Question about Maytag Dishwashers
Dishes not clean
Dishwasher is not removing food from dishes, and dishes are coming out dirtier than they went it. Some dishes will be perfectly clean and others dirtier than when they went in, sitting side by side in the same rack. Repairman initially blamed hard water and too much softening agent, but I used more soap and softening agent for the first 5 years of ownership and got perfectly clean dishes. I requested replacement of filter when no improvement and repairman found partially broken impeller, and clogged filter, but since that repair the same problem exists: up to 1/2 the dishes are dirty, or have food stuck to them that wasn't there when I orginally rinsed and loaded them.
  • chiafam Jan 26, 2009
    I use vinegar regularly and run the hot water before turning on the dishwasher - it doesn't help, unfortunately. I use citric acid cleaners on a regular basis (run without dishes in the dishwaser) to keep mineral deposits from forming - the inside of the dishwasher is clean and free from mineral deposits. It seems like a pressure problem, the water isn't hitting the dishes hard enough to remove the debris.
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem for the spots is hard water. There is a new product out at www.dishwasherfilter.com that solves this problem once and for all. It is a small filter that goes under the sink and filters out the hard minerals that cause these spots from the water before they enter the dishwasher. It is very affordable (like 70 bucks) and even has a money back guarantee. After just one load you will be amazed how your dishes look.
Posted on Aug 12, 2009
    Novelist:
  • 101 Answers
So I have a quite simple fix here for you and you will be happy that it won't cost you anymore money. On my profile I have a tip that includes this. What you will want to do is throw about a cup of white vinegar in the cavity and put it on a heavy wash. What the vinegar is going to do is clean out all the hard water deposits and anything else that may be stuck in there. You dishes will start coming out cleaner again. You can do this every few months or so and it will prevent this from happening. When I worked for Sears as a repair man I would always tell my customers this whether I was there to fix the dishwasher or not as it saved me a service call later. You can also do it in your washing machine.
Another thing you need to make sure you are doing is pre-heating your water before running the dishwasher. Just turn on your tap water and let it run till it is steaming then start the dishwasher. This could be contributing to the dirty dishes too. If you don't preheat the water first it takes the dishwashers heating element a long time to heat that water up. The result is washing your dishes with cold water for the first half of the wash. Let me know if you have any other questions and if this was helpful. This should work just fine for you, good luck and take care.
Posted on Jan 26, 2009
What causes grit to dry onto dishes after dishwasher has finished?
Check water hose leading to the dishwasher for deterioration..
May 11, 2014 | LG LDF6920ST Stainless Steel 24 in....
Indesit IDL 850 dishwasher: dishes in the top drawer ONLY are dirty: residues is left on and inside what is in the top drawer, so that they come out dirtier than when they went in. This is new: I have not...
If he Dishes Are Not Clean:
- Have you put the right amount of detergent into the dispenser?
- Is the wash cycle suitable for the dishes you have placed inside the
appliance?
- Are the filter and microfilter clean?
- Can the sprayer arms turn freely?
This is how the manual helps.
Jun 29, 2017 | Indesit Dishwashers
Why is my dish washer leaving food on my dishes that i loaded rinsed off?some dishes come out dirtier than i put them in there.
It is almost always because you have blocked the hole where the sprayer goes up through the middle of the dishwasher. If it cannot pop up the dishes will not only not clean, but the food will just deposit onto the dishes especially the upper rack.
Sep 30, 2010 | GE Crock Pots & Slow Cookers
I have used dishwasher cleaners, use Cascade Complete dishwahing detergent but all of the sudden, my dishes come out of the dishwasher dirtier then they went in. The glass glasses have a gritty stuff...
depending were you live they changed the formula in cascade,but they are doin a new formula are you using a rinse agent? claean the machine clean spray arms and soap dispencer,with no dishes run machine with 1cup of CLR or 2Cup of vinegar just pour in tub and let it run full cycle no drying.Thanks
Jul 31, 2010 | Whirlpool Dishwashers
Dirty dishes coming out of dishwasher dirty
check your drain line it should go up from bottom of d/w and then go down to drain that is so water from sink wont back up into d/w
Oct 27, 2009 | Dishwashers
Glasses come out dirtier than they went in to the dishwasher but other items clean OK
Remove all dishes and throw two cups of vinegar into your machine then run the complete pot scrubber cycle with the hottest water you can.
Always run the hot water into the sink until it is totally hot before you run your dishwasher.
May 20, 2009 | Dishwashers
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
Hard specs of food on dishes, they come out dirtier
Make sure you are starting d/w with hot water by running faucet. If you are, then it may be time for a new d/w. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | GE 24 in. Profile PDW7800 Built-in...
Not cleaning the dishes
You need to check your water temp after it enters the diswasher, it should be at least 120 deg when it get in the dishwasher. If it not then the detergent, food, and greese can't break down.
Jun 20, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Dirty glasses
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Sep 29, 2007 | Tricity Bendix 24 in. BDW53 Free-standing...
Dishwashers Logo
245 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
