Question about Sharp AR C250A Color Copier
Print function is out of service Code F9-00 - Sharp AR C250A Color Copier
  • steve_wardle Feb 04, 2009
    Connection Problem
    Thanks
    Novelist:
  • 126 Answers
F9-00 - Printer board problems
You've got a Communations error between the ICU PWB & the PRT PWB. This should work if brds and connectors are okay, try simulation 14-0 to reset.
Then I'd start checking harness's & connectors. Unless of course it's blown board.....then call service tech.
Posted on Jan 28, 2009
Canon ir2200 printer error code e0000020000
1. Hit "additional functions" key on the printer's keypad.
2. Press and hold 2 & 8 at the same time for one second.
3. Hit additional functions key again.
4. You've entered service mode. Now hit "copier"
5. "Function" key
6. "Clear"
7. "Err" . There should be an error or the error code in this section select this part.
8. Hit "ok"
9. Restart the printer by switching off the physical black power switch on the side and switching it back on.
For more help visit cbrtechsolutions
Dec 14, 2010 | Canon Computers & Internet
WILL NOT PRINT CODE E000002-0000
this means that there abnormal readings of temperature in fixing assy.
To get rid of the error you can do two things:
First:
Press * ( add. function key )
press 2
press 8
Press *
This will allow you to enter service mode.
Choose COPIER
Under FUNCTION tab, choose CLEAR and choose ERR
This will clear E002 error.
Turn off and on.
If it works, that means that because of i.e. blocked vent cover, or too much of a/c,... had influence on temperature readings in fix. assy.
If that doesnt help, you need to replace fixing film assy.
Hope that helped
Jun 04, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Error code E000002-0000
Get in the service mode *28* and there under function, clear, err.
If not replace the fixing film unit
Jan 02, 2010 | Canon (6981A002AA) for imagerunner 2200,...
The copier shuts down when trying to print
Look for the error code, that would lead you to the problem area, most likely the fuser assy. needs to be replaced. Do this, Press;
ADDITIONAL FUNCTIONS,
press 2 and 8 (together),
ADDITIONAL FUNCTIONS again,
You should now be in Service mode, if not hit CLEAR twice then repeat the steps above.
press COPIER,
press ERR
the one listed at the top is the error code.(write it down)
You can try clearing the code then reboothing the machine with the right side switch and it might work.
This is how you clear the code, follow all the steps above except the last one (ERR) instead select FUNCTION above then CLEAR then ERR. Turn the machine off then back on again.
If that does not help and you are still having the same problem, you could either call Canon with a service call, call a local technician or get yourself a service manual and with the error code you wrote down above try looking it up or contact us again with the error code. Good luck.
Dec 18, 2009 | Canon imageRUNNER C3220 Color Copier
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Where is the printer head and how to align it
Service Mode
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The
indicator will blink in green and remain lit in green.
3) Select one of the following service mode functions by pressing the resume button the specified number of times.
Press Resume Indicator Functions
Zero times Green Power off the printer
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter setting
5 times Orange Destination settings
6 times Green Print head deep cleaning
7 times Green CD-R test print
8 times Orange CD-R print position correction (horizontal)
9 times Green CD-R print position correction (vertical)
4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 25, 2009 | Canon PIXMA MX310 All-In-One Printer
Print Head Problem
Perform these steps and reset the EEPROM:
Service Mode
Thanks, Joe
May 20, 2009 | Canon PIXMA MP470 All-in-One Printer
Error code 300. How fix
Do the EEPROM initialize reset;
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. release RESUME
3. press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Thanks, Joe
May 01, 2009 | Office Equipment & Supplies
Canon i960 puts up an error code "USB003" used ink tank almost full. how do i reset the printer? please.
2. Release RESUME
3. Press RESUME twice, then release POWER
Mar 06, 2009 | Canon i950 InkJet Photo Printer
Error code is E000003-0000
thats a fuser error do this in this order additinol function key then the 2 and the 8 key and the same time then additional func key again screen should change to service mode then touch in this order copier function clear err ok turn off with main switch turm back on if it doesnt clear you have a bad fuser
Nov 25, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Sharp AR C250A Color Copier Logo
236 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
