Question about Dell Inspiron E1705 Notebook
I want to hook my dell tower to my dell laptop to view the files
My desktop monitor broke and i need to get to the files on my dell tower. How can I hook my desktop tower to my laptop to view these files
  • 55 Answers
Not that easily, you would need to link the two together using either a bridged network cable or bridged usb cable, or by setting up a network using a router, but all of these require setting up on each computer, and seeing as you cannot see your desktop on your pc you can't do this.
I would suggest taking out the hard drive of your pc and purchasing a SATA/IDE to USB adapter set, this allows you to connect your pc's hard drive to your laptop via the USB port. You can then view all your files on the desktops hard drive as if its an internal hard drive on your laptop using windows explorer.
See here for an example of the adapter:-
http://cgi.ebay.co.uk/SATA-IDE-to-USB-Converter-Universal-Drive-Adapter-Cable_W0QQitemZ310115625798QQihZ021QQcategoryZ41994QQcmdZViewItem
Hope this helps.
Posted on Jan 26, 2009
  • Azz
    Azz Jan 26, 2009
    Just had a thought, You may be able to connect your pc to your tv depending on what outputs you have either on the motherboard built in graphics card, or on a PCI / VGA graphics card. The way you connect it will depend on the connectors.
  • 86 Answers
U can get a usb adaptor for your hard drive.
  • 3,940 Answers
Simplest answer is to borrow a monitor for long enough to copy your files off of the desktop.
You also might look for a used monitor if no-one will let you borrow one, Pawn Shops, GoodWill, Ebay are all good sources, old CRT monitors are plentiful and cheap
If for some reason, you can't to that, then you are pretty much limited to getting a USB HDD adapter and removing the HDD from your dell and using the adapter to connect the drive to your portable.
My Alienware M11X R2's screen broke completely off. I thought I could just hook up an HDMI cable and use the base with a monitor but it keeps beeping... and the video wont show up on the monitor.
Do you mean that the hinges broke and the screen is no longer attached to the laptop. I googled ' Alienware M11X R2 screen' and one of the first results is a story from PC World which contains:
"Dell will repair broken hinges on any Alienware M11x system for any R1 or R2 customer worldwide regardless of warranty status," wrote Dell's John Blain, in a blog entry on the company's website.
Sep 14, 2012 | Alienware PC Systems Alienware Aurora High...
I have files on my old gateway computer tower that i need. unfortunately, the monitor broke. I want to know if i can hook up my acer laptop to the computer tower so i can save the files on a flash drive or...
You have not mentioned the make and model of the laptop. Anyway, the easiest would be to connect the other monitor to your laptop and from a key that has a monitor and the LCD made on it you can view the laptop on the monitor and do your work. You can then save your data to any removable media.
Jan 22, 2011 | Computers & Internet
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Thankyou
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
I turned on the computer and blank monitor screen.
have you checked if monitor cables are properly seated? have you tried a different known good video cable? also try a different outlet for the power supply for the monitor. lastly, try a different monitor and hook it to your tower. if it has a good display, then you should replace monitor, if still it has same issue, thenyou may want to consider changing your videocard.
Apr 03, 2010 | Dell Inspiron 531s Desktop Computer
Hooking a PC to your laptop's screen
Unfortunately you cannot use a laptop screen to view output from other computer sources. As you are surely aware, you may plug another monitor into the VGA plug on the laptop to view the laptop's output, but the plug is only for the laptop's output.
Nice thought, though.
Sirwriter
May 23, 2009 | Dell XPS M1330 Laptop
Dell monitor black screen
If you have another monitor for desktop hook other monitor up then under hardware and software in control panel, add the dell monitor, then hook it up. Some operating systems need the driver to be added first. My brother almost threw away agood dell lcd monitor before I told him this, now he loves the lcd, works great.
Mar 09, 2009 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Dell Inspiron E1705 Notebook Logo
546 people viewed this question
Alun Cox
