Question about Kenmore 15208 Mechanical Sewing Machine
Kenmore Sewing Machine model # c877.15
I have a kenmore sewing machine that is a classic machine but I can't figure out how to thread the bobbin please help thanks
  • 8 more comments
  • Anonymous Mar 15, 2014
    My machine won't hardly sew
    My machine won't hardly sew. What should I check next after all threading, bobbin etc.
    My machine won't hardly sew, what should I check
    I can't find the model number for my Kenmore Sewing machine. It is mounted in a wood cabinet that has a metal tag with a model # of 566 93610. Can you please help me?
  • Anonymous Mar 16, 2014
    Item: 19112 | Model: 19112
    i want to oil it
  • Anonymous Mar 21, 2014
    Haven't used machine for a while. Wheel does not turn. Belt intact. What do I do?
  • Anonymous Mar 22, 2014
    Model 158.19451
    Machine will not sew in reverse
  • Anonymous Mar 30, 2014
    kenmore sewing machine backstitch not working model 38517624390
    installing belts
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
Posted on Aug 09, 2007
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Posted on Jul 18, 2007
2 Suggested Answers
  • 1116 Answers
SOURCE: how do I thread the bobbin on kenmore machine
If this guide is not the same, there are others you can view to get the correct version for your machine - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Kenmore_Sewing_Machine_Threading/kenmore_1340_1345_1350_1355_threading_diagram.htm
Posted on May 19, 2010
Kenmore sewing machine model 158.905 how does the bobbin and bobbin cqse go back in?
Sears carries manuals for most of their machines (usually for free). The manual is invaluable for using your machine, including threading instructions.
Kenmore 158 1792 Sewing Machine Threading Diagram
May 02, 2017 | Kenmore Sewing Machines
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
How do I refill the thread bobbin on a Kenmore sewing maching,,model 148-19371
You can try a couple of YouTube videos:
Loading thread on the bobbin old Kenmore sewing machine
(do not wind the bobbin as fast as he does as it tends to stretch the thread and also could cause the spool to fly off the machine!)
How to wind Bobbin Winder Sears Kenmore Sewing Machine 158 12270 158
or order an Owner's Manual for your machine:
... Sewing Parts Online Search
Sep 04, 2015 | Kenmore Sewing Machines
How to "tune-up" mechanical Kenmore sewing machine
Sure! Jenny at http://blog.sew-classic.com/categories/Sewing%20Machine%20Repair.aspx has several very good, in-depth articles about servicing your own machine, but here are the basic steps:
1. Take out the bobbin case and bobbin holder.
2. Take the needle plate off.
3. Brush out all the old lint in the bobbin area and under the needle plate. Remove any loose bit of thread.
4. Open the head of the machine (should swing open). Clean any lint or thread that's caught in there.
5. Locate your machine's oil ports and put one drop of sewing machine oil (only use sewing machine oil) in each of them. One drop is sufficient. General rule of thumb: Put one drop of oil wherever metal moves against metal.
6. Using unwaxed dental floss, floss the tension disks.
7. Put everything back together.
If you need a manual, I found one at http://pages.sewing-machine-manuals.com/173/InventoryPage/1834489/1.html.
Hope this is useful!
Robbie
Jul 24, 2010 | Kenmore Sewing Machines
Kenmore Sewing Machine: stitch not forming bobbin thread problem
sounds like it needs a service call. if you do not have a sewing repair man you use regularly to clean machine the local fabric store should know who you could call.
Jul 20, 2017 | Kenmore Sewing Machines
Kenmore by sears model 1581457180 need a manual or a how to thread the bobbin
hi there,
on my manual 1581 kenmore show figure on how you thread your bobbins and upper thread.
to thread bobbin insert the thread on one hole of winder holding thread and rotate thread on counter clockwise rotation several times, loop the thread on tension thread and insert bobbins winder on winder shaftat top of your sewing machine push the latch to lock bobbin winder
pull the handwheel to disengage the clutch and to move the winder free rotation.
press the foot pedal to run your winder and thread your bobbins be sure on counterclock wise rotation.
if winder is full of thread this will automatically disengage the shafting winder from clutch.
4843169.jpginsert winder as in fig. check the thread direction
5d74924.jpg 153629c.jpg on figure hold and insert bobbins on shuttle race assymble.
on figure show upper threading.
3cba620.jpg follow the red thread on figure.
you can also check your manual on internet
search box type www.kenmore 1581
have a nice day,rate my fix,thank's a lot
Jun 12, 2009 | Sewing Machines
How do you thread a kenmore sewing machine I can't figure out how to thread the bobbin for kenmore machine 1385.15343600.  I am a beginner, so I will need pretty detailed instructions. Thanks! Jenny
Put the bobbin on the short metal stick on top of the machine. Unthread the machine. Put the spool of thread on the tall, left side stick on top of the machine. Take the thread and wrap it counter clockwise around the circular, short, metal thing on the left side of the top of the machine, only 180 degrees. Thread the thread through the hole in the bobbin (which should be on top). Press the bobbin to the right, into the little white thing. Pull the turning wheel on the right side of the machine out. While holding the end of the thread, softly press the presser foot so that the thread goes around the bobbin a few times. After that, cut the end down to the bobbin. Now, press the presser foot down and wind the bobbin until it stops on it's own.
Mar 05, 2009 | Kenmore 15343
Bobbin wont catch
Try flipping the bobbin. The thread must come off in a certain direction to work properly.
Jan 23, 2009 | Kenmore 15218 Mechanical Sewing Machine
Bobbins
Have a look at this website on the threading page, if your machine is not listed look at some of the other Kenmore machines and you will get the idea of how to remove the bobbin case. Basically you will find a small latch across the front of the bobbin case, pull the latch away from the case and hey presto.
www.sewusa.com
Apr 23, 2008 | Sewing Machines
Kenmore 10 Sewing Machine
i have a kenmore10 model 1249180 ehwn i sew it squeeks i oil it i dont know where the squeek is coming from
Dec 05, 2007 | Kenmore 744-08BH Mechanical Sewing Machine
Kenmore 15208 Mechanical Sewing Machine Logo
1,546 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
