Question about Dell ST2420L 24 inch LCD Monitor
The resolution of my monitor is set in 1920X1080 and the images does not take all of the screen.
I use Windows 7.
2 Suggested Answers
  • 902 Answers
SOURCE: I purchased a Dell ST2320L
thats really odd that windows 7 doesnt give you full screen but the game does? change your resolution settings around to see if that helps altho i doubt it. check menu settings on your monitor and see if you can change its aspect ratio
Posted on Mar 23, 2011
Hi,i actualy bought an aoc 2243fw2k led monitor,i hav a nvidia geforce 220gt graphic card,even though i installed the latest drivers for both graphic card n the monitor,i stil cant experience high...
1920x1080 resolution is the starting point for HD video. If you have set your desktop resolution to that or anything avove then you should be running at HD resolutions. Maybe the image/video you are watching is not at a HD resolution, therefore it will appear distorted and streched (poor quality). To fully experience HD playback use video files and imaged that are at the 1920x1080 resolution and above.
Dec 16, 2011 | Computers & Internet
I purchased a Dell ST2320L monitor. When I am in Windows, there are black bars on the top and bottom, as well as the sides. When I am gaming, however it is full screen. How do I adjust the monitor in...
Mar 23, 2011 | Dell ST2320L Monitor
I continully receive a message of the screen is not in optimal mode of 1920X1080. I have gone to the screen setttings and have applied this yet I continue to receive the message when I go to play a game....
Your game does not natively run at the same resolution as Windows. Check the video/graphics settings in the game itself to adjust the resolution to 1920x1080.
Note that increasing the resolution to this, will drastically increase the load on your graphic card.
Feb 26, 2011 | Samsung SyncMaster 2233SW Monitor
How do I set my HP S2331 Monitor to recommended setting of 1920x1080?
Hi!
First, make sure you have the latest driver for you Display Adapter.
Next, follow these instructions on how to change the screen resolution:
* Windows 2000/XP
* Windows Vista/7
Best regards,
Pelu.
Aug 18, 2010 | HP Computers & Internet
Using an external monitor with 1920x1080 resolution in my laptop
Well IF the Drivers support it then YES you can. Simply, make sure that the setup, is dual monitor, with extended desktop, active. Now, go into properties, and click, on the external screen, IF you can set this resolution, to what you wish, you will be able to do so. Both Monitors Do NOT have to be the same, usually, a laptop['s screen, resolution, isn't that large, but certain, screens and drivers, can support this. Ensure you have the most up-to-date Video drivers, for your Card.
Apr 04, 2010 | Dell Inspiron 1150 Notebook
1920x1080 resolution-entire screen not viewable
This also happens to my vga connection to my TV.
I used my tv remote "auto" button to re-size it to fit correctly.
If your monitor/TV does not have the adjustment, you may need to
supply your vga compatible device with your monitor's driver software.
This tells your computer what monitor specifications you have.
Mar 16, 2010 | ViewSonic X Series VX2260wm 21.5"...
Screen monitor images on the righ side is not showig.
Hi afcarrillo,
This could be a simple resolution problem. By that I mean that the resolution is set too low, therefore putting things off screen. Here's how you change the resolution:
Windows XP
Right click the Desktop and select Properties. Click the tab all the way on the right that says settings, and drag the slider to your native resolution of 1600x900
Windows Vista
Click Start, Control Panel, Appearance and Personalization, Personalization, Display Settings and drag the slider to 1600x900
Windows 7
Simply right click the desktop, select Screen resolution and pick 1600x900
If you do not have a resolution problem, then it's most likely the monitor itself. Most often times you can fix it one of two ways:
1. Some monitors have a button that says "Auto" which will auto adjust your monitor. If you have one, try it.
2. If that didn't work or you don't have one, go through the monitor's OSD (on screen display) and work through the settings so that you can manually adjust it and set it to your taste.
Hope this helps :)
Nov 29, 2009 | Acer Computers & Internet
1920x1080 Resolution Problem
less resolution that is way to high for this screen size
Jun 16, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Dell ST2420L 24 inch LCD Monitor Logo
21 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
