Solution to restore terrible twosome puzzle #42716
Is there a step by step diagram to restore this to starting position
2001 Cadillac DTS wont start or turn over
Turning ignition switch to start position ! Nothing happens , no click , nothing ?
Circuit Description
Moving the ignition switch to the CRANK position sends a 12 V signal to the PCM Ignition Crank Sense. The PCM verifies that the transmission is in the PARK or NEUTRAL position. The PCM then grounds the control circuit of the START relay. When the START relay is energized it allows voltage to the starter solenoid S terminal.
Starter Solenoid Does Not Click
Turn the ignition to the START position.
Does the engine crank?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 3
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With a scan tool, observe the Crank Request Signal parameter in the PCM data list.
Does the scan tool display Yes?
YES - Go to Step 5
NO - Go to Step 4
YES - Go to Step 11
NO - Go to Range Selector Displays Incorrect Range in Automatic Transaxle - 4T80- E
5
Turn OFF the ignition.
Disconnect the Starter relay.
Connect a test lamp between the battery positive voltage of the Starter relay coil circuit and a good ground.
Does the test lamp illuminate?
YES - Go to Step 6
NO - Go to Step 19
This is troubleshooting info from GM factory service testing and repair manual .A scan tool isn't necessary , you could use a test light if you knew which pins at the PCM . For example , testing Crank Request Signal parameter in the PCM data list. Find this wire circuit at the PCM , with a test light .When turning the key to start position ,does the test light light ? A factory scan tool just cuts down the time of diagnoses . A wiring diagram is a must for diagnosing this . Free wiring diagrams can be found at
http://www.bbbind.com/free_tsb.html There are videos on youtube on basic automotive electrical trouble shooting , Control module diagnostics . That is if you don't know how to already .
Jan 01, 2017 | Cadillac Cars & Trucks
Crosswords won't load anymore on my nook
I am having the same issue with my cross word puzzles...a screen comes up saying to choose continue or restore and neither are working, the puzzles flashes on and then disappears...I too would like to know how to play the puzzles I have paid for.
Jan 17, 2013 | Astraware Limited Astraware Sudoku
I've got a Palmer twosome, it is flashing either 3
Dave I think that is an indication of a brake problem either an open coil or other issues with the brake without replacing the brake assembly the scooter will not operate sorry Contact the provider that sold you your scooter to see if he can get the part for you Hope this helps
May 07, 2011 | Health & Beauty
Bought 'Creatology Wooden Puzzle Sphinx but came with directions for building a boat. :( Googles searches get me only here. And from what I can tell, there are no answers. Please help!
I dont have a solution but i do have the same problem. Step 7 says stuff about string for sails after building a boat....?? I was okay until step 9 because the diagram didnt say where to put it.
Apr 15, 2011 | Toys
Lost my nokia 5233 security code , how can i restore my phone
*#7328748263373738# to reset security code to default.
Default security code is 12345
i hope this helpful
thank you for using fixya
Feb 07, 2011 | Nokia 5200 Cellular Phone
Wooden piece puzzle square/rectangles various sizes coloured dots
it's okay I ended up finding the instructions. thanks.
Dec 23, 2009 | Puzzle Toys
Have a Skil #3305-01 table saw. Need to set blade
The jam nut is on the end of the bolt you are adjusting, directly underneath the table. The easiest way to get to it is to place the saw on it's left side, and move the saw blade to the maximum bevel position (45 degrees). You can then reach up -directly underneath the location of the bolt on top - and access the jam nut.
To be clear - the bolt you are tightening is about 2 inches long with the jam nut on the end with the purpose of tightening the bolt into place once you have established the correct adjusted position.
And yes, the directions for this step were terrible.
Nov 03, 2009 | Saws
JANOME MEMORYCRAFT 8000 STEPPING MOTOR ERROR
if you ever have this problem, it is because you have had something in the way of the embroidery arm at the back of the machine, so it has not been able to move freely; you'll get a terrible noise as the machine is unable to do what it wants, slips gears or something and then can't bring the arm to its home position. But fear not, i have found if you turn the machine off and gently push the arm back home to touch the machine as it is the start position, when you turn it on, it will work fine and no harm done. just make sure the arm can move freely before you start embroidery!
Jul 11, 2008 | Janome Memory Craft 9000 Computerized...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
