Question about GE Kitchen Ranges
Model jb6400 manual
Could the model number be jb6400
GET A MANUAL FOR MY SINGER ONE MODEL H12148A11110103
That looks like a serial number, not a model number. Here's a link to find your model number: http://www.singerco.com/support/machine-model-numbers
Once you have the correct model number, check the singer site for the manual. They have many free to download.
Oct 13, 2014 | Singer Sewing Machines
How to disassemble
Owner's Manual and Installation Instructions: Search Tips
  • Be sure to use the model number of your appliance to locate use and care manuals.
  • Model numbers are normally printed on tags located inside or on the back of your appliance. Find the model number on your appliance.
  • check to make sure you entered your model number correctly, or call 1-800-626-2005.
  • This search is for manuals for major appliances only. Manuals for small appliances and electronics are not included. Need to find manuals for other GE products?
Jan 10, 2013 | GE Dryers
I need manual for singer machine model #50t8 e99670
Singer Sewing Machine labels are printed in a confusing manner. E99670 50T8 is not the actual Model Number. The actual Model Number is the first 4 digits on the line with the Serial Number. In my case, the Model Number is1525, even though E99670 50T8 appears on the label at "Model Number". This machine was also labeled with other 4 digit model numbers too, depending on when it was manufactured. Using the Singer link for either free downloadable manuals, or paid paper manuals, search for the correct 4 digit model number and the resulting correct manual is there. Link below for manuals :
http://www.singerco.com/accessories/manuals.html
Sep 04, 2012 | Singer Sewing Machines
Find manual for tv?
model number is on label of TV on a label and serial number also usually there. To locate a manual GOOGLE the model number with "manual".
Mar 19, 2012 | Televison & Video
Looking for singer sewing machine manual g2048733 I believe it is 1911
The g2048733 is the serial number and was built in 1912, actually. (1911 is not the model number.) To get the manual, you need the model number. This should be on a plaque on the front of the machine; it may be just above the base on the belt side. (Singer made 40 models as of 1900.) If the plaque is missing, contact 1-800-4-SINGER (1-800-474-6437) to translate the serial number into a model number.
With the model number, you can get a manual here: http://www.singerco.com/accessories/instruction-manuals . Here you can download or purchase manuals depending on the machine.
If you add a comment with the model number, I will be glad to provide the direct link to the manual. I hope this helps.
Oct 30, 2011 | Sewing Machines
I want instruction manual for dishlex global 300 dishwasher
Happy New Year and welcome to FixYa, I am Kelly.
It took a while to locate the manual as there was not a model number. The model number I located was an Electolux DW300XA and the manual can be found here:
http://manuals.appliancesonline.com.au/dw300xa/dw300xa_product_manual.pdf
If this is not your model number, please respond wth your model number and I will look for the correct manual.
Thanks for choosing FixYa,
Kelly
Jan 01, 2011 | Dishwashers
Looking for MTD / Toro Leaf Blower (the manual) model #79DB/A or #TB320BV probably made in 2000 by Toro.
Hi and welcome to FixYa. I am Kelly. You will need both your model number and serial number but you can get a manual at the link below that you can print.
(Most model and serial number plates list the model number, then a dash / hyphen, and then the serial number.) There is no other source other than a Toro Distributor for Owner's manuals or parts manuals. You can look up on line replacement parts on numerous sites.
Manual: https://lookup3.toro.com/request/request.cfm
Kelly
Nov 12, 2010 | Mtd Garden
I have been given a Sanyo Fan Assisted Oven 1200w / microwave 900w but no instruction manual. Can you help?
We can most likely help you but need and exact model number so we can help you try and find you the correct manual.
I am going to post 2 links that you can use your model number to try and download a manual. In the case of these manuals if you have a model number that is close to your model number it will work for you.
http://us.sanyo.com/Customer-Support-Owner-Manuals-Locator
You will need your model number.
Also try here:
http://kitchen.manualsonline.com/manuals/mfg/sanyo/emc6786v.html
If you are in the UK you will need to use this link:
http://uk.sanyo.com/support/Instruction-Manuals/
Thanks for choosing FixYa.
Kelly
Aug 27, 2010 | Microwave Ovens
Goldstar VCR user manual
The model number is actually a Sears model number. The part number for the manual is L46-381253-3 and it can be ordered from Sears on this web page. When you see the PartsDirect web page, click on Part# in the upper right corner. Then enter part number L46-381253-3 to search for the manual.
Jan 20, 2008 | Televison & Video
Kitchen Ranges Logo
54 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
