Question about LG DLEX7177WM SteamDryer Front Load Electric Dryer, White, 7.3 cu. ft. Ultra Capacity with NeveRust Stainless Steel Drum, 5 Temperature Levels, 5 Drying Levels, 9 Programs, TrueSteam Generator Produces Real Steam, SteamFresh CycReduces Wrinkles and Odor
I have a lg dlex7177rm and I have power to outlet but nothing lights up or works on dryer
The outlet has power but pressing power button has no results
  • 489 Answers
SOURCE: My LG dryer will not power up
You may have a broken door switch.  That would be the most likely source of your problem since the machine will not work if the computer senses that the door isn't closed.
Posted on Apr 28, 2008
  • 489 Answers
SOURCE: LG DLE 9577
check to make sure that the power legs are correctly installed.  Use an volt meter and measure voltage across neutral and hot.  Hot leads should be on the left and right side and neutral is in the middle.  Hot to neutral should be 120v.  Hot to hot should read 240v.
SOURCE: LG Trohm dryer will not power up. No lights, nothing.
Plug it in
Posted on Mar 01, 2009
heatman101
  • 43501 Answers
SOURCE: LG Model DLEX7177RM makes a
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Posted on Jan 03, 2011
heatman101
  • 43501 Answers
SOURCE: lg dryer wont heat up DLEX7177RM
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
May 04, 2014 | LG DLEX7177 Dryer
How do you take apart the LG DLEX7177 Dryer to fix it?
This link should take you to the repair clinic. Their videos are great. This is how I learned to get into mine. Good luck.
http://www.repairclinic.com/LG-Dryer-Model-DLEX7177RM-ID-882536-Parts
Apr 17, 2012 | LG DLEX7177 Dryer
LG Model DLEX7177RM makes a rumbling noise upon start up like a bad bearing or gear drive sound. Noise is cyclic at dryer spin speed. Dryer is only a couple years old. Are there any recalls, warranty...
heatman101
Asker
Jan 02, 2011 | LG Dryers
We were just moved by a moving company and my dryer worked the day before they moved it. Now, my LG DLE7177RM won't power on at all. We had our maintenance come and check the outlet, that's fine, we bought...
Sounds like damage was done to the control panel during the move. You will need a qualified LG tech to test the controls and see if the power button was broken during the move.
Oct 03, 2010 | LG DLE7177 Dryer
My lg DLEX7177RM dryer turns on but,when u push the start button,it dosent work,nothing at all.I have changed the main sercuit board and nothing?
Check the light switch to make sure it's working and check the belt to see if it's broken.
Good luck
Oct 01, 2010 | Dryers
Lg dryer wont heat up DLEX7177RM how do I reset the thermostat
heatman101
Apr 30, 2010 | LG DLG3788W Gas Dryer
LG DLEX7177WM SteamDryer Front Load Electric Dryer, White, 7.3 cu. ft. Ultra Capacity with NeveRust Stainless Steel Drum, 5 Temperature Levels, 5 Drying Levels, 9 Programs, TrueSteam Generator Produces Real Steam, SteamFresh CycReduces Wrinkles and Odor Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
