Question about HP Compaq Presario CQ50Z-AMD Sempron(TM) X2 Dual-Core QL-60 (1.9GHz) , 15.4" diagonal WXGA High-Definit... PC Notebook
Need to know how to display the Laptop screen onto my Tv please?
Hi i recently got a laptop and was wondering how i got the screen of the laptop to display on my TV Screen
is there some sort of lead i need or something?
  • 86 Answers
You either need a Tv-Out card or an adapterTV Out box to connect the Laptop to the TV. Optionally if your Tv has a SCart connector(Google for what that means), you could connect the Laptop directly to the TV, instead of the adapter.
Posted on Jan 26, 2009
HEY
Hi, Simply attaching the cable isn't always enough. Sometimes you actually have to tell the laptop to display via HDMI or DVI onto your external monitor or it will not output any signal.
Try pressing Windows Key+P, this will change your presentation settings in Windows (What screens you get a display on and how they are displayed). Cycle through to either "projector only" or "duplicate screens" and see if you get a display on your TV then.
Mar 20, 2014 | Philips 42PF9630A 42 in. Plasma Television
Can someone please help me get my laptop working through HDMI cable onto TV on a sony VAIO VGN-FW23G. I need to know the process to do this
1. Check the computer for changing output (some computers use <F5>, <F8>, depending on which brand they are. I believe Sony uses <Function><F7> or <F7>).
2. Check what channel the HDMI port is on (e.g. AV1, HDMI1, HDMI2, etc.) - you need to know this if your TV doesn't automatically switch to the new input.
3. Plug the HDMI cable into the TV HDMI cable-in port.
4. Plug the HDMI cable into the laptop HDMI cable-out port.
5. Turn on the computer.
6. Press the <Function><F7> simultaneously ONCE. The screen should flicker and show up on TV.
7. Sometimes you may have to go to "Display Preferences" and select Dual Monitors or external monitor if your computer doesn't do it automatically. Repeat Step 6 after.
** You may have to adjust Display Resolution to 1024 x 768 or lower in order for the TV to work. After it works at a lower display (800 x 600, for example), you can adjust the resolution to the maximum the TV can accept.
Oct 26, 2012 | Fujitsu Computers & Internet
How do I conect my Acer aspire 5750 lap top to my sony hdmi tv. I have recently brought a VGA cable that allows me to connect my laptop to my tv. The problem is that everytime i connect the tv and the...
"Out of range" means that the picture displayed by the laptop cannot be displayed by the TV, either because the resolution is not supported or the refresh rate is not supported.
Sometimes, I've had to set the refresh rate (from the laptop Display settings) to 59Hz to get it to work as opposed to the default 60Hz.
What resolution does your TV support? What resolution does the laptop support?
Matching these as closely as possible and you'll get the picture on the TV screen.
Good Luck and let us know how it goes,
-BuzzPuppy
Apr 30, 2011 | Acer Computers & Internet
I connected my hp laptop to my pioneer plasma via svga cables. When i select my pc input using my tv remote it says "plasma display no input signal". How do I fix this?
Hello. You have to go into your Display Settings, in your HP Laptop, and chose the Dual Screen/Monitor Setting & make sure you check the "Extend my Windows Desktop onto this Monitor" Box. If you are trying to view your Internet Browser on your TV - you will need to Click on and Drag your Browser to the Right... of off your Laptop Screen and onto your TV Screen. This will take care of your problem!
Jan 11, 2010 | Pioneer PDP-5071HD 50 in. Plasma HDTV
No image on hdtv
First off, is the tv set to use the hdmi input? if not, change tv to hdmi input and try again. If still no good, you likely need to tell the laptop to use the hdmi connector. Try this:
  1. connect hdmi from laptop to tv and select hdmi input on tv.
  1. while holding the blue fn key (bottom left side of kbd) press and release the F5 key. This will toggle the laptop between the laptop lcd display, external connectors (vga/hdmi), or both simultaneously. Let me know if this works or not.....
Aug 08, 2009 | Acer Aspire 6930-6455 Notebook PC
Fix ressolution on aspire to fit 720 pixel tv
Connect the laptop to the TV and use the keyboard toggle to switch screens.
Once the display is shown on the the TV go to the control panel and select display, set the screen resolution to 1024x768 and your display should be fine.
If you need anymore help or advice please post back.
Regards.
Aug 01, 2009 | Acer Computers & Internet
About my MPC T3000 Laptop
there should be a button like f4 that switches hold down the fn key & press the key with the 2 screens on it.
Jan 16, 2009 | MPC Computers TransPort T3000 Notebook
Black striped down left hand side of display
Hi Danny, you haven't been very clear I will assume you pushed the auto configure on the monitor,
I would go into the menu on the monitor and reset the size of the screen if it has a setting for that 1024x768 should fix the problem
let me know what you find as I have never worked with a hp W19 monitor, if nothing else set the monitor to defaults again in the menu and that may get you back to having normal screens.
L8r
Nov 13, 2008 | HP w19 19" LCD Monitor
Laptop
You gotta go to system preferences and click on display then click on detect display settings. its should work. if not press F7 after clicked on detect displays
Nov 06, 2008 | Computers & Internet
USE LAPTOP ON TV & LAPTOP AT THE SAME TIME
dear sir
yes i can help u strongly... first of all u have to turn of laptop then connect yr laptop and tv then turn laptop on now when windows appeair. laptop screen has icon and other has plane wallpaper so now go to display propaties ( click on desktop>go to propaties>setting> now it's show's 2 monitor screen on display screen click in inditeficate... how it's show "Expand display " somthing like that just remove select earrow now click apply... if it's not worked go to advance then go to adaptor setting and find display setting and select "CLONE" it's male both laptop and tv screen as same...it's help u...:)
Thanks
please vote
jo_chinmay
Oct 06, 2008 | Toshiba P000347580 - Satellite 1400&2400...
HP Compaq Presario CQ50Z-AMD Sempron(TM) X2 Dual-Core QL-60 (1.9GHz) , 15.4" diagonal WXGA High-Definit... PC Notebook Logo
133 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
