Question about Honeywell Enviracaire Elite F300E-1019 Air Purifier
Broken fin air cleaner cell
How can you repair loose fins on an electronic air cleaner cell. Can these be soldered?
  • Don Hostetler
    Don Hostetler Jan 14, 2014
    I have a cell that has two loose fins that move and hit each other. Is there a good method to reattach these? I have though about using plastic spacers or removing the two loose fins. Any feedback?
3 Suggested Answers
liteswink
  • 99 Answers
SOURCE: The Honeywell electronic air cleaner constantly
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal .Remove both the cell and check clean the bottom portion by using a vacuum cleaner attachment. If the snapping continues with the cells remove contact your contractor.
Posted on May 25, 2010
  • 19 Answers
SOURCE: Loose Fins on Electronic Air Cleaner Cell
I would use hot melt glue to hold everything in place. The air cleaner works by charging the air particle at the front and there is high voltage on the plates. The polarity of the plate alternates where the first plate is positive, the second is negative, the third is positive, forth is negative, etc .
With first wire in front charging the dust particle, the plate attract the charged dust particle to the plate to capture it.
Posted on Jan 14, 2014
Jan 14, 2014 | Honeywell (F50F1032) Air Purifier
Nothing collecting on strips
Larry, since this unit is electrostatic, you may or may not hear little crackles of sparks when it is operational. You should, however, smell a very faint odor of ozone when it is running properly. If you do not hear any sounds from the electrical plates and the air coming out of the unit does not have a little different smell than the air in the rest of the room, then the unit is not functioning properly. In my research of these units, I did see references to replacing the metal fins being required as some claimed they were an consumable element to the purifier and needed periodic replacement to function properly. However, nothing in the owner's manual says they are. It simply says to carefully clean them to avoid damaging the fins or plastic insulation on them.
Other factors to check include:
Making sure the unit has at least 12" of open space behind it.
Making sure there is 36" of open space in front of it.
Give time for dust to accumulate. The manual states that you should check the collection fins after a couple of days to see how much dust has accumulated since cleaning schedules will vary greatly depending on how dusty your home is. Dust collection may take days to start to appear.
Make sure the DRYING CYCLE light is not on when the unit is operating. This protection system is designed to remove electrical power from the fins if humidity is detected (which can easily be the case since you are advised to wash the fins in water to clean them).
If the DRYING CYCLE light is not on, you have plenty of air space around the unit, and after days you still do not see anything on the fins, then chances are the issue is internal and will require repair or replacement of parts. Be advised that this unit is no longer made and has no manufacturer supported service or parts availability. Further diagnosis and repair could quickly get costly and in most cases, you are probably better off replacing the unit.
Jan 07, 2012 | Sharper Image Hybrid GP (SI724) Air...
Honeywell Enviracaire Elite 300 problem. Light is not on. Seems like no power to system. No snapping or noises. No obvious bent fins or broken wires
If it was wired to the return air it will have a flag switch to let it know the blower is on, sometimes the flag comes off and it wont operate, sometimes it is wired directly to the computer board on terminals EAC that stands for electronic air cleaner and the board turns the air cleaner on when the blower is running, if you have a meter you can check voltage in both places to see which one is the problem. let me know. thanks wally
Mar 11, 2011 | Honeywell Enviracaire Elite F300E-1019 Air...
The Honeywell electronic air cleaner constantly "snaps" even though it is clean. I have inspected the wires and fins, clean and spaced properly. Any suggestions?
Mar 05, 2010 | Honeywell (F50F1032) Air Purifier
I have a HoneyWell F300E electronic air cleaner, installed on a furnace in a house I just bought. I have never owned one of these things before. The filter arcs and makes sparking noises constantly,...
Continuous snapping is not normal .Remove both electronic cells. Make sure that there is no hair, dirt, sand or any debris on the bottom inside the Electronic air cleaner. If there is, remove what you can by hand. If a lot of debris is left in bottom of the Air Cleaner, you may want to use a vacuum attachment to see if you can vacuum up what you can.
Jan 05, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
I have the enviracaire f300e 1001 in a house i just bought. i cleaned the filters. whenever the furnace turns on a buzzing comes from the unit. is this normal? the thermostat also flashes "filter".
Sounds like the filter is damaged or has bent fins.Make sure all the fins are not touching eachother, or they will arch and keep buzzing and flashing.Also there is a wire on the incoming air side of the filter(between each fin) to precharge the particales entering the filter .make sure the wires are not broken.good luck--Nate
Oct 29, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
I purchased a Hybrid GP germicidal Air Purifier, Model # S1724 ((Electric Air Cleaner AC110v 20w 50/60Hz)). My unit is severly malfunctioning and i nee to either send it in for repair or be given detailed...
Locate the photo electric eye that picks up the need to clean and give it a thorought cleaning. Good Luck and I hope you get it repaired. That photo cell should be your problem It's probably a little black or ruby red dot in a fin or on the housing where yhe air passes.
Jul 06, 2009 | Sharper Image Hybrid GP (SI724) Air...
Honeywell F 50 F air filter
take out the cells, they weigh about 8 pounds apiece. Make sure you remove both. Put the door back on and turn the fan in the furnace on. IF the light on the power supply comes on, then the power head is most likely good.
Then insert one cell at a time, individually. Push the single cell in all the way to the back, put the door back on, if the light is on, that cell is fine. If the cell does not come on, there is most likely a bent fin on the cell. simply bend the fin so it does not touch the other fins and you should be fine. Repeat this step on the other cell.
Make sure the door to the filter is closed, the power switch is on and the furnace fan is on.
Good luck.
Nov 18, 2008 | Honeywell (F50F1032) Air Purifier
F50E New Power Supply Arcing
check the fins on both cells for even spacing on the fins. If the fins are bent a little, this will cause your arcing.
Pull both cells out and reinsert them one at a time. Keep the cell all the way to the front or all the way to the back so it makes contact with the power supply.
The cell that has bent fins will continue arcing. Good luck.
Nov 13, 2006 | Honeywell Enviracaire Elite F300E-1019 Air...
Clicking noise
I had the same problem.
We could put one cell in and it worked with out clicking. Putting the second one in solo however, it was clicking.
I looked closely at the second cell and discovered that two of the vanes on the side with the wires were bent at about 20 degrees off. Adjusting this and reinserting reduced the clicking but not completely. I pulled the cell and focused on the same two vanes and discover one was also bent in, gently pulled it back and no more clicking!
My wife had cleaned the filters and my 6 yr old and 4 year old had to help. I wonder how they got bent?!
We have had the cleaner for about 6 yrs and no problems until this last cleaning.
Be very careful in adjusting the cells. Aluminum does not like being bent and weakens each time it is moved, like pulling a tab off a beer can (of course the cells are made from much thicker and higher grade aluminum)!
Jan 23, 2006 | Honeywell Enviracaire Elite F300E-1019 Air...
Honeywell Enviracaire Elite F300E-1019 Air Purifier Logo
47 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
