Question about GE Ovens
K250R4WH burner broken - GE Ovens
Maytag double electric oven. we turn on to bake and would switch to broil then will turn off.
Assuming this is on a gas range, the bake burner ( under the oven floor) and the broil burner ( at the top of the oven) have electric igniters . When switching from bake to broil the broiler goes off due to a defective or broken broil igniter. cheap part to replace ( +-$40.00)
Oct 16, 2014 | Maytag Ovens
Broken stove knob
simple flame sensors at fault eg thermocouples replace bad sensors and dsi box (direct spark ignition )
Apr 01, 2014 | Ovens
Burner element broken
Hi friarjp - I am happy to assist you. First, I will need your model number to better address the issue at hand. With this information I can verify which part you need exactly. Is it the right, left, back or front burner element or are you referring to the bake and/or broiler element.
Jan 18, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
It looks as though the pilot for our Maytag oven is out. The burners are working fine. Could it be the thermocoupler, and if so, how do I identify it?
It is rather unusual for an oven these days to have a standing pilot, (and thus the Thermo Couple)
Are you sure yours doesn't have a glowing ignitor to light the gas?
Usually there is a separate ignitor and burner for broil, and a separate one for the Main oven burner-
Can you see the ignitor glow on one or the other burners?
If the ignitor is broken-- you can not get the burner to light
Do yo want to try changing the ignitor?
Let us know more about what you have--
Mack B
Jan 23, 2011 | Maytag CWG3100A Gas Single Oven
Gas oven not working. burners work. not
The holes may be plugged with residue. With the oven off! Try taking a paper clip and unplugging the whole. Make sure the ignitor next to the burner tube is secured and is not broken. These are under the bottom oven plate. Most models.
Sep 04, 2009 | Maytag Ovens
I have a Maytag gas oven that I bought in 2001 and
It could be the safety cut out is broken? or not in the pilot flame. You could carefully check to see if the little probe is close to the burner and hasn't been knocked some how?
Otherwise you may have to call a gas cooker specialist . . Sorry.
Jul 29, 2009 | Ovens
Maytag65300ddS My burners wont turn on,. Clock
Sounds like an open connection between the supply circuit and the burners. Could be corroded, burned, broken, or just loose. Also could be a bad/cracked resistor in the same circuit.
I suggest a service call.
Apr 21, 2009 | Maytag MEW6530D Electric Single Oven
Kenmore smoothtop model 911.9554590 duel size burners
the inner burner is broken so the whole thing needs to be replaced. check your owners manuel for warrenty times on the burner. otherwise just replace the burner and that will solve your problem..
Mar 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Hotpoint oven glowbar not working
My oven glowbar stopped working christmas morning. Yesterday we bought a whirlpool brand (igntr-oven #4342528) because it is twenty something dollars cheaper then GE. My husband installed it today. The only difference is you have to splice the wires (it comes with everthing you need) The first time he put it in it did not work because he had the wires backwards. He switched the wires and now its working fine.
My oven is two years old also.
Dec 27, 2008 | Ovens
Trouble Shooting
I hope by now it is working. You have probably knocked a wire off or actually have broken the burner itself. Can you check it for continuity.It may not appear to be broken but the coil on the inside may be depending on how hard the board hit the element.
Apr 16, 2008 | Kenmore 47783 Electric Single Oven
Ovens Logo
19 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
