Question about Delta & Single Handle Shower Faucet
Adjust anti-scald delta B114900 - Delta & Single Handle Shower Faucet
Adjusting the anti scald is pretty simple on this device. Attached is a photo of breakdown for this. Basically, unscrew the labeled part to access a very small black rubber gasket. Remove the black gasket to gain access to the anti scald part. You have have to use needle nose pliers to remove the black gasket but it does come off. Once you have this part off, you will see the two parts (with teeth like a wheel) that will adjust the hot water levels. Remove the part on top and turn the little "handle" clockwise towards "3'oclock" to make the water hotter. The part itself will not allow you to go past "3 oclock" for safety reasons. adjust anti-scald delta B114900 - adjust-anti-scald-delta-b114900-ucghvzot5faznyh4jdqs4e5n-4-0.jpg
Posted on Nov 23, 2014
I have a Glacier Bay shower faucet that is getting increasingly harder to control water temperature out of shower faucet! Water temperature is very hot
check the hot water supply first and if needed adjust if to high and or check your anti scald setting --need to remove the center handle on the mixing valve
How To Adjust Glacier Bay Anti Scald Device Yahoo Video Search Results
Jul 31, 2017 | Glacier Bay Home
Just installed a delta model #B114900 in a new shower and the hot water does not get real hot. Before we replaced the old one it worked fine
Support Information
This link gets you to owners manual installation.
It wont let me copy diagram.
Step 7
You need to adjust the Rotational Limit Stop
The 1st position is default and allows the least amount of hot water into the mix. As you move it more clockwise it allows more hot water into the flow. If you move it all the way clockwise you have the greatest amount of hot water and run risk of scald.
Basically you have a faucet to help protect from scald if the handle should accidentally get rotated all the way to hot.
Apr 15, 2015 | Delta Home
I installed a single lever b114900 fauset i turn the water on and the water come out of shower head and fauset
I woke up to this problem this morning and was told by delta it could either be the cartridge or the check valves assembly. For me it was the check valves. The plastic developed a small crack. Very simple process to replace the parts.
Dec 04, 2012 | Delta & Single Handle Shower Faucet
The handle stops mid way between hot and cold. The water gets barely lukewarm.
Have you tried adjusting the temp control setting behind the handle. Remove handle and mark the dial or remember where it located and slide it out of place so you can move it counter clock wise maybe a 1/4" turn and put handle on and turn faucet on and check for hotter water.
It is a anti scald valve and it's preset to a certain temperture for safety.
Oct 05, 2010 | Delta & Single Handle Shower Faucet
Delta 13022 - Hot water out of the shower is much cooloer than out of the sink faucet. How is the mix of hot & cold controlled?
The Delta shower has a rotational limit stop designed so that when another fixture is activated, such as a toilet or dishwaser, the water does not go to extreme hot or cold. The reason for this is that the Delta shower unit is not pressure balanced or does not contain an anti scald device. The pdf document below will show how to adjust the water tempature if you feel it is too cold. Please use caution as it is probably set the way it is to prevent scalding.
http://www.deltafaucet.com/media/Product_Tech_Docs/Maint_Installation/50001to80000/51975RevH_4.15_15e05.pdf
Aug 03, 2010 | Delta T13420 Chrome Classic Single Handle...
& Single Handle Shower Faucet : how to adjust to get hotter water...
First step remove handle and behind it there is a dial that looks like a gear. Mark where it is and remove it and put back in about a 1/4 to 1/8 turn counter clockwise to increase to hotter temp.
These faucets are equiped with anti scald setting's to protect the public and preset for this reason.
May 17, 2010 | Delta & Single Handle Shower Faucet
No cold water
Anti Scald Valves have an adjustment under the handle (remove handle) to allow so much hot water in no matter how far handle is turned. Its possible that the adjustment is set to allow only hot water in, this of course defeats the purpose of anti-scalding. Check to see if you can adjust this back. Good Luck have a Great Day. Please give a 4 THUMBS UP if this free answer was of any help.
Apr 01, 2010 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
It will not go all the way over to the left, does not get as hot as I would like
Remove handle , behind it you should see a dail with teeth like a gear remove it and turn counter clockwise maybe 1/4 turn, mark where you start so you will have an idea.
It is a anti scald unit to temper water so you can manually adjust temp.
Jan 22, 2010 | Delta T13420 Chrome Classic Single Handle...
My delta 132900 gets too hot.
With these Faucets, you can remove the handle and make adjustments to the max Hot water setting (scald guard).
You may also have a faulty or lime-covered cartridge.
SEE THIS SITE for making adjustments/replacing the cartridge.
Thanks for using FixYa - a 4 THUMB rating is appreciated for answering your FREE question.
Aug 23, 2009 | Delta & Single Handle Shower Faucet
Delta & Single Handle Shower Faucet  Logo
1,919 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
