Question about Intel Motherboard
Motherboard getting hot
I have Gigabyte S - series, m61pne-s2 motherboard its heat sink and battery is getting hot whenever i start my computer, although i removed all the components an kept it open but still it is showing d same problem.. i have AMD phenon x3 64bit processor
  • usaad14 Jan 26, 2009
    der r no jumperz on motherboard..i checked d thermal paste its there...
  • 4 Answers
Check your thermal paste... buy thermal in the computer store, possible your thermal paste already dry and did not transfer heat at heat sink...
can you adjust your speed FSB jumper to reduce the processor speed.
Posted on Jan 26, 2009
Windows-7 hang...
Check to make sure that one is the master drive and the other a slave. Whenever you run to harddrives on a computer the configuration has to be where one is the "master" so the computer does not get confused as to which one to run.
Aug 27, 2012 | Intel Motherboard
Gigabyte GA-965GM-S2 motherboard keyboard, mouse, monitor won't work.
You need all the drivers, each peripheral has it's own driver that needs to be loaded.
Nov 28, 2011 | Gigabyte GA-965GM-S2 Motherboard
Need gigabyte s series motherboard installation disk
You can download the drivers from Gigabyte WEB support site,select your model motherboard to download :- http://www.gigabyte.com/support-downloads/support-downloads.aspx
Oct 29, 2010 | Gigabyte GA-945GCMX-S2 Motherboard
Enable to boot bootable usb drive,ga-945gzm-s2 motherboard
reset your bios inside your pc its a big watch battery take it out for 10 15 min then put back it if that does not work take out the battery again and if you see neer your battery was ther should be a small jumper its usually black and its plugged in your board it also should have 3 pins to plug it in when you take it out plug it in the next 2 pins (the miffle one will plug in aswell then put it back in the first pins again put battery back in an try to boot it should work...
Mar 30, 2010 | Gigabyte GA-945GZM-S2 Motherboard
After purchasing a new Motherboard, my computer jsut seems to power down after about 20 mins playing games on it. Other than that it is ok.
It definately sounds like a heat issue.
Did you use the thermal paste to heat sink? Make sure your fans are all running. Make sure the heat sink is snapped tight to the processor.
I would suggest a system monitor to detect heat and speed of fans.
May 23, 2009 | Gigabyte MB GIGABYTE GA-MA74GM-S2H AMD740G...
Intel Motherboard Logo
242 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
