Question about Canon FAXPHONE L80 Laser
Change baud rate canon l190 - Canon FAXPHONE L80 Laser
3 Suggested Answers
  • 1335 Answers
SOURCE: How do I change the Baud rate on a canon f80 fax
To set the receive speed
Change RX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (RX or send) speed if this message appears frequently on the LCD.
  1. On the operator panel, press <Menu>.
  2. Press the left '<' or right '>' arrow repeatedly until [USER DATA] appears.
  3. Press [Set].
  4. Press the right arrow repeatedly until [FAX SETTINGS] appears.
  5. Press [Set].
  6. Press the right arrow repeatedly until [RX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [RX START SPEED] appears.
  9. Press [Set].
    1. The factory default RX (send) Speed is 33600 bps.
    2. You can select from the following RX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable RX Speed.
  11. Press <Set>.
  12. Press <Stop> to return to standby mode.
To Set the Send Speed
Change TX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (TX or send) speed if this message appears frequently on the LCD.
  3. Press [Set].
  5. Press [Set].
  6. Press the right arrow repeatedly until [TX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [TX START SPEED] appears.
  9. Press [Set].
    1. The factory default TX (send) Speed is 33600 bps.
    2. You can select from the following TX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable TX Speed.
You can download a copy of the user manual for the F80 at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=7175
Please make sure to rate this solution. Thanks.
  1. Press <Set>.
Posted on Apr 29, 2010
FixinFax
  • 3085 Answers
SOURCE: where do I find Baud 9600 Rate and ECM?
You can't, plus it will not help on a digital phone system. ALL fax machines are ANALOG devices.
Posted on Jun 29, 2010
How to change baud rate please
Not sure why you want to change baud rate. This should be automatically negotiated with the system you are communicating with....
What is the problem you are attempting to solve?
May 26, 2016 | Canon FAX-JX200
How i change the baud rate
why would you want to change the Baud rate? you don't need to do that.. Ive worked on faxes for over 30 years and never once have I changed a baud rate.. leave it alone..
May 02, 2014 | Samsung SF-560 Plain Paper Laser Fax
Memory if full message on Canon L190
I am sure a 'Memory Reset' would fix this.
As to 'how', I can only suggest you check out the precise way to do this in your CD manual.
Dec 18, 2013 | Canon Lasers FAXPHONE L190 Wireless...
Baud rate hp 9600
why need to change baud rate, no need to change???
because it is not a serial port printing it is usb port printing....?
Oct 01, 2013 | HEWLETT-PACKARD LaserJet M1522nf...
How do i clear the memory out of a canon l190 fax machine
1) Power off (front of system)
2) Hold down Rest button (//), keep holding down
3) Power back on, keep holding reset until until back on.
Sep 16, 2013 | Canon L190 Fax Machine
How to get a fax confirmation on a canon faxphone L190
There should be a button on the front of the fax 'Reports'. Push that. Then go to 'Report settings'. Select that option. For confirmation reports that a fax was sent 'TX Result Report'. Turn this 'On'. You should be set. We just figured this out on our faxphone.
Nov 29, 2012 | Canon Office Equipment & Supplies
Change baud rate on okifax 5050
The baud rate is automatically set by the machine when it connects to the remote machine. The machines start at the highest speed and drop down until both machines can send/receive without any errors then they send the pages. You can not manually set the speed.
Buddymc
Feb 27, 2012 | OKI Office Equipment & Supplies
Where do I find Baud 9600 Rate and ECM?
Jun 29, 2010 | Canon imageCLASS D480 Black and White...
4800 baud rate communication in vb
You have to change it on both side!
If you are communicating your PC with a serial device, BOTH must have the same speed (serial device: 4800, pc: 4800)
Have you done it?
Most devices DEFAULT settings are 9600 baud rate, N, stopbit1.
But you can change it depending on the device...
Jan 03, 2009 | Computers & Internet
Send and receive speed
That's not even a coherent response. Even analog phones go from an analog signal from your home, to a digital signal at the carrier, to an analog signal at the recipients end. It all goes digital at some point.
Fax machines work fine with a digital phone. The baud rate may need to be lowered in some cases, but working for a cable company, I've personally worked with hundreds of fax machines that work just fine.
Try lowering the baud rate and/or using a DSL filter if you are having problems. If you are unable to find the baud rate or speed setting on your fax, you may want to contact Canon to find out how.
Dec 09, 2008 | Canon FAXPHONE L80 Laser
Canon FAXPHONE L80 Laser Logo
63 people viewed this question
old marine
old marine
