Question about AM Auto Parts 2000 to 2001 VW Passat Mass Air Flow Sensor for L4 1.8L Turbo Eng
VW 2001 PASSAT: CODE PROBLEM P0600, P0030, P0135
How do you fix a code P 1506 ?
Hi Joel,
Here's what you were looking for. Idle Air control valve
http://upkeep.us/OBDII/OBD2/Ford/piart.php?art=5282
2.3L 2002 Ranger part page for reference & repair video. Same engine, etc...I do not work for Rockauto it's just a part/price reference.
http://www.rockauto.com/catalog/x,carcode,1372676,parttype,6072
Repair video
https://www.youtube.com/watch?v=iQr6E9Z7sg4
FYI, video for IMRC shows issues which are sometimes related.
https://www.youtube.com/watch?v=qLqpQeIJXek
PEACE
May 09, 2014 | aFe 2001 Ford Ranger - 2.3L 4-cyl. engine...
Abs light on on the dash and a motor under van stays on when key is off
the motor you are hearing could be the abs pump. abs light will not come up on a code reader for engine as its classed as body part. if it is this pump then the system is faulty and the pump running can mean that it has a broken fin inside you cannot fix this part and another abs pump will be need to fix this.
Mar 11, 2014 | EBC Brakes 2001 GMC Safari - AWD, without...
Check engine light
The PCV system in the 3.6 is a cyclonic separator (like a Dyson vacuum) integrated into the valve cover on the passenger side. It can get clogged, but it's rare.
Nov 08, 2013 | aFe 2006 Volkswagen Passat - 3.6L V6 - Air...
Temperature Coulant Sensor
Under hood, driver side, upper engine area, mounted in end of cylinder head
Jul 15, 2013 | AM Auto Parts 2006 VW Touareg Mass Air...
Code p1330
I would say the problem is with bad fuel or a bad knock sensor.
May 14, 2013 | AM Auto Parts 2000 VW Passat Mass Air Flow...
What hydraulic oil should i use for convertable top motor
You can use any hydraulic fluid. It is usually about the same as a 10 W oil
May 06, 2013 | AM Auto Parts 1996 to 1999 VW Cabrio Mass...
AM Auto Parts 2000 to 2001 VW Passat Mass Air Flow Sensor for L4 1.8L Turbo Eng Logo
94 people viewed this question
Top AM Auto Parts Air Purifiers Experts
David Payne
David Payne
Are you an AM Auto Parts Air Purifier Expert? Answer questions, earn points and help others
