LG Turbo Choice WF-T6517 TE user manual - Washing Machines
3 Suggested Answers
abhishek33
  • 1239 Answers
SOURCE: LG WF S5605PP Not Rinse
hi here the steps Of all washing machine parts, the water pump probably takes the most punishment, because it is constantly in use. When the pump fails, you can hear or see the trouble: a loud rumbling inside the machine, or a failure of the water to drain out of the tub. Here's what you can do to fix the problem:
Step 1: Check the drain hoses to make sure they are draining properly. Remove the water supply hoses from the back of the washer. With long-nosed pliers, extract the filter screens from the valve ports in the washer or from the hoses themselves. Wash the screens thoroughly. Then replace them and reattach the hoses. If the machine still rumbles or doesn't drain, examine the pump.
Step 2: To access the pump, first bail and sponge out any water in the machine's tub. Then tip the washer over on its front, using a heavy blanket or pad to protect the washer's finish. Remove the back service panel. The pump is usually located along the bottom of the machine, but with the unit tipped on its front it's easier to remove the pump through the back than through the bottom of the washer.
Step 3: Locate the pump. It has two large hoses attached to it with spring or strap clips. If the clips are the spring type, pinch the ends of the clips together with pliers to release them, and slide the clips down the hoses. If the clips are the strap type, unscrew the metal collar to loosen the clamp. Disconnect the hoses by pulling them off the connections. If the hoses are kinked or crimped at these connections, straighten them as best you can and reconnect them. Then try the machine again to see if this kinking was causing the problem. If the machine still doesn't drain, you'll have to remove the water pump.
Step 4: To remove the pump, loosen the bolt that holds the drive belt taut and move the washer motor on the bracket to loosen the belt. Move the motor out of the way and unbolt the pump; it's usually held by two or three hex-head bolts located on the bottom of the pump housing. As you loosen the last mounting bolt, support the pump with your hand. Then lift the pump out of the washer.
Step 5: You should take the pump apart if you can, because the trouble could be lint, dirt, or pieces of cloth or paper clogging the pump impeller. Clean away all debris inside the pump and clear any debris out of the water tubes. Then reassemble the pump. Hook up the pump again and test it. If cleaning the pump doesn't put it back into working order, or if the pump housing can't be removed, replace the pump with a new one of the same kind.
Step 6: To install the new pump, set it into position and connect the mounting bolts to the pump housing. Move the motor back into position. Tighten the drive belt on the motor by prying it taut with a hammer handle or pry bar; it should give about 1/2 inch when you press on it at the center point between the two pulleys.
Posted on Sep 12, 2008
  • 330 Answers
SOURCE: when going on to rinse cycle machine keeps filling
pressure switch needs to be replaced or repaired
Posted on Jan 11, 2011
I cannot find the online user manual for the WF-3620!
You can find easily by google it, Just type the model number of printer with user manual or user guide
you can use this key work " epson wf-3530 user's guide "
https://www.epson.com/cgi-bin/Store/support/supDetail.jsp?UseCookie=yes&oid=232591&infoType=Doc
https://files.support.epson.com/pdf/wf3520/wf3520ug.pdf
Feb 01, 2016 | Epson WorkForce WF-3620 Wireless Color...
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
Dec 01, 2013 | Washing Machines
Toyota hilux surf ssr x 1994 3.0 litre turbo diesel 1kz te
Check this video and leave him a message about your user manual,may help you get one.
Nov 25, 2013 | Toyota 4Runner Cars & Trucks
MANUAL FOR LG WASHING MACHINE, MODEL NUMBER WF-T653A
You can get the manual on the link below. Just click on where it says it is free top right.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T653A-_E
Good Luck and please rate 4 thumbs up for the free answer
Sep 06, 2010 | Washing Machines
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
