Question about T-Mobile Sidekick® 3 Cellular Phone
Pop up warning
A warning pops up saying back removed, always turn the device completely off before removing the battery. with a memory card inserted while the icon ... is blinking do not eject . when the blinking has stopped you can safely remove the card.
i have NO card in, and my back cover isn't removed.
what's going on ???
    President:
  • 625 Answers
Put a piece of folded up paper between the battery and the back cover. It will apply the extra bit of pressure it needs to engage those pins.
Posted on Feb 05, 2009
  • 27 Answers
Okay your sensor is probably dusty or broken there is 2 prongs on the backside of the case make sure they are intact and pushing down on the prongs okay if that dosent do it then stuff those prongs with somethin that will hold contineuous pressor kk let me kno how it works
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
Memory card is full and when I plug in the USB cord and turn on the camera I get a message that my device is not connected or is busy, or that it contains no pictures!!
Causes of memory card corruption
  • Turning off a camera before an image is completely written to the memory card.
  • Removing the memory card from a camera while an image is being written to the card.
  • Removing the card from a memory card reader while files are still being transferred to a computer.
  • Batteries conking out as files are being transfered directly from the camera to a computer. Note: always make sure you have fully charged batteries before transferring images.
  • Removing the card from a card reader while folders and files from the card are open on a computer.
  • Opening, deleting, renaming or moving files on the card while its contents are open on a computer.
  • Using a memory card which has not been formatted in the camera. Use the delete/erase function when needed, however a card should be regularly formatted.
  • Formatting a card in a computer instead of the camera.
  • Inserting a second memory card into a card reader before closing and removing the first when viewing images on the card from a computer.
  • Taking photos when camera batteries are nearly empty.
  • Taking photos too rapidly so the camera can not complete writing one image before starting the next.
  • Continually shooting and deleting, shooting and deleting images when the card is full.
  • Letting a memory card get too full before downloading the images to a computer or storage device. Cards that are too full may overwrite the card headers.
  • Using a memory card from one camera in a different camera without formatting it in the new camera first.
Feb 28, 2008 | Cameras
My vivicam x024 won't turn on. how do i remove the memory card? will the photos still be on the card if I remove it?
The SD memory card slot in located on the side og your camera. Push the SD card and it will pop out.
The photos are stored on the SD memory and removing it from the camera will not lose the photos stored on this SD memory card.
Remove the memory card from the camera and insert it into anUSB memory card reader. Connect this USB memory card reader and memory cardinto the USB port of your working computer. Your computer will see this as anUSB Mass Storage Device or an external storage device; you can then open thefolder on the memory card and copy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
May 28, 2012 | Vivitar ViviCam 5100 Digital Camera
My camera says memory card is write protected, how can i remove this?
Hi, try to remove first the memory card inside your camera, most memory cards are inserted at the location of the battery also. Pull out the memory card after pulling out the battery. You can pull out the memory card by pressing it once and it should pop out automatically. If it's lose already, please check the sides of your memory card, there should be a small switch either color grey, orange or red and change the switch by clicking upwards or just the opposite side of the original place... the card then is not write protected anymore.
Jun 06, 2011 | Nikon COOLPIX L20 Digital Camera
Where do i insert the samsung intensity memory card
Pull off the back cover of your phone by putting your fingernail in the slot on the top back of the phone (right above the camera) and popping the back cover off. Then turn your phone over so you're looking at the back. The memory card goes in the slot to the left of the battery (it should say "MicroSD" on the slot.) It slides in from the side, toward the battery. Once you have the card in, you can pop the rear cover back on.
Jun 04, 2011 | Samsung SCH-U450 Cell Phone
How can i pull out my memory stick t of my cer laptop
The memory card is ejected by just pressing it in until you hear a faint click then letting go. The card will pop out by itself about 1/8 inch and you can just grab it and easily pull it out the rest of the way. A word of caution. If you have written anything to the memory card from your laptop, you should not eject the card until you left-click on the tool bar icon "Safely Remove Hardware and Eject Media" then click on the pop-up list item to "Eject Mass Storage Device" which will reply with a "Safe to remove hardware" message. This insures that the contents of the buffer used for writing the memory card or stick has been completely written to the memory card or stick before it is removed. Because the card or stick is much slower to write than it is to read from the laptop's hard disk, there will always be a chance for an incomplete write causing card or stick corruption unless the "Safely Remove Hardware and Eject Media" is used.
Mar 26, 2011 | Computers & Internet
How can i download a music from computer to my memory card using my card reader,help please
1. First insert your SD card in the card reader.
2. Plug the card reader to your PC.
3. Go to My Computer, you will see the SD card as removable drive.
4. Double click in your card, and open.
5. Again go to my computer, open the a separate window. Open the folder containing your music files.
6. Select the required music file, right click, in the pop up window select copy.
6. Go to your SD card window, right click, in the pop up window select Paste.
7. You will see a window showing coping in progress.
8. After completed the process close the window.
9. Look at the right side of the task bar, there will be an icon, Safety remove hardware, left click, in the pop up menu select your SD card drive, one notification will come, "its safe to remove the hardware"
10. Remove the Card reader from your PC.
Aug 18, 2010 | SanDisk 2GB microSD Memory Card
I want to know what i need to do next after i have put my sd card into my computer, a green light comes on, and i want to know how to get my pictures to come up on my computer, so i can do any adjustments...
1. When you insert a memory card into your computer, it'll be detected automatically and an "AutoPlay" dialog box will ask you to what to do ?
2. Select "Open folder to view files" option from the list.
3. Now, you can easily view the files in the memory card by double-clicking them.
4. If the "AutoPlay" dialog box doesn't appear, goto Start >> My Computer. Here you can view the memory card as a "Removable Drive" with some name!
5. Double-click the memory card's icon to view the files inside it.
6. After your job is complete, you can remove the memory card by just clicking the USB device icon at the right side of Task Bar (Notification Area)!
7. On click, a single option pop-up will appear with "Safely Remove USB Mass Storage Device" message!
8. Just click on that pop-up. A "Safe To Remove" message box will appear.
9. Click on OK button, and manually remove your memory card!
please rate this advice if it helps...tc! :)
Jan 12, 2010 | Electronics - Others
How to insert a sim card in nokia7100 .tere is no slot .what can i do? I pushed the sim in, but it was really hard. the cut off corner was in the right place. Still does not say that there is a sim there...
Extract from nokia 7100 user guide:
Always switch the device off and disconnect the charger
The SIM card and its contacts can be easily damaged by
scratches or bending, so be careful when handling,
inserting, or removing the card.
1. Slide the release button (1), and remove the back cover
(2).
2. Remove the battery (3), and insert the SIM card (4).
3. Insert the battery (5), and replace the back cover (6).
May 29, 2009 | Nokia 7100 Cellular Phone
Samsung L730 wont extend lens and dosent turn on right
Try removing the batteries and memory card. Let the camera set for awhile. Put the batteries back in but not the memory card, restart the camera. Does it work know? If it does, turn the camera off put the memory card back in. Turn the camera on, does it work now? If it doesn't, replace the memory card.
Dec 27, 2008 | Samsung Digimax L730 Digital Camera
T-Mobile Sidekick® 3 Cellular Phone Logo
57 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
