Question about Samsung HCJ552W 55" Rear Projection Television
Samsung HCJ552W convergence out before warmup
I've noticed since connecting a HD DVR to the DTV input that my convergence lines on the left are vastly out of sync for 10-30 minutes. It seems after the TV warms up the convergence comes back in to sharp. Does anyone have an answer for this?
    Scholar:
  • 150 Answers
If set has a few years on it, the convergence may be going out.
Posted on Jul 17, 2007
SOURCE:
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Mitsubishi WS65809 HD input (DTV) not working correctly. I replace the convergence chips in this TV and was making adjustments in the service menu. Everything was lined up and working great. The HD input...
All these sets do have a hard reset---not the reset button on the front of the set---it will return the set to the factory original condition it was when new in the box--it will not affect the convergence as that is stored in a separate unit--the DCU (digital convergence unit).
It is accessed with an original MITSUBISHI remote.
You can try it if you want:
ACCESS CODE FOR WS65809 IS:
menu-0,1,7,0 enter
There are 3 hidden menus in the set--this is the Option menu
You will see either reset or option etc and highlight it with the remote and hit enter. Set will shut off and should come back on channel three in the air band--any labels you placed on inputs will be gone and set will be in air band--you will if on cable have to change it to cable band and auto program etc.
Let me know what happens and if you have questions I am here to help.
SD TECH
Feb 02, 2010 | Mitsubishi WS-55809 55" Rear Projection...
My antenna has a coax-my 50 in Maxent mx50X3 has no coax hook up. How do I connect these two?
That unit does not have a tuner so it does not have an antenna input. You need to connect a cable box, satellite box, VCR with a digital tuner (or an additional DTV box for converted input), or DVR to one of the HDMI, S-Video, or Component inputs to view TV.
Oct 26, 2009 | Maxent MX-50X3 50 in. HD-Ready Plasma...
HDTV goes blank when connected to Fios HD-DVR or Fios DTV recvr.
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
Jul 23, 2009 | Televison & Video
No digital reception with HD ready TV.
Someone did not explain to you what HDTV "Ready" means. It means you do not have a ATSC tuner in it to except over the air digital signal. The only way you will get digital reception is either from a HD Cable box with RGB outputs that plug into your RGB inputs, or being on Satellite connecting the same way. Seven years ago manufacturers never made it easy to understand and Salesmen only made it worse. So in short the term HDTV Ready meant it can, with a BOX.
Jun 13, 2009 | Samsung HCJ552W 55" Rear Projection...
Want to run my dtv receiver through new digital converter box.
You will not be able to record local station from a DTV converter connected thru a directv receiver unless there is a a/v input on the directv samsung receiver. Also check the user manual for this receiver if recording from an external source such as a DTV converter box is possible. The answer to seperating the DTV converter box from the directv samsung receiver is possible if your tv has multiple inputs. Try connecting the DTV box to the RF input and the directv samsung box to an a/v input then change inputs using the tv remote. you will need an av cable (yellow/ red/white) for the directv box and a rf jumper cable for the DTV box.
May 17, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Can't seem to add HD channels to Mitsubishi WS-65513
You need to run an external antenna feed to the air DTV input jack, bottom left. You can use your loop out if you already have an antenna connected to your antenna A input jack. Create a DTV device, then run your antenna setup for DTV.
Mar 14, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Feb 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Samsung LE32R7 Vertical lines problem
Plug the TV into a wall socket by itself, have seen this when TV was plugged into a power strip.
Dec 13, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung HCJ552W 55" Rear Projection Television Logo
83 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
