Question about Haier Energy Star ESA3183 Air Conditioner
3 amp fuse blows after three hours on Goodman 4 ton 16 seer pump
I have the Model# MBE2000 & CAPF4860D6A 16 seer 4 ton heat pump. After two-four hours the heat pump blows the fuse on the circut board in the indoor unit. Is very annoying. I have been replacing these 3 amp fuses at a rate of 5 per day. Started satruday when temps were down in 20's. Furnace runs normally untill the fuse blows then shuts off. Circut breakers are not tripping or anything. Tried to un plug the hudistate and that didn't help. Please any help would be nice. 50 degree mornings ****.
    Problem Solver:
  • 17 Answers
I would suspect you have a problem in the defrost circuit of your heat pump. there are a couple of things you can try. first just run the system on emergency heat and see what happens. you could have a defrost board that is shorting when it kicks into defrost. it sends a signal back to the furnace so it will come on during defrost. if you do not blow a fuse as long as you are running in emergency heat, i would suspect the defrost control board. also you could have a dead short in the wire that runs from the "w" terminal on furnace control board, out to the heat pump. keep in mind that any of the wires could be the cause and i am just tying to give you the most common things. your furnace will still run if you unhook all the low voltage wiring out at the heat pump. if you do this and stop blowing fuses. you know it is something on that wiring. goodl luck.
Posted on Jan 27, 2009
GOODMAN HEAT PUMP MODEL GSZ 130481AF: freon or R410????
That would be a 13 SEER 4 ton HeatPump using R-410a
Aug 20, 2014 | Heating & Cooling
3a fuse blowing on the blower motor board
The 3 amp fuse blowing indicates some control function is either grounding out (probably a worn insulation on control wire) or one or more of the solenoid controls is pulling more wattage than it is designed to draw. The solenoids for the main contactor and reversing valves should only draw about 0.1 to 0.25 amp. Any more than this the solenoid overheats and causes the control fuse to blow. I have actually had to replace the thermostat wire on some units because the control that was pulling more than designed caused the entire length of thermostat wire to overheat and break down the insulation, causing the control wire to short to the common wire or others and cause more than required operations to occur simultaniosly. One unit had a short and emergy heat was coming on the same time cooling was on.
Feb 23, 2014 | Goodman Manufacturing Goodman GPH1348H41...
I would like to know how to replace the heat strips in an Amana GPH1330M41 unit
Buy a heat kit from a Goodman dealer. Check that your existing wire will carry the amp load.
Jan 17, 2014 | Goodman Manufacturing Goodman GPH1330M41...
Blows little heat
Check the filter & indoor coil...could be plugged up.
Dec 13, 2013 | Goodman Manufacturing Goodman GPH1360M41 5...
Goodman package unit heat strips will not turn on
Put meter probes at in put terminal of the element if you read 220volts that mean your relay is good. if you got it there use amp meter on one leg of that element. You should read some amp draw there but if there is no amp draw it mean the element broke.
Nov 29, 2013 | Goodman Manufacturing Goodman GPH1530M41...
What seer is my goodman cl 30 1 fb and how many tons is it
If this is the model number of the unit, it would be a 2 1/2 ton unit. The seer I couldn't tell you with out seeing the manual. Could be a 10, 12, 13, cant tell with this information. Sorry.
Shastalaker7
A/C, & Heating Contractor
Feb 18, 2011 | Heating & Cooling
I have a goodman gmnte with a 16 seer ac, just
yes in the air handler the blower will have possibly 4 wires the ones you are needing are red blue and black1 will go to a relay or possibly a circuit board and the other 2 will capped off, black is high speed, blue is medium, red is low, most come from factory on med.
Aug 11, 2009 | Heating & Cooling
1997 Amana 2 or 2.5 ton heat pump, 13 seer - air handler only blows 4-5 min
do you have a totaline t-stat. they and some other brands have a fan recirculation setting in the installers menu.
this is assuming that this happens in addition to the heating or cooling normally
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Haier Energy Star ESA3183 Air Conditioner Logo
833 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
