Question about Konica Minolta magicolor 5430 DL Laser Printer
Tray Jamming When I try to print out a photo on lazer photo paper the tray jams,I try removing the paper and using just one sheet and sometimes it will print, very annoying.
  • 32 Answers
Sounds like the rollers are having issues. You could call the manufacture and get a local repair shop to switch out the rollers for you.
Posted on Jul 19, 2007
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Constant paper jams
find some hard paper like trancparency plastic paper or some hard type paper leke certeficate printing paper and by opening the tray out and push the paper till u see it out around the touner cartirage place after doing so replace the tray and the toner cartirage hop the printer do not paper!!!
Apr 24, 2013 | Kyocera Mita FS-1030D Laser Printer
I have an epson printer and when I hit print, the paper slides right thru & says paper jam
  • Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
  • 2
    Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
  • Sponsored Links
  • 3
    Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
  • 4
    Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
  • Performance Chip
    May 22, 2012 | Epson NX415 All-In-One Printer
    My Brother HL-5740 Is jamming after every print jog. It's pulling two sheets through, the first sheet with the print job and the second sheet clear, Its like every job has two sheets. The second sheet...
    You probably need to clean the paper pickup roller above the paper tray. A clean cloth dipped in diluted kitchen detergent and a couple of drops of alcohol, will clean the rubber rollers. Stroke the cleaning cloth firmly from side to side all the way around all the rollers. Also clean the paper separation shoe (rubber pad) at the front of the paper tray. The last thing is to make sure your paper is dry. Damp paper sticks together
    Oct 16, 2017 | Brother HL 5140 Laser Printer
    My laserjet 1020 develops a paper jam after printing the first page of a multipage print instruction .I have deleted the printer and re-installed it including all drivers but problem still...
    Reinstalling the printer is related the Software.
    If the paper gets physically jammed than its the driver setting issue or hardware issue.
    Check if two sheets get jammed or only one sheet.
    If it is two sheets than printer is picking up multiple sheets and paper gets jammed.
    If the printer is jamming a single sheet than remove the Tray and look there is rubber roller inside if there are marks or lines on that rubber roller or if the roller roller is worn out than that rubber roller called as paper pickup roller need to be replaced.
    If that looks fine than try to priny using manual feed and if the problem persists from manual feed too than try another toner cartridge
    If the problem is not from Manual feed Tray that Replace the main Tray with known good Tray and check if the issue resolved.
    Jul 01, 2009 | HP LaserJet 1010 Printer
    Kodak 5300 paper jam
    What kind of paper is jamming?
    The paper could be too thin, or too thick.
    Have any young children visited you recently?
    My neighbour's grandson thought the paper tray was a great place to hide his Oreo cookie and gummy bears. The crumbs on the roller made the paper wrap around inside. It was cheaper to buy a new printer than pay for a tear down. This happened to my neighbour over Christmas.
    Check for spilled ink inside the cartridge area.
    If Ink has dripped down on the rollers, that would jam the paper. This would only be an issue if anyone moved the printer. Could your cleaning person have done this? It happend to me, once.
    Have you checked the slider that adjusts for different paper sizes?
    It could be putting too much tension on the paper and throwing off the timing of the paper travelling through the printer, so the sheet is in the wrong place at the wrong time and jams up.
    Is it 8.5" x 11" photo grade inkjet paper or 4" x 6" photo paper?
    Before I print, I check that the paper type setting matches what is in the tray. If it is letter size premium photo paper, then I choose that paper in the printer settings. If it is premium letter size paper for documents then I choose that paper, so the printer can adjust itself to the paper.
    Are you using recycled paper?
    My Kodak, HP, Epson, and Canon printers jam. Recycled paper really screws up my machines. I don't like it and can't use it.
    Do you have too much paper in the tray?
    Try 5 or 10 sheets only in the tray to see if the amount of paper was the culprit.
    Have you tried a different package or brand of paper?
    One time a package of 500 sheets of HP inkjet wouldn't go through my KODAK , but worked fine in
    the other printers. The next package of HP paper worked fine.
    How long has the paper been out of the package and sitting in the printer?
    Try fanning the paper.
    Has the humidity in your area drastically changed in the past week?
    I have to keep the paper sealed in the original package. Inkjet paper out of the package is affected by humidity where I live. Winter heating causes out of package paper to collect static and stick to the rollers. Summer temperatures with high humidity causes out of package inkjet paper to absorb moisture from the room. This humid paper sticks together.
    Is the paper meant for a photo copier or laser printer/copier?
    I get lousy results with non-inkjet paper in every brand of injet printer I use.
    Is it Brand name InkJet paper, like Kodak, XEROX, or HP?
    I stick to brand name inkjet and photo paper. Dollar store paper always jams in my printers.
    For Document Printing I use either:
    Kodak's 24 lb Ultimate Inket Printer Brightness 98 paper,
    XEROX Premium Inkjet Brightness 98 24 lb,
    or
    HP 96 Brightness Premium Inkjet Printer 24 lb paper.
    For Photo Printing I use Kodak's Ultra Premium Photo Paper, and adjust the printer's settings for it.
    Jan 05, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
    When printing paper continues to jam.
    1. Take out paper tray 1.
    2. Remove any jammed sheets of paper you find there.
    3. Once you have done this, reinstall the paper tray and try printing again.
      Note: You may receive a message informing you that another sheet of paper is jammed elsewhere in the printer. If so, please open the front door and remove the toner cartridge. Also open the rear door of the printer (and the duplex option if a duplex unit is installed). Remove any and all jammed sheets of paper you find. Then try printing again.
    4. If the printer jams again with a 241 Paper Jam error message, look to see if it has tried to feed a sheet of paper out of the tray.
    Dec 16, 2008 | Office Equipment & Supplies
    Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
    Hope this helps....
    Explanation of the paper jam message
    A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
    NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
    Clearing the jam
    To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
    Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
    NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
    For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
    NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
    Remove any jammed sheets of paper you find and try printing again.
    Dec 12, 2008 | Lexmark T640 Laser Printer
    My kodak easyshare5300 is printing black picture
    Hi-
    If your product is still within the warranty period from KOdak then you can call them up for some step by step troubleshooting to help you with your problem and as well they can replace the printer if defective.
    Try this first
    Calibrate your printer, then print a demo sheet.
    1. If paper is in the photo paper tray, remove it.
    2. Load photo paper into the photo tray.
      1. Fan the paper to keep the sheets from sticking together. IMPORTANT: Do not overload the photo tray.
      2. Load a maximum of 20 sheets into the photo tray, with the Kodak logo facing up.
    3. Calibrate your printer.
      1. Press Menu.
      2. Select Calibrate Printer, then press Start.
      3. Wait for your printer to print the calibration sheet.
      4. Place the calibration sheet face down on the scanner glass.
        • For the 5300 AiO printer, place the sheet on the front right corner of the scanner glass.
        • For the 5500 AiO printer, place the sheet on the left rear corner of the scanner glass.
      5. Press Start.
      6. Wait until "Calibration complete. Remove calibration page from scanner glass. Press OK to continue." appears on the LCD display.
      7. Remove the calibration sheet from the scanner glass, then press OK.
    4. Print a demo sheet.
      1. Disengage the photo tray by sliding it towards you until it stops. When the photo tray is disengaged, the main tray is active.
      2. Select Print Demo Page, then press Start.
      3. Wait for the demo sheet to print.
    Then call them if issue Persist at these numbers:
    In the U.S. and Canada: 1-800-421-6699
    In Australia and New Zealand: 1800 793 895
    Thanks for using Fixya!
    Jun 21, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
    RECURRING PAPER JAM - BROTHER MFC 5860 CN
    I just bought the 5860 and have this issue right out of the gates. I discovered that the back lid causes the paper jam when using the bottom tray while examing with a flash light during a print job. I dislodged the back plate/lid (same lid you remove to pull paper jam out) out about 10mm and fastened the lid loosely to the back with a piece of tape on each side. The paper from the bottom tray does not slam against the back of the printer any more, thus more freedom of movement and no jams. Just successfully printed an 80 page document. You shouldn't have to do this with a new printer but I got it so cheap with all the rebates that I'm going to keep it and live with this fix. To sum up, the problem is a design flaw where the removable back plate is snapped in too tightly and contacts the bottom tray paper roller (& paper) during a print cycle. To fix you need to clear the path by pulling the back lid out slightly and taping each side with scotch tape to 'suspend'the back plate out about 10mm.a5999d3.jpg
    Feb 02, 2008 | Office Equipment & Supplies
    Konica Minolta magicolor 5430 DL Laser Printer Logo
    50 people viewed this question
    Top Konica Minolta Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Adorjani Laszlo
    Ben
    Ben
    Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
