Question about Toshiba Computers & Internet
Hard drive problem
i am having problem while opening hard disk drive by double clicking, when i am clicking on drive it's appear open with or choose any application to open it. i have visited the forum and got the solution but it does not work.
solution was...
go to registry edit- and find ctrl+F & write "mountpoints2" then delete this file.......again continuing with same until all the files will deleted. i done with the procedure but when i reboot my system, again i have face the same problem again. please guide me the about the problem and solutions.
Thank you
I only install trojan remover 7.74 then i scan may registry then i reboot then i check my drive its ok
Posted on Feb 03, 2009
I can't open because of the paSSWORD IN IT.
USB flash drives are small, convenient storage drives. Place data such as pictures, photos and text on them quickly and efficiently and then carry it to another computer for copying to its hard drive.
A USB flash drive that has security enabled in it must be 'unlocked" before it can be used, which becomes difficult if the password has been lost. Because the security on the USB flash drive is rudimentary, a number of methods, from built-in software to optional programs, can remove the security so that the drive can be used.
Plug the USB connector of the USB flash drive into a USB port on the PC. Right-click on the icon of the USB flash drive when it appears on the desktop of a Windows-based computer. Select "Format" from the pop-up menu. Follow the command prompts in the window that appears to format the USB flash drive. Click "Done" in the confirmation window when it appears. The USB flash drive can now be used because the security has been removed from its storage space. Plug the USB connector of the USB flash drive into a USB port on the Mac. Double-click on the Mac's Disk Utility program, which comes free with the OS X operating system and is in the "Utilities" folder on the hard drive. Select the icon of the USB flash drive in the left column of the Disk Utility program's main screen. Select the "Erase" tab at the top of the Disk Utility program's main screen. Click on the "Format" check box on the right side of the Disk Utility program's main screen. Select "Fat (32)" from the drop down menu below the "Format" check box. Click "Format" at the bottom of the Disk Utility program's main screen. Click "Format", again, in the confirmation box that appears. Quit the Disk Utility program when the formatting is done. The USB flash drive can now be used because the security has been removed from its storage space. Download a password protection program to the computer's desktop; for example, the free TrueCrypt password protection program (see the link Below). http://www.truecrypt.org/downloads Double-click on the icon of the password protection program when it has fully downloaded. Follow the command prompts to install the program onto the computer's hard drive. Restart the PC after the installation has been completed. Double-click on the password protection program to launch it. Wait for the password protection program to recognize the USB flash drive and display disc letters for the drives attached to the computer in the left column of its main program screen. Plug the USB connector of the USB flash drive into a USB port on the computer. Wait for a letter to appear in the left column of the password protection program's main screen. Use the mouse to click once on this letter which represents the USB flash drive. Click on the "Volume" or "Volume Tools" button to open a new window. Click on the "Next" button in the new window. Erase the password in the "Password" column of the new window that appears. Erase the password in the "Confirm password" column. Click on the "Next" button to go to a new screen. Select "Traveler Disk Setup" from the drop down menu below "Tools" at the top of the password protection screen. Click on the "Open Explorer window for mounted volume" check box in the new window that appears. Click the "Create" button at the bottom of the window. Click the "OK" button on the confirmation window when it appears. Quit the password protection program. Drag the icon of the USB flash drive to the Trash or right-click on it and select "Eject" from the pop-up menu. Remove the USB flash drive from the computer's USB port. Plug the connector of the USB flash drive back into the computer's USB port. Double-click on the icon of the USB flash drive when it appears on the desktop to open its window now that the security password has been removed. Plug the USB connector of the USB flash drive into a USB port on the PC. Go to "Start" and select "Run" from the pop-up menu. Enter "regedit" into the text column that appears and press the "enter" key to run the registry editor. Press the "Browse" button on the registry editor's main screen and navigate to the following path on the computer's hard drive: "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies" Click "OK" to close the window. Double-click on the "WriteProtect" text that is in the right column of the registry editor's main screen. Enter "O" into the "Value Data box" in the window that appears. Click on the "OK" button to close the window. Quit the registry editor program. Restart the PC. Double-click on the icon of the USB flash drive that is on the desktop to open its window and access the files now that the security write protection has been removed.
Hope this helps.
Jan 17, 2013 | SanDisk 2GB microSD Memory Card
Un lock my pasword
Which is it a 2 gb cruzer or 1000 gb ??
Plug the USB connector of the USB flash drive into a USB port on the PC. Right-click on the icon of the USB flash drive when it appears on the desktop of a Windows-based computer. Select "Format" from the pop-up menu. Follow the command prompts in the window that appears to format the USB flash drive. Click "Done" in the confirmation window when it appears. The USB flash drive can now be used because the security has been removed from its storage space. Plug the USB connector of the USB flash drive into a USB port on the Mac. Double-click on the Mac's Disk Utility program, which comes free with the OS X operating system and is in the "Utilities" folder on the hard drive. Select the icon of the USB flash drive in the left column of the Disk Utility program's main screen. Select the "Erase" tab at the top of the Disk Utility program's main screen. Click on the "Format" check box on the right side of the Disk Utility program's main screen. Select "Fat (32)" from the drop down menu below the "Format" check box. Click "Format" at the bottom of the Disk Utility program's main screen. Click "Format", again, in the confirmation box that appears. Quit the Disk Utility program when the formatting is done. The USB flash drive can now be used because the security has been removed from its storage space. Download a password protection program to the computer's desktop; for example, the free TrueCrypt password protection program (see the link in Resources). Double-click on the icon of the password protection program when it has fully downloaded. Follow the command prompts to install the program onto the computer's hard drive. Restart the PC after the installation has been completed. Double-click on the password protection program to launch it. Wait for the password protection program to recognize the USB flash drive and display disc letters for the drives attached to the computer in the left column of its main program screen. Plug the USB connector of the USB flash drive into a USB port on the computer. Wait for a letter to appear in the left column of the password protection program's main screen. Use the mouse to click once on this letter which represents the USB flash drive. Click on the "Volume" or "Volume Tools" button to open a new window. Click on the "Next" button in the new window. Erase the password in the "Password" column of the new window that appears. Erase the password in the "Confirm password" column. Click on the "Next" button to go to a new screen. Select "Traveler Disk Setup" from the drop down menu below "Tools" at the top of the password protection screen. Click on the "Open Explorer window for mounted volume" check box in the new window that appears. Click the "Create" button at the bottom of the window. Click the "OK" button on the confirmation window when it appears. Quit the password protection program. Drag the icon of the USB flash drive to the Trash or right-click on it and select "Eject" from the pop-up menu. Remove the USB flash drive from the computer's USB port. Plug the connector of the USB flash drive back into the computer's USB port. Double-click on the icon of the USB flash drive when it appears on the desktop to open its window now that the security password has been removed. Plug the USB connector of the USB flash drive into a USB port on the PC. Go to "Start" and select "Run" from the pop-up menu. Enter "regedit" into the text column that appears and press the "enter" key to run the registry editor. Press the "Browse" button on the registry editor's main screen and navigate to the following path on the computer's hard drive: "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies" Click "OK" to close the window. Double-click on the "WriteProtect" text that is in the right column of the registry editor's main screen. Enter "O" into the "Value Data box" in the window that appears. Click on the "OK" button to close the window. Quit the registry editor program. Restart the PC. Double-click on the icon of the USB flash drive that is on the desktop to open its window and access the files now that the security write protection has been removed. Hope this helps
Dec 20, 2012 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I purchased a Toshiba Canvio 3.0 500 GB portable hard drive, and plugged it into my MacBook with Mac OS X Tiger. The icon for Toshiba EXT came up on the desktop but wouldn't do anything. The box came...
1 . Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
2. Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
3.
Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
4. Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs.
  • 5. Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
  • 6. Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
    Aug 30, 2011 | Toshiba Canvio 500 GB USB 20 Portable...
    Mac G5, what is pin set up. my computer doesn't see my new hard disq WD1002FAEX
    If it is not seeing it then you will need to format it properly for Mac's most hard Drives are pre-formatted for PC's.
    You also need to make sure the SATA cable is plugged into the right place on the board.
    SATA Hard Drives do not need a pin out. Only IDE drive's have that function.
    If this is an addon drive then
  • Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
  • Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
  • Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to the Apple user's manual.
  • Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
  • Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
  • I got these instructions off ehow.com
    Jul 02, 2011 | Western Digital WD Caviar Black WD1002FAEX...
    Reformatting toshiba portable hard drive for mac, since the one i have says for windows pc
    Note: I'm assuming you have a working mac; if you don't, then post back to this solution with that information.
    1. Connect the external hard drive to your mac.
    2. Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
    3. Select the external hard drive that needs to be formatted on the left.
    4. Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
    5. Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X.
    6. Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
    7. Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
    Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
    Apr 28, 2011 | Computers & Internet
    How do I format my new WD Elements SE 500GB for Mac OS Snow Leopard
    hi.
    follow instructions below
    1> Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
    2> Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
    3> Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
    4> Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to the Apple user's manual.
    5> Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
    6> Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
    regards
    Apr 23, 2011 | Western Digital Wd Elements Se 1tb...
    Computer will not reconize external drive
    Its a comman error and can be solved according to the operating system. Follow these steps on windows.
    • Open the Start menu and click on the "Control Panel" icon.
    • Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
    • Select "Disk Management" from the list of options on left side of the window.
    • Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."Select a drive letter for the external hard drive to be recognized as and click "OK." The drive will now appear in My Computer.
    Feb 24, 2011 | Computers & Internet
    How do I reformat my Iomega eGo hard drive so that it is compatible with my Mac? OSX 10.6.6 The current IOmega format is FAT
    First of all, connect the Iomega to you mac, make sure it powers up and is detected by the Mac. Now follow these steps: ( It's important to note the Drive before you begin this task so that you may not make any mistakes.)
    • Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
    • Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to your Apple user's manual.
    Let me know if you need further help.
    Good Luck.
    Thanks for using FixYa.
    Feb 08, 2011 | Iomega 500GB eGo Helium Portable USB 2.0...
    When i try to open any drive or any other application a dialog box 'open with' appears why this happens ,how do i solve this problem?
    This is problem with registry, there is some sort of corrupt data in your registry which can be cleaned by registry repair.
    By the way you can open your drive by using explorer drop down address bar.
    Sep 11, 2009 | HP 435768-001 - Compaq Presario C300...
    Computers & Internet Logo
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
