reset the unit to factory settings, try that.
If that doesn't work, disconnect all of the peripherals, and select the radio. If you get sound there, you may have a bad cable.
Beyond that I would say the amp needs repaired.
Cheeres
Jan 01, 2009 | Sony STR-V444ES Receiver
Sony Receiver STR-V444ES and Blueray
You might have to go into the players setup and select the output and audio stream options. If it is set for PCM only it will not receive the Dolby or DTS signals if you selected them in the DVDs audio selection menu. There may also be a signal select in the Sony receiver to assign the digital inputs to selected units.
Hope this helps
Cheers
May 08, 2008 | Sony STR-V444ES Receiver
Sony V444ES Receiver
Ours started doing this also now up to 20 min of clicking before it turns on.  My thought is that it is a bad power supply since once its on it works fine.
Aug 03, 2007 | Sony STR-V444ES Receiver
Sony STR-V444ES Receiver Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
