Question about Denon AVR-1403 Receiver
Denon analog only - Denon AVR-1403 Receiver
In cable / sat mode accidentally switched to analog in stereo. i have 5 surround sound and can not get any sound. how do i get out of analog and stereo - i have a denon avr 1911
Carefully examine the front panel indicators for status of switches you DON'T want active.
http://www.retrevo.com/support/Denon-AVR-1911-Receivers-manual/id/23695ci376/t/2/
Register and download it for free at retrevo.com
See Page 17 and consider how the digital audio is assigned (page 46).
Feb 13, 2011 | Denon AVR-1911 Receiver
Denon avr-1804/884, speakers Bose vcs center, Bose acoustimass 5 series 3 speaker system, Bose 201 series 4. All speakers play in test mode, with tuner, dvd, phono, cassette. The left side speakers will...
You don't say how "TV audio" is entering the system.
My guess is you're using analog audio Out from the TV into an analog input on the Denon. One channel failing would probably be the Left Channel cable failing or not seated.
I always recommend bypassing the TV audio entirely if the programming comes from somewhere other than its own antenna, as TV audio electronics add nothing good to the process.
If you're using cable box, sat box, game, whatever, ITS audio is best sent directly to your Denon's specialized audio hardware - digitally, if possible, to preserve multichannel possibilities.
You could also run standard analog audio from the cable box to the TV analog Audio IN if you just want to watch news and weather on TV speakers without the Denon involved.
Jan 11, 2011 | Denon AVR-1804 Receiver
I have a Denon 2800 hooked up to a Pioneer DV-C302D and while DVD's thru the Denon, the sound will come on and off. At the same time the Denon will be switching between analog and digital mode. Is one of...
It's a cable or connection.
The Denon apparently has an automatic selector to choose the digital input over the analog input if both are present (my Pioneer does this). The random switching is telling you the digital input is intermittently dropping out and coming back. You don't say if you're using the optical or coaxial digital interface. Coaxial is less prone to connection problems. If you use optical, make sure the ends are clicked in and there are no small radius bends in the cable. Tight curves reduce the optical power. Either way, check the connections and wiggle them to see if you can cause the problem to return.
Jan 18, 2010 | Denon AVR-2800 Receiver
Can't record out from a digital input
It only passes the signal it see's. Digital for Digital and Analog for Analog. Try running a Standard analog RCA from your Cable box to the receiver then try and record. Hope this helps. If you still have an issue, post a comment and I can help you further.
Sep 18, 2009 | Denon AVR-3803 Receiver
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
How to get DVD to switch from Analog to HDMI ?
Read this: http://reviews.cnet.com/av-receivers/denon-avr-888/4864-6466_7-32740020.html?messageID=2561222 Including the comment below it. Also troll here; http://www.avsforum.com/avs-vb/showthread.php?t=944567 Then join, and post your issue. Guaranteed someone there can help.
Jun 09, 2009 | Denon AVR888
Denon AVR-1403 receiver switched from digital to analogue.
There are three modes (Auto, DTM, and PCM) on the input mode switch, on the main unit, selected by repeatedly pressing the input mode switch.
However, if you have already depressed the Analog button in, on the main unit you have predetermined the mode as analog.
On the remote, the INPUT MODE switch combines toggles for 5 choices, [Auto, PCM, DTS, Analog,
Ext. input]
My guess is that either the input mode switch on the main unit and/or the remote are toggled to analog.
Apr 11, 2009 | Denon AVR-1403 Receiver
Selecting a Blu-Ray Player
If Denon blu ray has coaxial or optical out for audio, then your Denon receiver will process this signal and will give you 7.1 out sound.
Jan 24, 2009 | Denon AVR-4802 Receiver
Denon avr-1905
Yes...and no it's not worth saving,,,,don't ever buy another Denon....! Worst Warranty, Worst Tech Support!!!! Cheap units...
Nov 28, 2007 | Denon AVR-1905 Receiver
Denon AVR-1403 Receiver Logo
27 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
