Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
I have ex USB harddrive but it was not able to install I need the usb driver. p/n WD1600ME-00
  • Anonymous Feb 10, 2009
    the pc cnat read it
  • Nathaniel46 May 21, 2009
    I have the same problem with the same harddrive WD 1600ME-00 extern hdd. i connect it to the pc the yellow light is blinking one time then its stops and the computer is asking me for a drive ..i don`t have one ..can you help please..I tried all the USB ports the result is the same.
  • 68 Answers
HAVE YOU TRY TO ALL USB PORT, IF U ARE USING LAPTOP SOMETIME THE FRONT USB NOT WORK, YOU NEED TO INSERT INTO THE REAR USB PORT(ON THE BACK OF YOUR LAPTOP, TRY TO INSERT TO ALL PORT, WAIT ABOUT 10 SECONDS,
IF U ARE USING DESKTOP, NORMALLY THE 2.0 USB IS ON THE BACK OF THE DESKTOP.
Posted on Jan 26, 2009
I had wd WDBAAR2500ABK-00 it blinking but in my computer it not showing
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Apr 30, 2011 | Western Digital My Passport Essential SE...
I have a WD1600ME-01 hard drive passport. It was working fine but suddenly my laptop is no longer recognizing it neither my PC. when I connect it the drive light starts to blink and I hear a continuous...
Jan 02, 2011 | Western Digital WD Passport 250GB Portable...
Compaq presario M2202AP doesnt recognize WD 3200 external usb drive. I cant find the download site for the corresponding usb hard drive. ...
Hi You can download driver from below link. Click here Install driver then check. Also follow below if still not recognize. First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Oct 13, 2010 | Western Digital Passport 320GB External...
It's not making any noise
then check.
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Jul 20, 2010 | LaCie (300770) 250 GB Hard Drive
My sata external usb western digital 320 gb drive only shows up as an unknown USB device. Is there any way to get my computer to recognize it. I have a laptop using windows xp. Ive tried unplugging...
then check.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
Jun 25, 2010 | Western Digital 320GB MyBook External USB...
Windows 7 is not recognizing and comes up as a cd drive?
then check.
Jun 22, 2010 | Buffalo Technology 1TB DRIVESTATION COMBO...
External hard drive is not being recognized by any computer
then check.
Thanks for using FixYa.
Apr 27, 2010 | Western Digital Passport 320GB External...
MY PASSPORT ESSENTIAL WD1600ME-00 is not recognized by plug-and-play in either of my HP Desktop Windows computers (One with XP, one with VISTA). Power light comes on when attached to any USB port. Device...
You run MS Windows Update to download and install the latest OS updates. Your WD external HDD should be detected after OS update.
For non updates system, try to connect WD to the USB Port where it worked before. If you have 4 USB ports for instance, try to connect it to these ports one try at a time. Windows XP might have assigned one USB port for your device before when it was working just fine.
Feb 02, 2010 | Western Digital WD Passport 250GB Portable...
Driver for rtl 8139D
maybe you got the wrong version of your driver, realtek got an A&B device driver..
Feb 15, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
804 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
