Can't turn the light off on my jensen vr185
I can turn off the radio but the light does not go off, it was going off but it will not any more
3 Suggested Answers
  • 172 Answers
SOURCE: CD's won't play in Jensen VR185
Do you have it set on mp3
Posted on Aug 11, 2009
  • 14 Answers
SOURCE: We have a radio in
Press T/F (7) momentarily to change the information displayed by the unit from mode-specific
information (radio frequency, CD track number, etc.) to the clock display. Press T/F again to
return to the default display.
The T/F button is also used to set the clock to the correct time. Press and hold T/F to enter into
clock set mode. When the time flashes on the display, rotate the volume control to adjust the
hours. When finished, press T/F again and rotate the volume control to adjust the minutes.
When no adjustments have been made for five seconds, the unit will resume normal operation.
You may also download the manual here:
http://www.jensenheavyduty.com/downloads/dl/file/id/96/vr185_owners_manual.pdf
Posted on Mar 07, 2011
My Jensen MCD 5110 Marine radio acts like the antenna is unplugged. I can't figure out how to remove the radio from it's sleeve to re-plug the antenna jack (if that is the problem)
I don't know much about marine radios. I am a ham radio operator, but they are much the same, if you do not hear any static (with squelch control turned down), then I suspect you are correct about the antenna. It could be the antenna itself, or the coax line to it, or the connection point at the radio or at the antenna. You're stuck without being able to remove it. If you do and find nothing at the radio, you'll need to check the connection at the antenna etc. Good luck.
Nov 21, 2014 | Jensen Mcd5110 Marine Radio /am/ Fm/ Cd...
Help with VR185 remote
use the same type batteries full charge, same marke do not use another mixed example SONY+EVERYREADY. same polarity
2) clean the contacts batteries with c.cleaner very well
3) tight the spring contacts with pliers very well
4) open the r.control and clean the keypads with c. cleaner see the diagram attached.
try again, otherwise you must go to the repair shop TV for fix it.
God bless you
Nov 29, 2012 | Jensen Televison & Video
Have a 5" portable jensen tv/radio - no picture - how to attach a converter?
If it's one of the newer models that has the input for an antenna on the back then you can go buy the adapter at radio shack that allows you to hook it up with coaxial with either a converter box or a converter box with an antenna. The attachment looks like a 3.5 audio jack.
Oct 31, 2012 | Televison & Video
Code radio jensen
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
Sep 21, 2012 | Audiovox Jensen Vm9022hdn 6.5" Gps Ipod Hd...
How do I set the clock on a jensen vr187 cd/ car radio
1. If the radio / i-pod is on- turn it off.
2. Hit the 'mode' button until the time flashes (it should be 3 times).
3. Use the Tun +/- button to change the hour.
4. Use the Volume +/- to change the minutes.
5. Click through the rest of the options to change between setting the alarm, how to be woken up (chime, ipod, etc), 12/24 hour format, year, and date.
Oct 29, 2011 | Jensen Car Audio & Video
We have a radio in our RV and no manual. It is a Jensen VR185. Can you help us to set the time on this radio.
Mar 07, 2011 | Jensen Car Audio & Video
How do you set clock on a jensen VR185?
Hold "dis" until hours flash. Use volume knob to adjust. Press "dis" again to move to minutes. Press "dis" again to exit.
Oct 21, 2010 | Jensen Car Audio & Video
Bought a motor home with a vr185 jenson radio installed. have no instructions on using it.
you can find the manual here
http://caraudio.manualsonline.com/regman/exit/ct?url=aHR0cDovL3d3dy5hc2FlbGVjdHJvbmljcy5jb20vdGVjaHBkZi9WUjE4NSBPd25lcnMgTWFudWFsIDExLTYtMDYucGRm&target=productDoc&idDeviceType=2402&idMfg=14325&idProduct=215757
Feb 04, 2010 | Sirius Satellite Radio Sirius Starmate ST1...
Aug 11, 2009 | Car Audio & Video
Sirius Activations on VR 185 Jensen Radio
The user's manual containing the instructions can be downloaded here
http://www.asaelectronics.com/techpdf/VR185%20Owners%20Manual%2011-6-06.pdf
Thank you.
Aug 29, 2008 | Car Audio & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
