Question about Dryers
My kennmore gas dryer will not heat it spins and i turn the timer on and off and that works there is gas to the unit
    Sniper:
  • 50 Answers
Unplug dryer , remove back panel and you will see a thermo link in about the middle of the back of dryer with a vom test continuity of the link this is a very common problem . if no continuity replace thermo kink . if it tests good remove access pane in front of dryer and turn the dryer on to a heat cycle, see if the ignitor coil gets red hot. if it doesn't then the ceramic coil is bad. these are the 2 most common problems with gas dryers. if still no good write back
Posted on Jan 26, 2009
I smell gas when my gas dryer is not on and the pilot light is not lit prior to turning on; it is a 1997 series 70 kennmore
There is a leak in the gas line supplying the dryer. This is DANGEROUS and should be repaired.
S for the pilot light, is it continuously on or is there an igniter that only heats up when you start a dryer cycle?
Sep 22, 2012 | Dryers
Kennmore Elite HE4 no heat on low or extra-low setting
Assuming this is a gas dryer, it is likely the igniter has failed. The igniter plate has to heat up to glowing in order to heat up the thermocouple that turns on the gas valve.
Sep 03, 2012 | Kenmore Dryers
Dryer wont heat up just spins keeps spinning with timer set. replaced heat element and still wont dry
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
l;
Jan 03, 2011 | Roper RGX4634KQ Gas Dryer
Kennmore dryer wont heat
Your problem could be one of the following:
* thermostat
* gas coils
* radiant sensor
* gas igniter
* timer
Contact an appliance service company.
Feb 20, 2010 | Kenmore 93142 Gas Dryer
Kennmore dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
cghjhc
Feb 16, 2010 | Kenmore 73952 Gas Dryer
Tumbler spins, heat won't go on, timer won't work
It is your operating thermostat. It controls the heat and runs the timer down.
Jul 07, 2009 | GE DVL223GB Gas Dryer
Dryer will spin but won't heat up
Hi
Things that could stop a electric dryer from heating:
  • house fuse or breaker ( needs two of them )
  • heating element, burnt wire
  • thermostat(s), thermal fuse ( not all models ),
  • motor heat switch, timer, selector switch,
  • burnt power cord/plug.
You can check these things using an ohmmeter/multimeter from here.
Things that could stop a gas dryer from heating:
  • glow bar igniter,
  • thermal fuse ( not all models ),
  • coils on the gas valve, gas valve, thermostats,
  • motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 20, 2009 | Whirlpool Dryers
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer spins but does not get hot
The problem could be a faulty component such as the timer, heating glow bar, gas coils, safety or operating thermostats. First thing to do is to check the venting to make sure it is not plugged. I cover that more in detail if you wanna check it out.
http://tclaundryrepair.com/dryer
Feb 26, 2009 | KitchenAid Dryers
Kenmore Heavy Duty 80 Series Gas Dryer won't cycle/won't heat.
if you ran this unit awhile without timer advancing,,now you blew the thermal fuse,,,re place thermal fuse and timer..
Nov 27, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
Top Dryers Experts
