Question about GE JBP24 QuickClean Electric Kitchen Range
The oven relay sticks.
Any source for just the relay instead of the whole panel?
My solution has been to smack the top of the console when I find it isn't shutting off. Not a reliable solution by any stretch. What I'm looking for is a replacement relay to avoid the cost of the whole panel ($200+). I'm a victim of the "Assembly Parts Plan." It doesn't appear that the relay has any number on it, unless it's on the side that assembles to the circuit board. For $200+ I can buy another range, which seems a bit less environmentally friendly than fixing this one!
Posted on Jan 28, 2009
After cleaning the control panel ribbon, the oven will not shut down (top and bottom ovens. Is this the thermal oven shutdown fuse that needs to be replaced? If so, how do I remove the fuse from a W
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
: I offer free advice bcuz God is so good!
Dec 28, 2014 | Whirlpool Ovens
Do I have to pull the whole double oven assembly out of the wall to gain access to the upper oven power relay board? MCS230S
On some ovens you have to pull the oven out of the cavity and remove the top panel of the oven to get access to the electronic timer control. On other ovens you only have to remove the panel which is behind the timer without removing the whole thing. Just slide it out a bit and have a look at the panel behind the timer.
Feb 16, 2011 | Dacor MCS230SS Millennia Electric Double...
My ge cafe gas oven light won't turn off
The switch which activates your light probably is stuck/broken in the on position.It should be similar to a refrigerator where you can see a small rod sticking out,or something that sticks out of the completely flat front of your oven with the door open.Sometimes there is an access panel,sometimes the whole panel comes off.The screws should be noticeable,almost flush on the front.Sometimes they are covered with a cap for appealing looks.Those just pry or unscrew off.
You will have to order the part.Even if it is expensive,there probably is a $50 minimum for a repair center just to show up.Then labor,20% minimum parts price markup also.Greg Pull the circuit breaker before messing with any wires.
Nov 17, 2010 | Ovens
I have a Thermador SC301 wall oven and the display has faded out. Thermador says I need to replace the whole control unit ($500 for the part!) Any cheaper fix?
I have just repaired two SC301 ovens myself, but it is alot of work. You can get the oven's LED lights reconditioned at a company called CGI industries. Look them up on the web and click on the link for thermador. Removing the led panel and oven relay board is an involved job, but easier if you do it the correct way. First, turn off the power to the oven. Then pull the oven out of the wall socket about 1 quarter of the way. Remove the top cover of the oven with a phillips screw driver. This reveals the oven relay board. Take a digital picture of the board to remember the wire positions, or alternatively write them down. You also need to remove the touch panel (two screws underneath) and gain access to the LED. Remove the LED panel and wires. ship both to CGI (boards only) and you will have them back in less than a week. Costs about $170 before shipping. Reinstall and turn power on. All is good.
Feb 08, 2010 | Thermador Ovens
I have a Kenmore gas built in oven, model number 790.30179400. It's 5 years old. I just used the oven and it wouldn't turn off. It seemed to be hotter than the temperature I had it on. I have a fuse box in...
Usually F11 is a comunication error and the initial fix is to remove all power for 30 seconds then try it again.
The oven element that did not turn off is a sticking relay on the Electronic Range Control (ERC) board /clock timer that did not open the relay electrical contacts when the power was removed from the relay coil. Or there was an on the printed circuit board (PCB) fault in the ERC that allowed power to remain on the relay coil until you removed power by pulling the fuse.
The most probable cause below with the cheapest source being Sears Direct in 2nd link.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-316418553-%3d%3di1064462&PartID=1064462
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=79030179400&productCategoryId=0125200&brandId=0582&brandDescription=KENMORE&modelName=GAS-WALLOVEN&diagramPageId=00001&componentDescription=CONTROLS&documentId=R0409085&blt=06
Thanks for using FixYa!
Kelly
Jan 20, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
After 3hrs self cleaning oven and 2hrs. of cool down. The countertop light will not unlock. How do I get the countertop light to unlock?
sometime a relay sticks in the solid state circuitry.
Turn off the oven breaker at the fuse panel for 10 minutes or so. The turn it on hit reset button or open button and this shoud unlock the door.
Nov 30, 2009 | Washing Machines
Rangemaster 110
i used the solution above worked great as i never used the clock anway . but instead of removing the whole hob i simply un screwed the front panel 5 scews. pulled the front panel out about an inch and used a pair of long nose pliers to remove the blue wires cliped them together. then just screwed the panel back took about 5 mins.
Nov 01, 2008 | Rangemaster 110 (Gas) Kitchen Range
Oven sensor
Open your oven door and look to the back and top , should see small metal bar sticking out held in by a couple screw. that is your sensor. Most of these can be change right from the front some you have to take the back panel off, just make sure that the connection on the sensor is all the way through the oven wall. And turn off power prior to working on range
Jan 30, 2008 | Ovens
Bizzare Oven
i will call ge technical and see if they have an issue after holidays would of you reply to me with a complete model and serial number
Dec 14, 2007 | GE JKP15 Electric Single Oven
GE JBP24 QuickClean Electric Kitchen Range Logo
90 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
