Question about Seismic Audio 12" PA Speakers & Floor Monitors
Speakers smell like rubber - Seismic Audio 12" PA Speakers & Floor Monitors
Microwave smell like burning rubber
Good Afternoon Friend,
I understand that you are receiving a burning rubber smell from your Frigidaire microwave. I also see that your appliance will run for a couple of seconds, and then you hear a weird noise, followed by a burning rubber smell. I suggest contacting your local authorized technician, especially when dealing with your microwave. They will be able to diagnose your appliance and determine what is causing that sound as well as the burning rubber smell. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Microwave Ovens
SMELL OF DIESEL IN SIDE CAR
Smelling gases from outside usually means one of your rubbers have failed. Inspect all the rubbers on the firewall and the boot rubbers. May also be coming up from around the gear stick.
Mar 05, 2012 | Mazda 2 Cars & Trucks
Battery light on and a strong burnin rubber smell
SOUND LIKE ALTERNATOR SHAFT BEARING FAILING CAUSING ALTERNATOR PULLEY LOCK OR PUT DRAG ON DRIVE BELT CAUSING BURN RUBBER SMELL OR DRIVE BELT LOOSE CAUSES BELT SLIPPAGE MAKE BELT RUB AND BURN.WHEN YOU SMELL RUBBER BELT BURN SMELL WATCH OUT DRIVE IS GOING TO BREAK.
Aug 04, 2011 | 1983 Ford Fairmont
I own a 2003 chevy suburban with the factory am/fm cassette/cd player. has rds with the bose system. i have a problem with the cd player. it takes a number of trys for the cd to insert, it'll play the cd,...
This problem is caused by the cd tray either malfunctioning determined by the burnt rubber smell. More than likely, the tray that hold the cd or arms or whatever you want to call em, are off track or caught on something and the motor tries to move them and just spins the rubber belt which causes the burnt rubber smell. You will need to take the vehicle to a Chevy dealer to have them fix it or replace it cuz it probably is unrepairable. Or you could take it to any place that fixes cars and/or car stereos. But look on the bright side, this gives you an excuse to buy a new stereo that has a screen and everything. You could be "pimpin" lol. Good luck. I don't know how many times i've had this same problem with stereos. They always wear out.
Jan 13, 2011 | Car Audio & Video
How to remove rubber smell from rubber boots
Only time will do that. Rubber smells. Leaving them outside on the porch helps a little, but the smell will gradually fade over time. You can mask the smell briefly with fabreze, but this is not very effective. farmerbear at FixYa
Oct 07, 2010 | Health & Beauty
Hi I get a smell of burnt rubber,when I touch left side on silver part loud speaker ,my tingles like electric current thre
There's a short in your laptop. Open it and get it fixed quickly or you'll end up with fried, good for the skip, laptop.
Mar 03, 2010 | Computers & Internet
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
A smell of burning rubber is coming from my engine. What is it? Could it be the timing belt? Is it safe to drive any distance? Thanks I have a burning rubber smell in my Subaru 2003 Outback, - any...
Check serpentine belt, the radidator hose , the air conditioner compressor and also the differential seal they common cause for rubber smell.
Check for any rubber part that can be in contact with exhaust system and inspect wirings looking for shorts.
Also ensure that the smell is not coming from a bad tyre, and check for oil leaks in your engine, burnt oil can be confused with rubbere smell.
Mar 05, 2009 | 2003 Subaru Outback
Burning rubber smell and the dryer will not turn on
sounds like you need a new belt for your dryer, the smell of burning rubber is the belt slipping, thats my guess
Feb 09, 2009 | Dryers
Vacuum cleaner smells
A rubber smell usually indicates a belt slipping. Rubber belts stretch after a short while and will slip on the brush roll under load. Check also to make sure that the brush roll is turning freely.
Feb 10, 2008 | Vacuums
Seismic Audio 12" PA Speakers & Floor Monitors Logo
Top Seismic Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Seismic Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
