What voltage is required for volare hd-20k led projector?
There are some white dots on the projection
The DLP chip of the projector has gone bad, which require to be replaced.
Aug 17, 2015 | LG HS200 SVGA 200 lumens LED Projector;...
When i on the main ac power switch,instead of the red led the green led comes on
Hello , the problem is usually the Power Board . Requiring a technician to fix it
Oct 03, 2014 | Panasonic PT-AE900U Multimedia Projector
MY PROJECTOR TURNS OFF AFTER A COUPLE MINUTES
- Check LED Status
a. Lamp LED Light
- Check Lamp
- Check Lamp Driver
- Check Main Board
b. Temp LED Light
- Check Thermal Sensor
- Check Thermal Switch
- Check Fan
c. Color Wheel
- Check Color Wheel
- Check Photo Sensor
Sep 03, 2014 | Optoma Hd70 Dlp Hd High Definition 720p...
We purchased a white HD 1080P Home theatre LED Projector, we cannot get the sound to work. What could be the problem?
The AV may require a separate audio connection. For HDMI, check that resolution (720 vs 1080, etc.) are matched. Could be HDCP handshake failure. Sometimes this can be fixed by powering source & projector off, then back on. Sometimes it is incompatibility between devices, which some claim can be fixed with powered switches (but didn't in my case [with other brands]). HDCP is a bag of hurt.
Jul 30, 2014 | Office Equipment & Supplies
Voltage of the lamp
starting voltage is more than 1000V (only 1-2 seconds)
after 1-2 seconds ,the projector is turn on ,and running
operating voltage is 65-120v
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 26, 2014 | Sony VPL-EX100 3LCD Projector VPLEX100
Led bulb blinking even turned
1. voltage problem
2. transformer problem
3. the problem of the LED bulb itself
4. not suitable on your original fixture.
it depends on many situations, and you can check this blog out for better knowledge of LED products
LED tipster Lighting EVER
Jan 17, 2014 | Sharp XR-10X Multimedia Projector
Hi Ajin, I have a LG RD-JT52 Projector which I
HI David,
Sorry for the late replay first of all. I dont have the service manual with me. So i need the service manual for assist you. One more thing is You will not be able to connect the led directly to the power supply of your projector. For that you need Buck converter to connect in between the led and power supply. Normally leds are of voltage between 1.8V to 3V range. That will be mentioned in the PDF datasheet of the LED. The tearm BUCK means to reduce the voltage From the applied voltage to the range of LED working voltage. If not the led will burn out. You didnt mentioned about is the buck converter is there or not . If its there i want to know the input voltage range of the Buck converter. If it is not there, sent the service manual i will check out and tell you what type of buck converter you need. And how to replace with the LED if it possible. My email address is ajingopakumar@yahoo.co.in
Ajin
Jan 15, 2012 | Office Equipment & Supplies
Will not Power up
if you shook it too mutch you must have disconected the power so check all the electricals and fix the separation. the same thing happened to mine
Nov 14, 2011 | Televison & Video
Lens light not glow?
1) Does the projector have power? There should be at least 1 LED lit on the body. Make sure that the on/off switch is on and that the mains feed is working.
2) Turn the projector on. Does the fan run? Are there any error codes indicated? Consult the manual for help interpreting them.
It may be that you require a new lamp, however I would verify the projector is working and that the LEDS indicate this before spending any money on it.
Feb 14, 2011 | Samsung SVP-5500DX Multimedia Projector
73 people viewed this question
jasbo
jasbo
