Question about Admiral Refrigerator Temperature Control 61002085
Admiral model hmg211447 runs for long time - Admiral Refrigerator Temperature Control 61002085
My admiral washer model atw4475tq0 is having trouble spinning and i also have a admiral dryer atw4475tq0 that is making a thumping sound
washer: check clutch assembly links with instructions here https://www.youtube.com/watch?v=tVc6SZ2DD4U
dryer: check support weels (2) for a flat spot or if theyre hard to turn
Dec 11, 2014 | Admiral Washing Machines
Admiral Dryer, runs bu t does not heat
The thermostat, timer or the heating element itself are the places to check. Look at the circuit breaker for the dryer in the power panel. It will be two breakers connected together. If one trips but not both, the heating element will not heat but the dryer will run.
Nov 17, 2014 | Admiral Dryers
I don't have a model number right now, but the front door on my Admiral dishwasher is leaking at the bottom. I have changed the gasket inside the door panel at the bottom but it still leaks. This is a...
it may not be the door that is leaking if this is an older admiral or whirlpool dishwasher the lever that holds the soap door closed has a little rubber seal that after time will let water in during the wash cycle it the runs down the inside of the door and out the bottom if you rmove the in side of the door you will probably see the water trail from the wax motor down. this gasket is not expensive or hard to replace.
Mar 08, 2011 | Admiral Dishwashers
My admiral washer Model #lnc 676OB71 continues to let water run in the machine even with the cycle dial turned to off. What is going on? The lid can be closed or open.
If the water continues to run, even when power is off at the wall switch it's likely that the water inlet valve has failed...When power is cut they should shut off!..Replacing the inlet valve is a simple and common job...Good luck....Nomess
May 21, 2010 | Washing Machines
Admiral refrigeration not freezing not cooling
This could be a defrost problem or fan not working all time when compressor is working. What is your model number so I can see what components your model has and then solve your refrigerator problem. Need you to answer so we can get you running, Sea Breeze
Oct 23, 2009 | Maytag Admiral Top-Freezer Refrigerator
Wards/Admiral refrig/freezer
I put the fridge in manual defrost by advancing the timer. The defrost heater worked so the problem was with the timer not advancing to defrost every 6 hours. The plastic gears wear out over time.
Apr 18, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral tv/vcr, innovage jumbo remote
YOU CAN USE EMERSON CODES FOR YOUR ADMIRAL TV AND TV / VCR COMBOS, MY COMCAST REMOTE ACCEPTED 11911. SOME REMOTES NEED FIVE NUMBERS AND MY ADMIRAL ONLY HAS THREE. SO I USED AN EMERSON CODE AND IT WORKED MOST OF THE BELLS, NOT ALL WHISTLES WORKED BUT I DIDN'T HAVE TO GET UP TO TURN IT ON, CHANGE THE CHANNEL OR THE VOLUME. MY KIDS WON'T DO IT ANY MORE!!
GOOD LUCK!!!!!
Dec 26, 2007 | Televison & Video
Admiral mod#lnc6760b71
Water runs out, but does not spin, nor dry the clothes. Motor is good.
Dec 08, 2007 | Admiral AW22 Top Load Washer
Admiral Refrigerator Temperature Control 61002085 Logo
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
