Question about Cameras
When trying to take picturesmessage says camera is currently in use
I have taken 1 or2 without message do not know how to turn it off
    Genius:
  • Cameras Master
  • 1,019 Answers
Let us know what kind of camera you are talking about ?
You are leaving us in the dark and unable to help you.
Posted on Jan 26, 2013
Why my yahoo messenger cannot connect webcam
1)you have to en-load it and re load it then it should work or2)Re-install operating system and yahoo messenger as well as webcam it may work previously it worked for some people. if it doesn't work please let me know,if you find any errors while installation
Thank you
Jan 30, 2011 | Yahoo Messenger
Lamp lights without command no longer open in the minidv box black screen does not play, not record one more thing to do?
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory car
Jan 26, 2011 | Samsung SC-D103 Mini DV Digital Camcorder
Have a canon rebel EOS 20D that registers an error 99 after I take one frame and then won't allow another one to be taken until I turn camera on then off again. Does this require factory repair or is there...
Hi LLFraserny,
You can probably try to isolate the error 99 first.
To isolate the cause of the issue, do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 30 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera will need to be serviced. If the message does not appear, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
One last item to check before sending camera to Canon service is the alignment of the shutter. Life the mirror and visually inspect the shutter curtain. If each segment is not completely straight, touch it lightly with your blower bristles and try to pop it back into alignment.
Hope this helps,
Andrew
Apr 09, 2010 | Canon Photography
I just bought a new memory card and tried to format it and I get an error message filesys 001 I think. Bev Caproitti bcaproitti@cox.net
Your camera is only supporting SD/MMC Cards (up to 1GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Dec 28, 2009 | Kodak EasyShare C330 Digital Camera
Error message
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Sep 20, 2009 | Nikon D80 Digital Camera with 18-135mm...
Error 99 in Canon EOS 350 D
Try the following diagnosis steps, in this exact order. This will isolate the cause of the issue: -
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Dec 01, 2008 | Canon Rebel XT / EOS 350D Digital Camera
I have a Canon Rebel XT EOS Every time i take a pic I get an Err 99. I have taken the battery out and memory card for 5 Min. If i do that I can take about 5 or 6 pics before I get that message again. What...
Try the following diagnosis steps: -
To isolate the cause of the issue, do the following: -
Nov 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Memory card problem
wheather you check in computer repair shop is their any virus present in memory card? format your memory card! check virus is present in your computer or not! ?Try it!
Jul 11, 2008 | Nikon Coolpix S3 Digital Camera
Digital camera R717 - display screen
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Apr 20, 2008 | HP Photosmart R717 Digital Camera
Change battery message
I am experiencing exactly the same problem with my Canon Powerhot S2IS. I tried the same thing to remedy it by cleaning off the contacts, but no luck. And it's not simply a cold weather problem. My camera does this with brand new Duracell batteries as well as with freshly recharged NMH batteries. What gives? I've had the camera for nealy 2 years and have taken excellent care of it.
Oct 24, 2006 | Canon PowerShot S2 IS Digital Camera
Cameras Logo
13 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
