KV-36FS10 resistor R546 burned can't read color bands, please he
Tv KV-36FS10 Sony .
Resistor R546 need color bands or value.
Please help.
  • advisers Feb 02, 2009
    Thanks a lot.
    Very good service!
    Best regards,
    Advisers.
    Genius:
  • 2,035 Answers
Please click on this link and download the service manual for 5$ which contains the parts list ..
http://www.e-servicemanuals.com/product-search.php?searchfld=KV-36FS10&SearchBtn=Search
Good luck...
Posted on Feb 02, 2009
    Sergeant:
  • 250 Answers
R546 vale is ---------1.8k 10k.
  • 19,396 Answers
Try downloading the service bulletin from website below, there you should find part list with r546.
To download the file, please, click here
WHAT IS THE VALUE OF RESISTOR R10 IN THE CIRCUIT BOARD?
Look at the color bands, they will determine the value. Last band color is the precision value of the resistor. You can find the color band values on many websites. The size of it tells you the wattage raring.
Mar 02, 2015 | Compaq CV 7500 17" CRT Monitor
I got this one dead. There is a burnt resistor on the main circuit board ( the one with the on/off sw). Would anyone know what value it could be.
You can determine the resistors value by reading the color code bands that are marked on it. The following picture is an example of the color codes and there values.
To show you how to read the color codes on a resistor, I am including a link to a video that will explain how to do this easier than I could probably explain it.
I hope this helps you in solving the problem. If you need further assistance please feel free to ask.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Feb 15, 2010 | Fellowes 3011001 Shredder
NEED TO KNOW THE OHMS VALUE FOR RESISTOR ON PEANUT 8685
I have the same problem, but it is open.  The color code Brown - Green - Brown - Gold.  If it is a resistor, the value must be 150 ohms +/- 5%.  To confirm the value, I open the working trimmer and remove one leg from the circuit and measure resistance.  The meter reads only 4 ohms.  Therefore, I think it is an inductor (150uH +/-5%), not resistor.
Jan 27, 2009 | Wahl 8685 Hair Trimmer
WILL NOT TURN ON
Sir;
friend of mind had the same model # and he give me the color band for the resistor
Nov 18, 2008 | Yamaha HTR-5560 Receiver
I have a resistor problem in sanyo ST-21G1
it's very difficult to give the exact value of that resistor.,but i can give some tips to find the value of the said resistor .( find how the resistor works, it is a dropping or fusable? if fusable used .47 or 1 ohm resistor if it is a dropping resistor you should make a trial and error .from 100k,10k or 1k.
Oct 29, 2008 | Televison & Video
Resistor problem in sanyo
I can not even begin to help without the model number as each model is slightly different. Can you post that please?
Thanks,
Dan
Burn resistor
if its a 4 band resistor, use the following calculator...
http://www.dannyg.com/examples/res2/resistor.htm
if the resistor is a 5 band, use the following link....
http://www.sizes.com/materls/resistorcolor.htm
hope this helps!
Jun 16, 2008 | Dell E773C 17" CRT Monitor
I had projection tv.modle#pt-47wx49.i had convergence problum.i change both big ics.one resistor is blown out. what is the valueof resistor place on R7050,or R7001,or R7059.please help me.
R7050 and R7059 are both 2.2ohm 2watt Resistor R7001 is either 82 or 8.2 ohm if you give me the colors of the bands on that resistor I will let you know for positive what the value of R7001 is
Apr 26, 2008 | Televison & Video
1999 sony trinitron kv-36fv26
Hello, please check: 1) is the regulated B+ avail at collector of HOT? 2)does the base of HOT go negative when unit is powered? 3)have you examined the external PIN diode for leakage? I sorta recall from memory this circuit and the B+ path from original 165 volt source thru to collector of HOT is not a simple distrubution path i recall a VDR in second stage with a resistor to ground around 5.6 ohms this resistor will discolor or change value if the VDR is defective be careful there are several of these VDR's avail use only the correct one. Best regards, Arpi
May 28, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
